I installed other version of manjaro in my particion manjaro, the GRUB was not created then i saw in GPT need 1mb BIOS-BOOT particion, then i installed manjaro again resizing the perticion and create the bios-boot particion with with bios_grub flag, and the manjaro root, but again doesnt work. When i reboot have a delay and only start the manjaro, in the bios i change the order to start in the HD and snd the manjaro particion. I try edit /etc/default/grub still doesnt work.
I cant upload images and links here.
Please help me!
Let me get this straight… You installed Manjaro in your Manjaro, then you installed Manjaro. Are you dual-booting Manjaro with the Manjaro in the Manjaro?
no lol, i was formatting/resetting my manjaro, dual boot with windows, the images ht!tps://imgur.com/a/QTB7x2t
please help me idk what to do!
Screenshots are hard to see on mobile and can’t be indexed for searching.
Please post the output of the commands in your screenshots here with Preformatted text </>.
boot on USB iso manjaro
open a terminal and a browser on this topic
inxi -Fza
sudo parted -l
manjaro@manjaro-bspwm Linux 5.6.12-1-MANJARO x86_64 20.0.1 Lysia
~ >>> inxi -Fza
System: Host: manjaro-bspwm Kernel: 5.6.12-1-MANJARO x86_64 bits: 64
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=nonfree nouveau.modeset=0
i915.modeset=1 radeon.modeset=0 misobasedir=manjaro misolabel=MANJARO_BSPWM_2001 quiet systemd.show_status=1
Desktop: bspwm 0.9.7-2-g342c2e3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: MSI model: H110M PRO-VH PLUS (MS-7A15) v: 1.0 serial: <filter>
UEFI [Legacy]: American Megatrends v: 1.80 date: 07/20/2017
CPU: Topology: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP family: 6 model-id: 9E (158) stepping: 9
microcode: CA L2 cache: 6144 KiB
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 440.82
Display: x11 server: X.org 1.20.8 driver: nvidia resolution: <xdpyinfo missing>
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.6.12-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 946.07 GiB used: 479.2 MiB (0.0%)
ID-1: /dev/sda vendor: Toshiba model: HDWD110 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 14.56 GiB block size: physical: 512 B
logical: 512 B
Partition: ID-1: / raw size: N/A size: 5.81 GiB used: 479.1 MiB (8.1%) fs: overlay source: ERR-102
Sensors: System Temperatures: cpu: 35.0 C mobo: 29.8 C gpu: nvidia temp: 27 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info: Processes: 175 Uptime: 1m Memory: 7.74 GiB used: 395.8 MiB (5.0%) Shell: zsh inxi: 3.0.37
~ >>> sudo parted -l
Model: ATA TOSHIBA HDWD110 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 524MB 523MB ntfs Basic data partition hidden, diag
2 524MB 629MB 105MB fat32 EFI system partition boot, esp
3 629MB 646MB 16.8MB Microsoft reserved partition msftres
4 646MB 860GB 859GB ntfs Basic data partition msftdata
5 860GB 995GB 135GB ext4
7 995GB 995GB 1049kB
6 995GB 1000GB 5565MB linux-swap(v1) swap
in case in boot USB iso manjaro ( or for boot linux on disk) you are not in Full EFI
( *UEFI[legacy] means it should start EFI , but some options in bios failback to legacy or you have a /boot/efi)
you will have to check all options in Bios
1 - save profile for windows
2 - for linux or USB iso
- disable secureboot
- disable legacy
- disable csm
- choose UEFI on others ( not linux )
- disks are on on AHCI
- disable fastboot
to check on USB iso manjaro if boot EFI is OK
USB iso should appears as UEFI < USB vendor name > < partition 1 > for boot EFI
open a terminal and check
inxi -MCza
sudo efibootmgr -v
test -d /sys/firmware/efi && echo efi || echo bios
dont forget to save profile for linux in bios
~ >>> inxi -MCza
Machine: Type: Desktop Mobo: MSI model: H110M PRO-VH PLUS (MS-7A15) v: 1.0 serial: UEFI: American Megatrends
~ >>> sudo efibootmgr -v
BootCurrent: 0006
Timeout: 1 seconds
BootOrder: 0006,0000,0002,0004,0001,0005
Boot0000* Windows Boot Manager HD(2,GPT,c70f98e6-3fca-4b01-adc7-c7cb75e93657,0xfa000,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS…x…B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}…
Boot0001 Hard Drive BBS(HD,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0200)…GO…NO…T.O.S.H.I.B.A. .H.D.W.D.1.1.0…,.@.r.d.=.X…A…>…Gd-.;.A…MQ…L. . . . . . . . . . .Z. .H.7.S.T.J.A.S.F…BO
Boot0002* Manjaro HD(2,GPT,c70f98e6-3fca-4b01-adc7-c7cb75e93657,0xfa000,0x32000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0004* kali HD(2,GPT,c70f98e6-3fca-4b01-adc7-c7cb75e93657,0xfa000,0x32000)/File(\EFI\KALI\GRUBX64.EFI)
Boot0005 USB KEY BBS(HD,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0b00)…GO…NO…S.a.n.D.i.s.k. .C.r.u.z.e.r. .B.l.a.d.e. .1…2.7…,.@.r.d.=.X…A…>…Gd-.;.A…MQ…L.4.C.5.3.1.0.0.1.4.3.0.3.1.0.1.2.3.4.7.4…BO
Boot0006* UEFI: SanDisk Cruzer Blade 1.27 PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/CDROM(1,0x3b7290,0x8000)…BO
~ >>> test -d /sys/firmware/efi && echo efi || echo bios
efi
it`s EFI now, but i dont what do you mean whith profiles in BIOS, i dont see that option, and i dont know which SO i select the boot option priorities in the HD, see how are my BIOS.
`https://paste.pics/A5P3G
`https://paste.pics/A5P3A
ok you are well boot in UEFI
if you select in boot order manjaro ( 2nd line ) it should boot on it ( without USB iso )
I reboot without USB iso, and manjaro in HD 1st order and appear this error.
`https://paste.pics/A5PC2
so you boot on usb iso manjaro ( UEFI )
open a terminal
sudo lsblk -fs
sudo manjaro-chroot -a ( type 1 if one line 0 appears )
cat /etc/fstab
exit ( quit chroot )
~ >>> sudo lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
├─sda1 ntfs Recuperação 26A20E0BA20DDFE3
├─sda2 vfat FAT32 CC11-0B25
├─sda3
├─sda4 ntfs D4E041FAE041E2FA
├─sda5 ext4 1.0 29200915-f622-4c5d-be01-5849d759c03b
├─sda6 swap 1 abb8941c-00ba-4653-97ff-1d818dc7c2d4
└─sda7
sdb iso9660 Joliet Extension MANJARO_BSPWM_2001 2020-05-22-00-29-48-00
├─sdb1 iso9660 Joliet Extension MANJARO_BSPWM_2001 2020-05-22-00-29-48-00 0 100% /run/miso/bootmnt
└─sdb2 vfat FAT12 MISO_EFI A514-D968 3.9M 4% /media/MISO_EFI
~ >>> sudo manjaro-chroot -a
==> Detected systems:
--> 0) ManjaroLinux
==> Select system to mount [0-0] :
1
==> Mounting (ManjaroLinux) [/dev/sda5]
--> mount: [/mnt]
[manjaro-bspwm /]# cat /etc/fstap
cat: /etc/fstap: No such file or directory
And why don`t appear windows in detected systems?
error type , cat /etc/fstab
sorry,
[manjaro-bspwm /]# cat /etc/fstab
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a device; this may
be used with UUID= as a more robust way to name devices that works even if
disks are added and removed. See fstab(5).
<file system> <mount point> <type> <options> <dump> <pass>
UUID=29200915-f622-4c5d-be01-5849d759c03b / ext4 defaults,noatime 0 1
[manjaro-bspwm /]# exit
exit
--> umount: [/mnt]
now?
1 - you have to add in /etc/fstab /boot/efi
nano /etc/fstab
mkdir /boot/efi
as example
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=CC11-0B25 /boot/efi vfat defaults,noatime 0 2
2 - redo a chroot for get /boot/efi ( 2nd time )
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --verbose
efibootmgr -v
[manjaro-bspwm /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --verbose
Installing for x86_64-efi platform.
grub-install: info: cannot open `/boot/grub/device.map': No such file or directory.
grub-install: error: failed to get canonical path of `/boot/efi'.
what have you get after manjaro-chroot -a ?
is /mnt/boot/efi appears ?
--> 0) ManjaroLinux
1
--> mount: [/mnt]
only appear this in nano /etc/fstab
i have to write in /etc/fstab?
yes you have to add in /etc/fstab
add line /boot/efi
nano /etc/fstab
then save ( ctrl+X)
exit
~ >>> cat /etc/fstab
# /etc/fstab: static file system information
# <file system> <dir> <type> <options> <dump> <pass>
/dev/mapper/root-image / auto defaults 0 0
~ >>> manjaro-chroot -a
--> 0) ManjaroLinux
1
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: mount point does not exist.
[manjaro-bspwm /]#
after i edit
