I’m trying to install the Manjaro ARM on a GT King and my problem is about the correct dtb file. Wifi doesn’t work.
Thinking generally, if there was a tool that probes the hardware an generate dtb file correctly, many hours of testing would be saved.
There are two possibilities: First, many of these sbc boards come with Android that uses all hardware completely. One Android App could generate the dtb for that hardware.
The second possible solution is a JEOS distribution, with only objective to boot in a specific hardware and create corresponding dtb.
In my case, I could extract the dtb from Android image that everything works. Was a surprise to me that this dtb file does not work with Manjaro 5.15 kernel.
So, the possible solutions can be:
A conversion between Android version x dtb to Linux version y dtb
A abstraction layer in kernel that make dtb of old kernel version work in new kernel.
A Linux kernel that could test possible solutions, and, may be, interactively, find the right parameters that substitute the old dtb.
