I run Manjaro KDE Wayland and I want to create high quality YouTube videos. I’m trying to find a good camera that I can connect though USB to my desktop to record through OBS, but also have it being portable to record in a outside area using a tripod and saving to internal storage or SD card
Which camera would you recommend? I do not want those 10-15 years old canon or Nikon DSLR, I would prefer something newer.
Would this be able to work abs be recognized easily if it was plugged in or it would need special drivers and set up?
I find no info on if it works on linux or not, but you should probably make sure before investing.
But wait and see if they respond to this on the Q & A, that I assume is you…
· 6 hours ago
WIll this plug-and-play with Linux? I run Manjaro KDE wayland and while webcams work out of the box without drivers with OBS and Teams I wonder if this camera will work out of the box in full quality and resolution on Linux Wayland without special drivers
