Hello,
At first my computer froze, so I forcefully shut it down. On the next boot, the system dropped me into the emergency rootfs shell. How can I fix this?
:: running early hook [udev]
:: running hook [udev]
:: Triggering uevents...
[ 0.931294] wmi: Failed to parse WDG method
:: running hook [keymap]
Loading keymap...done.
:: running hook [encrypt]
:: performing fsck on '/dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600'
/dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600 contains a file system with errors, check forced.
Inode 14418116 extent tree (at level 1) could be narrower. IGNORED.
Inode 14948887 extent tree (at level 1) could be shorter. IGNORED.
/dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600: Inode 14949823 extent tree (at level 1) could be shorter. IGNORED.
Inode 14950700 extent tree (at level 1) could be shorter. IGNORED.
Inode 14977542 extent tree (at level 1) could be shorter. IGNORED.
Inode 29360556 extent tree (at level 1) could be narrower. IGNORED.
/dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600: Inode 29361709 extent tree (at level 1) could be narrower. IGNORED.
/dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600: Inodes that were part of a corrupted orphan linked list found.
/dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
ERROR: Bailing out. Run 'fsck /dev/mapper/luks-57a92bc2-e0d5-4934-920f-62bf530af600' manually
********** FILESYSTEM CHECK FAILED **********
* Please run fsck manually. After leaving *
* this maintenance shell, the system will *
* reboot automatically. *
sh: can't access tty; job control turned off
[rootfs ~]#
Mod edit: Converted screenshot to text via OCR. This way it’s searchable and saves server space. ![]()
