I just did a fresh install of Manjaro, and now I can’t find Dropbox in the Package Manager. I’ve checked “Enable AUR support” in the Third Party tab, and I’ve refreshed the database, but Dropbox can not be found.
Has Dropbox been removed from the repository?
cscs
16 February 2025 01:30
2
It may be noted that dropbox or any variant thereof is not present in the official repositories.
To my knowledge it was never there.
There are some packages in the AUR though.
This would be roughly the approach.
Did you sort mirrors?
For whatever reason there have been a few threads about ‘enabling AUR in pamac does not make AUR available’ … but most or all eventually resolve with no clear rationale.
Like here
Enabled in Pamac- database refreshed, . Pamac restarted, searched for ‘Brother’ and nothing came up. Search for anything in AUR and …nothing.
Works ok on a KDE-Plasma install on another PC. And prior to Gnome worked on KDE-Plasma on the this PC. AUR is listed on the left but selecting it comes up blank.
Well guess what, just tried again and there it is!! I’m baffled.
You may also consider alternative package managers and/or aur-helpers .
yay, paru, and trizen are among the favorites for aur-helpers that are frontends for pacman.
pacman being the default package manager of Arch, that is included in manjaro, that is exceedingly reliable but cli-only.
Ben
16 February 2025 01:50
3
I had it via AUR before, but there was an issue (it always showed ‘connecting’) which I fixed by purging that, and installing via flatpak instead.
I enabled flatpack, refreshed the database, and it’s still not showing up in the package manager. I have no idea what’s going on.
Ben
16 February 2025 02:23
5
Open a terminal:
❯ flatpak install dropbox
Looking for matches…
Remotes found with refs similar to ‘dropbox’:
1) ‘flathub’ (system)
2) ‘flathub’ (user)
Which do you want to use (0 to abort)? [0-2]:
Annoyingly AUR is borked in pamac for me too.
pamac fails with AUR again...
pamac search dropbox
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
Using yay dropbox
1 aur/dropbox 214.4.5217-1 (+2375 1.94)
Okay, well, that gets me a little further. I was able to install with flatpak and start the application, but there was no option to login, and trying to install with yay gives me the error, “Cannot find the fakeroot binary.”
It’s too late in the day right now for me to mess around with this further (I’m tired and likely to make a mistake), so I’ll figure it out later. It just seems like the package manager is not working like it’s supposed to, which is annoying.
Ben
16 February 2025 02:40
7
Purge the config files and connect fresh.
cscs
16 February 2025 03:07
8
Using the AUR requires prerequisites - in this case base-devel.
Dropbox is available as a Flatpak or via the AUR.
If you enable AUR and or Flatpak in pamac-gui, you will find them.
Alternately you can use
in the CLI, or
yay -S dropbox
An update to pamac should be passing on shortly - should fix the issue
opened 07:23AM - 23 Jan 25 UTC
Previously reported as issue #1
The app fails to read AUR data
## pacman ver… sion
$ pacman --version
.--. Pacman v7.0.0 - libalpm v15.0.0
/ _.-' .-. .-. .-. Copyright (C) 2006-2024 Pacman Development Team
\ '-. '-' '-' '-' Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
## pamac version
$ pamac --version
pamac-cli 11.7.1 - libpamac 11.7.0
Copyright © 2019-2024 Guillaume Benoit
This program is free software, you can redistribute it under the terms of the GNU GPL.
## manjaro branch
$ pacman-mirrors -G
unstable
## search
$ pamac search visual-studio-code-bin
## force refresh
$ pamac update --aur --dry-run --force-refresh
Preparing...
Nothing to do.
## using sudo to force refresh
$ sudo pamac update --aur --dry-run --force-refresh
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Nothing to do.
## db location
No matter how one attempts to retrieve the database it will not work
$ ls /var/lib/pacman/sync -l
-rw-r--r-- 1 root root 141877 22 jan 17:28 core.db
-rw-r--r-- 1 root root 8524755 23 jan 02:50 extra.db
-rw-r--r-- 1 root root 143986 23 jan 02:50 multilib.db
-rw-r--r-- 1 root root 1865 20 jan 04:13 sublime-text.db
-rw-r--r-- 1 root root 543 20 jan 04:13 sublime-text.db.sig
## pacman package info
$ pamac info pacman
Version : 7.0.0.r10.ga2d0293-1
Description : A library-based package manager with dependency support
URL : https://www.archlinux.org/pacman/
Licenses : GPL-2.0-or-later
Repository : core
Installed Size : 5,1 MB
Groups : --
Depends On : bash coreutils curl gawk gettext glibc gnupg gpgme grep
libarchive pacman-mirrorlist systemd
Optional Dependencies : base-devel: required to use makepkg [Installed]
perl-locale-gettext: translation support in makepkg-template
Required By : arch-install-scripts archlinux-keyring autogit base
base-devel libpamac manjaro-check-repos manjaro-keyring
mhwd packagekit pacman-contrib pacseek paru-bin pyalpm
repoctl yay
Optional For : --
Provides : libalpm.so=15-64
Replaces : --
Conflicts With : --
Packager : Philip Mueller <philm@manjaro.org>
Build Date : søn 27 okt 2024 07:15:28 CET
Install Date : <irrelevant>
Install Reason : Installed as a dependency for another package
Validated By : Signature
Backup files : /etc/pacman.conf /etc/makepkg.conf
/etc/makepkg.conf.d/rust.conf
## pamac-cli package info
$ pamac info pamac-cli
Version : 11.7.1-1
Description : A CLI Package Manager based on libalpm with AUR support
URL : https://github.com/manjaro/pamac-cli
Licenses : GPL-3.0-or-later
Repository : extra
Installed Size : 180,7 kB
Groups : --
Depends On : libpamac>=11.7.0
Optional Dependencies : plymouth: offline upgrade support [Installed]
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : pamac<=7.3.4-2
Packager : Mark Wagie <mark@manjaro.org>
Build Date : man 11 nov 2024 18:00:36 CET
Install Reason : Explicitly installed
Backup files : --
## libpamac package info
$ pamac info libpamac
Version : 11.7.0-2
Description : Library for Pamac package manager based on libalpm
URL : https://github.com/manjaro/libpamac
Repository : extra
Installed Size : 4,0 MB
Groups : --
Depends On : appstream dbus-glib git glib2 json-glib libalpm.so=15
libsoup3 pacman-mirrors polkit
Optional Dependencies : --
Required By : pamac-cli
Optional For : --
Provides : libpamac.so=11 pamac-common libpamac-appstream.so=11
libpamac-appstream-plugin libpamac-aur.so=11
libpamac-aur-plugin
Replaces : pamac-common
Conflicts With : libpamac-aur-plugin libpamac-appstream-plugin
Build Date : ons 04 dec 2024 19:43:10 CET
Backup files : /etc/pamac.conf
I got this resolved. In order to use yay, I needed to first run
>sudo pacman -S --needed base-devel
to download the requisite packages (that was the cause of the “Cannot find the fakeroot binary” error). After that
>yay dropbox
worked as expected, and now I have Dropbox up and running again.
Thanks for everyone’s help.
cscs
16 February 2025 21:59
18
As this is news to you I might guess you have not familiarized yourself with the Arch User Repository. This is a requirement otherwise you may run into other problems in the future.
I suggest looking over the wiki(s).
Arch User Repository - Manjaro
Arch User Repository - ArchWiki
system
Closed
20 February 2025 06:05
20
