08:50:47 AM CDT)
==> Checking runtime dependencies…
==> Checking buildtime dependencies…
==> Retrieving sources…
→ Found DropboxGlyph_Blue.svg
→ Found terms.txt
→ Found dropbox.service
→ Found dropbox@.service
→ Found dropbox-lnx.x86_64-210.4.4854.tar.gz
→ Found dropbox-lnx.x86_64-210.4.4854.tar.gz.asc
==> Validating source files with sha256sums…
DropboxGlyph_Blue.svg … Passed
terms.txt … Passed
dropbox.service … Passed
dropbox@.service … Passed
==> Validating source_x86_64 files with sha256sums…
dropbox-lnx.x86_64-210.4.4854.tar.gz … FAILED
dropbox-lnx.x86_64-210.4.4854.tar.gz.asc … Skipped
==> ERROR: One or more files did not pass the validity check!
Failed to build dropbox
aur/dropbox 210.4.4854-1 (+2375 2.61) (Installed: 205.4.5765-1)
How did I do this? I cheat:
chaotic-aur/dropbox 205.4.5765-1 (90.5 MiB 227.5 MiB) (Installed)
That works if you aren’t too keen to build (",)
searching AUR also: AUR (en) - dropbox
Your issue is there (2024-10-09)
But take note, Chaotic is unsupported (like AUR) but also less popular because you don’t get to check pkgbuilds - it’s more risky.
Still, great if you don’t want to compile a browser and there’s no -bin option from AUR.
What do you mean by “cheat”? I updated via add/remove software, because I received a notification for an update! I also tried the Konsole, but got the same result.
This time the maintainer forgot to update the checksum
AUR (en) - dropbox
Richardk2n commented on 2024-10-22 10:27 (UTC)@mtorromeo forgot to update the SHA256. New one is
ec2ee411a295ab1f559243ad267899f7b4b7405d97641374909ab0fd4b310fd0for
sha256sums_x86_64
To validate the x86_64 file, user can edit the PKGBUILD to use the correct sha256sum:
sha256sums_x86_64=('ec2ee411a295ab1f559243ad267899f7b4b7405d97641374909ab0fd4b310fd0
Files should then pass validation for package to build
DropboxGlyph_Blue.svg ... Passed
terms.txt ... Passed
dropbox.service ... Passed
dropbox@.service ... Passed
==> Validating source_x86_64 files with sha256sums...
dropbox-lnx.x86_64-210.4.4854.tar.gz ... Passed
dropbox-lnx.x86_64-210.4.4854.tar.gz.asc ... Skipped
==> Verifying source file signatures with gpg...
I mean ‘cheat’ by downloading Chaotic version, not building via AUR.
@fhins – This appears to be the solution to your issue.
Disclaimer:- Software installed from the AUR is officially unsupported by Manjaro (or Arch).
I couldn’t figure out exactly where exactly to modify it, but it is fixed now and updated.
This was the reason for the validity check failing.
The inference should have been obvious – wait for the maintainer to correct it – which now, they obviously have, as dropbox builds without issue.
Cheers.
