Hi newbie here,
my boot times are about 10+ min and it seems to me that quite some time is spend on an error
> dmesg
[ 561.078691] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:91:pipe A] flip_done timed out
[ 571.105330] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:91:pipe A] flip_done timed out
[ 581.132012] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:91:pipe A] flip_done timed out
[ 591.158670] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CONNECTOR:215:eDP-1] flip_done timed out
[ 601.185336] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:31:plane 1A] flip_done timed out
[ 611.212016] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:91:pipe A] flip_done timed out
[ 621.238660] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:91:pipe A] flip_done timed out
[ 631.265335] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CONNECTOR:215:eDP-1] flip_done timed out
[ 641.291993] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:91:pipe A] flip_done timed out
i searched the error and tried adding “video=SVIDEO-1:d” to the kernel parameters (updated with update-grup ), but that did not help.
here is some info
> inxi -Fza
System: Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=bb7308de-27e8-4b2e-945a-994b9c105dde rw video=SVIDEO-1:d apparmor=1
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Razer product: Blade Stealth 13 (Early 2020) - RZ09-0310 v: 2.04
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Razer model: LY325 serial: <filter> UEFI: Razer v: 1.02 date: 05/26/2020
Battery: ID-1: BAT0 charge: 17.2 Wh condition: 52.8/53.4 Wh (99%) volts: 11.1/11.6
model: Razer Blade type: Unknown serial: <filter> status: Discharging
CPU: Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 7E (126) stepping: 5 microcode: 78 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23968
Speed: 746 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 850 2: 1170 3: 626 4: 926
5: 682 6: 1236 7: 936 8: 727
Graphics: Device-1: Intel Iris Plus Graphics G7 vendor: Razer USA driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:8a52
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Razer USA driver: nvidia
v: 450.66 alternate: nouveau,nvidia_drm bus ID: 58:00.0 chip ID: 10de:1f95
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus ID: 3-6:4
chip ID: 13d3:56d5 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia unloaded: intel,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 166 size: 294x165mm (11.6x6.5")
diag: 337mm (13.3")
OpenGL: renderer: llvmpipe (LLVM 10.0.1 256 bits) v: 3.3 Mesa 20.1.6 compat-v: 3.1
direct render: Yes
Audio: Device-1: Intel Smart Sound Audio vendor: Razer USA driver: sof-audio-pci
alternate: snd_hda_intel,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Sound Server: ALSA v: k5.7.17-2-MANJARO
Network: Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter driver: iwlwifi
v: kernel port: 4000 bus ID: 00:14.3 chip ID: 8086:34f0
Drives: Local Storage: total: 946.39 GiB used: 7.04 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 2B2QEXM7 scheme: GPT
ID-2: /dev/sda type: USB vendor: Intenso model: Alu Line size: 14.88 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: 8.07 scheme: MBR
Partition: ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%) used: 7.04 GiB (0.8%) fs: ext4
dev: /dev/nvme0n1p2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 36.0 C mobo: N/A
Info: Processes: 194 Uptime: 20m Memory: 15.38 GiB used: 755.1 MiB (4.8%) Init: systemd v: 246
Compilers: gcc: 10.2.0 Packages: pacman: 1029 lib: 270 Shell: Zsh v: 5.8
running in: urxvtd inxi: 3.1.05
does anyone know what is causing it or has an idea in which direction i can go?
thanks in advance
