Hi all,
Today I’m back to my home office after a couple of months. My secondary screen, a Samsung SyncMaster T220 is no longer recognized by my laptop. The monitor display tool thinks it’s an AlgolTek 15’, but no signal is sent there.
It used to work before, so the problem was either caused by some update, or by me removing some orphan packages a while ago.
What would be the best approach to find out what drivers I’m missing? The amount of nvidia packages is massive, especially if you include AUR.
Any help would be appreciated!
Hi @mathemaat ,
Theoretically this shouldn’t be necessary. Please provide the output of:
mhwd --list
mhwd --listinstalled
And:
inxi --verbosity 7 --filter
$ mhdw --list
> 0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
$ mhdw --listinstalled
> Installed PCI configs:
$ inxi --verbosity 7 --filter
Kernel: 6.6.33-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: HP product: HP ProBook 640 G8 Notebook PC v: N/A
Mobo: HP model: 87ED v: KBC Version 33.14.00 serial: <superuser required>
part-nu: 250A3EA#ABH uuid: <superuser required> UEFI: HP
v: T74 Ver. 01.07.02 date: 11/25/2021
ID-1: BAT0 charge: 32.8 Wh (95.6%) condition: 34.3/45.0 Wh (76.3%)
volts: 12.3 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 92
System RAM: total: 32 GiB available: 31.04 GiB used: 14.93 GiB (48.1%)
Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: 1 width (bits): data: 64 total: 64
manufacturer: Crucial part-no: CT16G4SFRA32A.M16FR serial: <filter>
Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous size: 16 GiB
Info: quad core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB
Speed (MHz): avg: 1570 high: 1614 min/max: 400/4700 cores: 1: 1612 2: 1585
3: 1530 4: 1614 5: 1546 6: 1585 7: 1529 8: 1561 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.1 ports: active: HDMI-A-1,eDP-1
empty: DP-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 3-2:3 chip-ID: 0408:5347 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 953x286mm (37.52x11.26")
s-diag: 995mm (39.17")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Samsung SyncMaster
serial: <filter> res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.66x11.65") diag: 559mm (22") modes: max: 1680x1050
min: 720x400
Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x068b
res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.17x6.85")
diag: 355mm (14") modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
Device-2: JMTek LLC. USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 bus-ID: 3-6:7 chip-ID: 0c76:160a class-ID: 0300
API: ALSA v: k6.6.33-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.7 status: off
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fc class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: br-06aac060ddbb state: down mac: <filter>
IF-ID-2: br-2254a1740a90 state: down mac: <filter>
IF-ID-3: br-2d1df9affcb9 state: down mac: <filter>
IF-ID-4: br-559d8ea45148 state: down mac: <filter>
IF-ID-5: br-57579196d884 state: down mac: <filter>
IF-ID-6: br-5fd051357e68 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-7: br-686bdbdcc290 state: down mac: <filter>
IF-ID-8: br-7e166968ebad state: down mac: <filter>
IF-ID-9: br-b0110813be86 state: down mac: <filter>
IF-ID-10: br-cf03ecd63a49 state: down mac: <filter>
IF-ID-11: br-f15626113eb8 state: down mac: <filter>
IF-ID-12: br-f1f2372ac988 state: down mac: <filter>
IF-ID-13: docker0 state: down mac: <filter>
IF-ID-14: veth46211cb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth4e47ef2 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: vethaef1466 state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 bus-ID: 3-10:6 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 94.48 GiB (19.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1006 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: HPS2 temp: 28.9 C scheme: GPT
ID-1: / size: 468.09 GiB used: 94.48 GiB (20.2%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: a432be9b-15bd-475f-b169-cd9516f7a995
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: NO_LABEL uuid: 0685-6D9F
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
speed: 480 Mb/s lanes: 1 chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
lanes: 1 chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Dell Keyboard SK-8115 type: keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s lanes: 1
power: 70mA chip-ID: 413c:2003 class-ID: 0301
Device-2: 3-2:3 info: Quanta HP HD Camera type: video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s lanes: 1 power: 500mA
chip-ID: 0408:5347 class-ID: 0e02 serial: <filter>
Device-3: 3-4:4 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s lanes: 1 power: 300mA chip-ID: 046d:c092 class-ID: 0300
serial: <filter>
Device-4: 3-6:7 info: JMTek LLC. USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 0c76:160a class-ID: 0300
Device-5: 3-7:5 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA
chip-ID: 06cb:00f0 class-ID: ff00 serial: <filter>
Device-6: 3-10:6 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 326 Power: uptime: 4h 45m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform Init: systemd v: 256 default: graphical
Packages: pm: pacman pkgs: 1444 Compilers: clang: 17.0.6 gcc: 14.1.1
Shell: Bash v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.35
And please:
xrandr --listactivemonitors
Outputs without/with the secondary monitor plugged in respectively.
$ xrandr --listactivemonitors
Monitors: 1
0: +eDP-1 1920/309x1080/174+0+0 eDP-1
Monitors: 2
1: +HDMI-1 1024/256x768/192+1920+0 HDMI-1
Should I update my previous post so it shows the output with the secondary monitor plugged in?
Positive.
But, seeing as everything looks fine from what I can see, except that the second monitor is obviously detected incorrectly, but detected nonetheless, I suspect the cable or something…
Well, that’s silly. I gave the cables another pull and the monitor is recognized correctly again.
Thanks for the assistance!
system
Closed
20 June 2024 23:42
8
