Hello everyone, I wanted to see if anyone could help me get the driver for the Canon Pixma G6010 printer.
Try canon-pixma-g6000-complete
from the AUR (Arch User Repository).
Unfortunately, the correct driver is not in the package. So I can’t install it. I’ll have to go back to Mint. Even though the experience with Manjaro is much better.
Did you try the suggested package or simply read the description and decide for yourself? Although the G6010 isn’t specifically mentioned in that description, being in the same G6XXX family, it’s still likely to work.
If you did actually try it, ignore this. Cheers.
