I used “Legacy support first” mode in BIOS, UEFI is disabled (and if I change to UEFI I would need to rewrite the boot), so Secure Boot should also be disabled.
sudo dmesg --human shows some information about it, it suggest me to use 390xx driver, which is conflict with the Wiki here
https://wiki.archlinux.org/title/NVIDIA
[ +3.741585] nvidia: loading out-of-tree module taints kernel.
[ +0.000015] nvidia: module license 'NVIDIA' taints kernel.
[ +0.000001] Disabling lock debugging due to kernel taint
[ +0.019613] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ +0.028231] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000012] NVRM: The NVIDIA GeForce GT 720M GPU installed in this system is
NVRM: supported through the NVIDIA 390.xx Legacy drivers. Please
NVRM: visit http://www.nvidia.com/object/unix.html for more
NVRM: information. The 470.141.03 NVIDIA driver will ignore
NVRM: this GPU. Continuing probe...
[ +0.001762] NVRM: No NVIDIA GPU found.
[ +0.000205] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.259519] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000008] NVRM: The NVIDIA GeForce GT 720M GPU installed in this system is
[ +0.000645] NVRM: No NVIDIA GPU found.
[ +0.000167] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.217296] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000604] NVRM: No NVIDIA GPU found.
[ +0.000192] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.249159] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000612] NVRM: No NVIDIA GPU found.
[ +0.000201] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.199248] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000574] NVRM: No NVIDIA GPU found.
[ +0.000137] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.227966] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000595] NVRM: No NVIDIA GPU found.
[ +0.000182] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.224643] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000007] NVRM: The NVIDIA GeForce GT 720M GPU installed in this system is
[ +0.000655] NVRM: No NVIDIA GPU found.
[ +0.000175] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.200375] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000592] NVRM: No NVIDIA GPU found.
[ +0.000169] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.253811] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000009] NVRM: The NVIDIA GeForce GT 720M GPU installed in this system is
[ +0.000168] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.189008] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000609] NVRM: No NVIDIA GPU found.
[ +0.000171] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +0.592352] audit: type=1105 audit(1668681894.682:129): pid=2753 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits acct="nx" exe="/usr/NX/bin/nxexec" hostname=? addr=? terminal=ssh res=success'
[ +0.712913] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +1.227759] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000579] NVRM: No NVIDIA GPU found.
[ +0.000139] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ +1.229341] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.001287] NVRM: No NVIDIA GPU found.
[ +0.000443] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[Nov17 11:45] audit: type=1100 audit(1668681910.172:130): pid=2848 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="victor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ +0.000294] audit: type=1101 audit(1668681910.172:131): pid=2848 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="victor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ +0.001214] audit: type=1110 audit(1668681910.175:132): pid=2848 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ +0.000175] audit: type=1105 audit(1668681910.175:133): pid=2848 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[Nov17 11:46] audit: type=1106 audit(1668681974.582:134): pid=2848 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ +0.000012] audit: type=1104 audit(1668681974.585:135): pid=2848 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[Nov17 11:48] audit: type=1100 audit(1668682099.098:136): pid=3137 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="victor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000172] audit: type=1101 audit(1668682099.098:137): pid=3137 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="victor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.001154] audit: type=1110 audit(1668682099.098:138): pid=3137 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000173] audit: type=1105 audit(1668682099.098:139): pid=3137 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +40.606514] audit: type=1106 audit(1668682139.705:140): pid=3137 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000010] audit: type=1104 audit(1668682139.705:141): pid=3137 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[Nov17 11:49] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ +0.000575] NVRM: No NVIDIA GPU found.
[ +0.000153] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[Nov17 11:51] audit: type=1100 audit(1668682303.998:142): pid=3302 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="victor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000295] audit: type=1101 audit(1668682303.998:143): pid=3302 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="victor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.001172] audit: type=1110 audit(1668682303.998:144): pid=3302 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000180] audit: type=1105 audit(1668682303.998:145): pid=3302 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
