Well, I just installed a new computer with Manjaro with Kernel 5.10 / KDe-Plasma
Linux mylinux-inmyhom 5.10.79-1-MANJARO #1 SMP PREEMPT Fri Nov 12 20:26:09 UTC 2021 x86_64 GNU/Linux
I got a Clevo computer AMD Ryzen 5, with 32gb 3200mhz
I installed VmWare and Virutalboxes
the network card Realteck RTL8111/8168/8411 does not recognize ethernet connexions
The wifi connexion works but lags too.
I tried many things and when It starts to be connected, the network lags too much
Of course, I got no sounds, showing there is a conflicts of PCI cards
Regarding the network configuration, I allow just IPV4, not IPV6
First, I tried to Pacman -S R8168 , but it’s not working
Secondly, I downloaded the driver RTL8169_Linux from the website Realtex and try to install it (I created the blacklisted file) Still same errors,
Please help !!
vendor: CLEVO/KAPOK driver: r8168 v: 8.049.02-NAPI port: 3000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
-inmyhom modprobe.d]# inxi -Fxxxza
Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cf6610e5-92e4-44ec-b0d3-a969ef9b2c0f rw quiet apparmor=1
security=apparmor resume=UUID=6bd2b55d-fdfd-4d7b-9541-0836b248d87d
udev.log_priority=3
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: PC Specialist product: NH5xVR v: N/A serial: N/A
Chassis: Notebook type: 10 serial: N/A
Mobo: CLEVO model: NH5xVxx serial: N/A UEFI: Insyde v: 1.07.07RPCS1
date: 02/18/2021
ID-1: BAT0 charge: 57.5 Wh (100.0%) condition: 57.5/62.1 Wh (92.6%)
volts: 12.6 min: 10.9 model: Notebook BAT type: Li-ion serial:
status: Full
Info: 6-Core model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 21 (33) stepping: 0
microcode: A201009 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 88664
Speed: 3152 MHz min/max: 2200/3700 MHz base/boost: 3700/4650
boost: enabled volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 3152
2: 2471 3: 2589 4: 2593 5: 2753 6: 2235 7: 2734 8: 2180 9: 2687 10: 2681
11: 2144 12: 2208
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
vendor: CLEVO/KAPOK driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm
bus-ID: 08:00.0 chip-ID: 10de:249d class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 3-4:2
chip-ID: 5986:9102 class-ID: 0e02
Display: server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.4x7.5")
s-diag: 391mm (15.4")
Monitor-1: DP-2 res: 1920x1080 hz: 240 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
IF: enp4s0 state: down mac:
class-ID: 0280
IF: wlp5s0 state: up mac:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.55 TiB used: 665.88 GiB (14.3%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 91 hrs cycles: 66
read-units: 2,313,869 [1.18 TB] written-units: 3,796,354 [1.94 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
SMART: yes health: PASSED on: 75 hrs cycles: 66
read-units: 1,961,887 [1.00 TB] written-units: 1,997,636 [1.02 TB]
ID-3: /dev/sda maj-min: 8:0 model: 1TB PCS 2.5 SSD size: 931.4 GiB
block-size: physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s
type: SSD serial: rev: 1A0 temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5d 23h cycles: 68
read: 7.3 MiB written: 7.5 MiB
ID-1: / raw-size: 585.84 GiB size: 575.64 GiB (98.26%)
used: 41.96 GiB (7.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:7
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:6
ID-1: swap-1 type: partition size: 35.57 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 56.2 C mobo: 56.0 C gpu: nvidia temp: 43 C
Processes: 345 Uptime: 5h 0m wakeups: 2 Memory: 31.28 GiB
used: 3.78 GiB (12.1%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1432 pacman: 1424 lib: 391 flatpak: 0
snap: 8 Shell: Bash (su) v: 5.1.8 running-in: konsole inxi: 3.3.09
So, Is it the correct driver ?
Should I remove the VMWare driver ?
Any idea ?
pleas help
