Driver for MediaTek 7902 Wifi
I’ve just bought a Acer Aspire 3 which has the wifi card from MediaTek.
Apparently there is no Linux Driver fpr this as yet.
Does anyone know if one is in the works?
Or have I jus bought an expensive brick?
Cheap laptops with Windows - socalled Winbooks - often means flaky wifi.
See → MediaTek Wi-Fi 6E MT7902 Wireless Network Adapter
See → How to get MediaTeK MT7902 support? [SOLVED] / Newbie Corner / Arch Linux Forums
Use a USB wifi adapter or replace the card inside the laptop.
SearX linux driver media tek 7902 wifi - sx.nix.dk
Thanks for the quick response.
That basically confirms what I’ve already found out, namely that no drivers currently exist and the only solution is to buy a dongle.
Considering that this is a Christmas present for my elderly mother, I don’t really want to mess about with external hardware.
The wrapper solution using Windows drivers seems to have very limited success from what I can see.
But thanks anyway.
Are you sure? Did you search the internet for something like, MediaTek 7902 Linux driver? :wink:
:male_detective: :mag_right:
Please see:
