Otherwise i can only expect that the antenna is broken somehow or has a lose contact on the card internally … so that it does not find any SSIDs or the driver, which is a unified one, is just bad on kernel 4.19 … try a newer kernel which have better drivers.
Meantime been done : 1/ deleted the livebox connecting 2 / shutdown the PC. 3/reinstall the wlo (dongle unplugged) and newly introduce activating key and forcing the mac adress as “journalctl”
result : no change …
oh … sorry for the language …but adding lang=c is not active
[philline0@philline0-hplx ~]$ rfkill
ID TYPE DEVICE SOFT HARD
0 wlan hp-wifi débloqué débloqué
1 wlan phy0 débloqué débloqué
2 bluetooth hci0 débloqué débloqué
3 wlan phy1 débloqué débloqué
i translate the 8 answers for soft and hard are all “unblocked”.
Access a 5.4-80 kernel is not possible … I should reinstall my config ! …
The card has been physically reinstalled to be sure it well connected.
Otherwise, with a dongle it is right … that is not the case of the card … so something fails with the card …if not the driver, it’s the sender …you are right…
So the dongle will do the work…forever.
I very appreciated your guiding… with the respect of an old debutant.
Thanks you very much.
philline00 - Basic user.
ps - Re-opened a new topic some days ago because i was not sure we could pursue on this one …
Don,t be annoyed with this way. You gave me all the needed supports and that’s so enough.
