Driver does not work properly Nvidia GT555M
hey, I have a problem with the drivers for the Nvidia GT555M graphics card in my laptop, after installing video-nvidia-390xx black screen with some short writing, while when trying to install video-hybrid-intel-nvidia-390xx-bumblebee appears as properly installed:
>  Starting
> > Using config 'video-hybrid-intel-nvidia-390xx-bumblebee' for device: 0000:01:00.0 (0300:10de:124d) Display controller nVidia Corporation GF116M [GeForce GT 555M/635M]
> > Using config 'video-hybrid-intel-nvidia-390xx-bumblebee' for device: 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller
> > Installing video-hybrid-intel-nvidia-390xx-bumblebee...
> Sourcing /etc/mhwd-x86_64.conf
> Has lib32 support: true
> Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-390xx-bumblebee/MHWDCONFIG
> Processing classid: 0300
> Sourcing /var/lib/mhwd/scripts/include/0300
> :: Synchronizing package databases...
>  core downloading...
>  extra downloading...
>  community downloading...
>  multilib downloading...
> error: failed retrieving file 'core.db' from mirror.tuchola-dc.pl : SSL certificate problem: unable to get local issuer certificate
> error: failed retrieving file 'core.db' from mirror.infotronik.hu : The requested URL returned error: 404
> error: failed retrieving file 'extra.db' from mirror.tuchola-dc.pl : SSL certificate problem: unable to get local issuer certificate
> error: failed retrieving file 'extra.db' from mirror.infotronik.hu : The requested URL returned error: 404
> error: failed retrieving file 'community.db' from mirror.tuchola-dc.pl : SSL certificate problem: unable to get local issuer certificate
> warning: too many errors from mirror.tuchola-dc.pl, skipping for the remainder of this transaction
> error: failed retrieving file 'community.db' from mirror.infotronik.hu : The requested URL returned error: 404
> warning: too many errors from mirror.infotronik.hu, skipping for the remainder of this transaction
> resolving dependencies...
> looking for conflicting packages...
> warning: dependency cycle detected:
> warning: primus will be installed before its bumblebee dependency
> Packages (12) egl-wayland-2:1.1.10-1  eglexternalplatform-1.1-2  libxnvctrl-390xx-390.154-1  libxvmc-1.0.13-1  primus-20151110-9  bumblebee-3.2.1-22  lib32-nvidia-390xx-utils-390.154-1  lib32-primus-20151110-4  linux515-bbswitch-0.8-73  linux515-nvidia-390xx-390.154-2  nvidia-390xx-utils-390.154-1  xf86-video-intel-1:2.99.917+916+g31486f40-2
> Total Installed Size:  213.84 MiB
> :: Proceed with installation? [Y/n]
> checking keyring...
> checking package integrity...
> loading package files...
> checking for file conflicts...
> checking available disk space...
> :: Processing package changes...
> installing primus...
> installing eglexternalplatform...
> installing egl-wayland...
> installing libxnvctrl-390xx...
> installing nvidia-390xx-utils...
> ==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
> Optional dependencies for nvidia-390xx-utils
>     xorg-server-devel: nvidia-xconfig
>     opencl-nvidia-390xx: OpenCL support
> installing bumblebee...
> Don't forget to add yourself to the 'bumblebee' group to use Bumblebee
> Optional dependencies for bumblebee
>     xf86-video-nouveau: nouveau driver [installed]
>     nouveau-dri: 3D acceleration features fo nouveau
>     bbswitch: switch on/off discrete card [pending]
>     nvidia: NVIDIA kernel driver [pending]
>     virtualgl: alternative back-end for optirun
>     lib32-virtualgl: run 32bit applications with optirun
>     lib32-primus: faster back-end for optirun [pending]
> installing libxvmc...
> installing xf86-video-intel...
> >>> This driver now uses DRI3 as the default Direct Rendering
>     Infrastructure. You can try falling back to DRI2 if you run
>     into trouble. To do so, save a file with the following
>     content as /etc/X11/xorg.conf.d/20-intel.conf :
>       Section "Device"
>         Identifier  "Intel Graphics"
>         Driver      "intel"
>         Option      "DRI" "2"             # DRI3 is now default
>         #Option      "AccelMethod"  "sna" # default
>         #Option      "AccelMethod"  "uxa" # fallba
> ck
>       EndSection
> Optional dependencies for xf86-video-intel
>     libxrandr: for intel-virtual-output [installed]
>     libxinerama: for intel-virtual-output [installed]
>     libxcursor: for intel-virtual-output [installed]
>     libxtst: for intel-virtual-output [installed]
>     libxss: for intel-virtual-output [installed]
> installing lib32-nvidia-390xx-utils...
> Optional dependencies for lib32-nvidia-390xx-utils
>     lib32-opencl-nvidia
> installing lib32-primus...
> installing linux515-nvidia-390xx...
> installing linux515-bbswitch...
> :: Running post-transaction hooks...
> (1/7) Creating system user accounts...
> (2/7) Reloading system manager configuration...
> (3/7) Reloading device manager configuration...
> (4/7) Arming ConditionNeedsUpdate...
> (5/7) Updating module dependencies...
> (6/7) Refreshing PackageKit...
> (7/7) Updating the desktop file MIME type cache...
> bumblebee: install reason has been set to 'explicitly installed'
> nvidia-390xx-utils: install reason has been set to 'explicitly installed'
> xf86-video-intel: install reason has been set to 'explicitly installed'
> lib32-primus: install reason has been set to 'explicitly installed'
> lib32-nvidia-390xx-utils: install reason has been set to 'explicitly installed'
> linux515-nvidia-390xx: install reason has been set to 'explicitly installed'
> linux515-bbswitch: install reason has been set to 'explicitly installed'
> xorg configuration file: '/etc/X11/mhwd.d/intel.conf'
> Created symlink /etc/systemd/system/multi-user.target.wants/bumblebeed.service → /usr/lib/systemd/system/bumblebeed.service.
> > Successfully installed video-hybrid-intel-nvidia-390xx-bumblebee
> Done ...
and after typing the command inxi -gazy
> Graphics:
>   Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
>     vendor: Dell driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
>     built: 2011 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
>     bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
>   Device-2: NVIDIA GF116M [GeForce GT 555M/635M] vendor: Dell driver: N/A
>     alternate: nouveau, nvidia_drm, nvidia non-free: series: 390.xx+
>     status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
>     process: 40/28nm built: 2010-16 pcie: speed: Unknown lanes: 63 link-max:
>     gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:124d class-ID: 0300
>   Device-3: Quanta Laptop_Integrated_Webcam_2HDM type: USB driver: uvcvideo
>     bus-ID: 1-1.4:3 chip-ID: 0408:2fb1 class-ID: 0e02
>   Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
>     loaded: intel gpu: i915 display-ID: :0 screens: 1
>   Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
>     s-diag: 485mm (19.11")
>   Monitor-1: LVDS-1 mapped: LVDS1 model: Chi Mei Opto 0x1718 built: 2010
>     res: 1600x900 hz: 60 dpi: 107 gamma: 1.2 size: 380x220mm (14.96x8.66")
>     diag: 438mm (17.3") ratio: 16:9 modes: 1600x900
>   OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 22.1.6
>     direct render: Yes
I should add that the HDMI port still does not work
so do you have a problem or not? its not clear from this…
if you have post output from:
mhwd-kernel -li && mhwd -l && mhwd -li
yes I have a problem because the laptop behaves as if it has no drivers for the graphics card, for example the HDMI port which is connected to a dedicated graphics card does not work
I will add that I reinstalled the system and drivera 5 times each time the same thing
output from: mhwd-kernel -li && mhwd -l && mhwd -li
> mhwd-kernel -li && mhwd -l && mhwd -li         ✔
> Currently running: 5.15.60-1-MANJARO (linux515)
> The following kernels are installed in your system:
>    * linux515
> > 0000:01:00.0 (0300:10de:124d) Display controller nVidia Corporation:
>                   NAME               VERSION          FREEDRIVER           TYPE
> video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.26               false            PCI
>     video-nvidia-390xx            2021.11.26               false            PCI
>            video-linux            2018.05.04                true            PCI
>      video-modesetting            2020.01.13                true            PCI
>             video-vesa            2017.03.12                true            PCI
> > 0000:0a:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
>          network-r8168            2016.04.20                true            PCI
> > 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation:
> > Installed PCI configs:
> Warning: No installed USB configs!
i see, so first reboot and provide system info + logs
inxi -Faz
journalctl -b0 -p4 --no-pager
sudo dmesg -l err,warn,emerg,alert
pacman -Qs nvidia
inxi -Faz
  Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=41ccfa96-0761-46ce-881d-89f4765e1d6a rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
  Type: Portable System: Dell product: Dell System XPS L702X v: N/A
    serial: <superuser required> Chassis: type: 8 v: 0.1
  Mobo: Dell model: 0XN71K v: FAB1 serial: <superuser required>
    UEFI-[Legacy]: Dell v: A14 date: 11/11/2011
  ID-1: BAT0 charge: 14.2 Wh (21.0%) condition: 67.7/73.3 Wh (92.3%)
    volts: 10.5 min: 11.1 model: LGC Dell type: Li-ion serial: <filter>
    status: discharging
  Info: model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 940 high: 1170 min/max: 800/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1087 2: 1036 3: 798
    4: 798 5: 798 6: 871 7: 1170 8: 967 bogomips: 35135
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
    22.1.6 direct render: Yes
    vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF116 High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:0bee class-ID: 0403
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 8086:008a class-ID: 0280
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp10s0 state: down mac: <filter>
  Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB
    driver: btusb v: 0.8 bus-ID: 2-1.5:3 chip-ID: 8086:0189 class-ID: e001
  Local Storage: total: 177.84 GiB used: 23.07 GiB (13.0%)
  ID-1: /dev/sda maj-min: 8:0 model: SSD 128GB size: 119.24 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 2B0 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Intenso model: Alu Line
    size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 8.07 scheme: MBR
  ID-1: / raw-size: 119.24 GiB size: 116.81 GiB (97.96%) used: 8.94 GiB
    (7.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 53.0 C mobo: 30.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
  Processes: 316 Uptime: 27m wakeups: 2 Memory: 11.58 GiB used: 1.22 GiB
  (10.6%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pm: pacman pkgs: 1181
  libs: 319 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.21
> Aug 09 10:54:30 XPSL702x kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
> Aug 09 10:54:30 XPSL702x kernel:  #2
> Aug 09 10:54:30 XPSL702x kernel:  #3
> Aug 09 10:54:30 XPSL702x kernel:  #4
> Aug 09 10:54:30 XPSL702x kernel:  #5
> Aug 09 10:54:30 XPSL702x kernel:  #6
> Aug 09 10:54:30 XPSL702x kernel:  #7
> Aug 09 10:54:30 XPSL702x kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
> Aug 09 10:54:30 XPSL702x kernel: mtrr: your CPUs had inconsistent variable MTRR settings
> Aug 09 10:54:30 XPSL702x kernel: pnp 00:05: disabling [mem 0xfffff000-0xffffffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0xfff80000-0xffffffff pref]
> Aug 09 10:54:31 XPSL702x kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\GPIN) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\GPIN) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\GPIN) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
> Aug 09 10:54:31 XPSL702x kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
> Aug 09 10:54:31 XPSL702x kernel: bbswitch: loading out-of-tree module taints kernel.
> Aug 09 10:54:31 XPSL702x kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
> Aug 09 10:54:31 XPSL702x systemd[1]: shadow.service: Failed with result 'exit-code'.
> Aug 09 10:54:31 XPSL702x kernel: r8169 0000:0a:00.0: can't disable ASPM; OS doesn't have ASPM control
> Aug 09 10:54:31 XPSL702x kernel: iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
> Aug 09 10:54:31 XPSL702x kernel: at24 0-0050: supply vcc not found, using dummy regulator
> Aug 09 10:54:31 XPSL702x kernel: at24 0-0052: supply vcc not found, using dummy regulator
> Aug 09 10:54:31 XPSL702x kernel: snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
> Aug 09 10:54:31 XPSL702x kernel: snd_hda_intel 0000:01:00.1: number of I/O streams is 30, forcing separate stream tags
> Aug 09 10:54:31 XPSL702x kernel: Bluetooth: hci0: unexpected event for opcode 0x0000
> Aug 09 10:54:31 XPSL702x systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
> Aug 09 10:54:31 XPSL702x systemd[1]: Failed to start pkgfile database update.
> Aug 09 10:54:31 XPSL702x systemd[419]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D0: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D1: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D2: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D3: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D4: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D5: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D6: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: hdaudio hdaudioC1D7: no AFG or MFG node found
> Aug 09 10:54:31 XPSL702x kernel: snd_hda_intel 0000:01:00.1: no codecs initialized
> Aug 09 10:54:32 XPSL702x kernel: kauditd_printk_skb: 27 callbacks suppressed
> Aug 09 10:54:35 XPSL702x klauncher[548]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
> Aug 09 10:54:35 XPSL702x ksplashqml[525]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
> Aug 09 10:54:35 XPSL702x ksplashqml[525]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
> Aug 09 10:54:36 XPSL702x kcminit_startup[552]: QDBusConnection: error: could not send signal to service "" path "//home/pawel/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/pawel/.kde4/share/config/kdeglobals
> Aug 09 10:54:36 XPSL702x kwin_x11[566]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
> Aug 09 10:54:36 XPSL702x kwin_x11[566]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
> Aug 09 10:54:36 XPSL702x kwin_x11[566]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
> Aug 09 10:54:36 XPSL702x ksmserver[598]: Qt: Session management error: networkIdsList argument is NULL
> Aug 09 10:54:36 XPSL702x ksmserver[598]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
> Aug 09 10:54:36 XPSL702x kded5[563]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
> Aug 09 10:54:37 XPSL702x kwin_x11[566]: kwin_core: XCB error: 10 (BadAccess), sequence: 827, resource id: 1337, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
> Aug 09 10:54:37 XPSL702x baloo_file[609]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
> Aug 09 10:54:37 XPSL702x kded5[563]: kscreen.kded: PowerDevil SuspendSession action not available!
> Aug 09 10:54:37 XPSL702x org_kde_powerdevil[610]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
> Aug 09 10:54:37 XPSL702x pulseaudio[640]: stat('/etc/pulse/default.pa.d'): No such file or directory
> Aug 09 10:54:37 XPSL702x org_kde_powerdevil[610]: org.kde.powerdevil: Handle button events action could not check for screen configuration
> Aug 09 10:54:38 XPSL702x plasmashell[620]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
> Aug 09 10:54:38 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
> Aug 09 10:54:38 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55faf534e1a0)
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55faf5353000)
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55faf530ff50)
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55faf5352920)
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55faf530ff50)
> Aug 09 10:54:38 XPSL702x plasmashell[620]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55faf52f2b70)
> Aug 09 10:54:38 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
> Aug 09 10:54:38 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
> Aug 09 10:54:39 XPSL702x plasmashell[620]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
> Aug 09 10:54:39 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
> Aug 09 10:54:39 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2705, resource id: 4194357, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 10:54:39 XPSL702x kwin_x11[566]: kwin_core: XCB error: 152 (BadDamage), sequence: 2711, resource id: 18874411, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> Aug 09 10:54:39 XPSL702x plasmashell[620]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
> Aug 09 10:54:41 XPSL702x kernel: kauditd_printk_skb: 21 callbacks suppressed
> Aug 09 10:54:43 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
> Aug 09 10:54:43 XPSL702x plasmashell[620]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
> Aug 09 10:54:48 XPSL702x plasmashell[620]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 10:54:48 XPSL702x plasmashell[620]: org.kde.plasma.runner.bookmarks: No default firefox profile found
> Aug 09 10:54:48 XPSL702x plasmashell[620]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
> Aug 09 10:54:49 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3883, resource id: 52428949, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 10:54:49 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3929, resource id: 52428950, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 10:54:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4491, resource id: 18874692, major code: 3 (GetWindowAttributes), minor code: 0
> Aug 09 10:54:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4492, resource id: 18874692, major code: 14 (GetGeometry), minor code: 0
> Aug 09 10:55:07 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf672ad00) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 10:55:07 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> Aug 09 10:55:07 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> Aug 09 10:55:07 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
> Aug 09 10:55:07 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
> Aug 09 10:55:07 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf6b272e0) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 10:55:12 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8891, resource id: 52428953, major code: 15 (QueryTree), minor code: 0
> Aug 09 10:56:03 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
> Aug 09 10:56:18 XPSL702x kernel: sd 6:0:0:0: [sdb] No Caching mode page found
> Aug 09 10:56:18 XPSL702x kernel: sd 6:0:0:0: [sdb] Assuming drive cache: write through
> Aug 09 10:56:33 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
> Aug 09 10:56:33 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15490, resource id: 52429036, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 10:56:33 XPSL702x dolphin[1176]: kf.kio.core: "The file or folder /run/media/pawel/INTENSO does not exist."
> Aug 09 10:57:39 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
> Aug 09 10:57:40 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
> Aug 09 10:59:09 XPSL702x kernel: sd 6:0:0:0: [sdb] No Caching mode page found
> Aug 09 10:59:09 XPSL702x kernel: sd 6:0:0:0: [sdb] Assuming drive cache: write through
> Aug 09 10:59:10 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
> Aug 09 10:59:13 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
> Aug 09 11:00:19 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 904 op 0x0:(READ) flags 0x84700 phys_seg 30 prio class 0
> Aug 09 11:00:19 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 1144 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
> Aug 09 11:00:19 XPSL702x kernel: sd 6:0:0:0: [sdb] tag#0 device offline or changed
> Aug 09 11:00:19 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 904 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> Aug 09 11:00:19 XPSL702x kernel: Buffer I/O error on dev sdb1, logical block 97, async page read
> Aug 09 11:00:19 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 33888 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
> Aug 09 11:00:19 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 33888 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> Aug 09 11:00:19 XPSL702x kernel: Buffer I/O error on dev sdb1, logical block 4220, async page read
> Aug 09 11:00:22 XPSL702x kernel: exFAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
> Aug 09 11:00:34 XPSL702x dolphin[1176]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
> Aug 09 11:00:34 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37153, resource id: 71303265, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:00:34 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37161, resource id: 71303266, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:00:34 XPSL702x kate[1355]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 11:00:35 XPSL702x kate[1355]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 11:00:40 XPSL702x kate[1355]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 11:00:40 XPSL702x kate[1355]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///run/media/pawel/INTENSO/.output.txt.kate-swp")
> Aug 09 11:00:41 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39852, resource id: 77594635, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:00:41 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39856, resource id: 75497618, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:00:41 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39873, resource id: 71303267, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:00:43 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf6449f40) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 11:00:43 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> Aug 09 11:00:43 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> Aug 09 11:00:49 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 8299008 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 0
> Aug 09 11:00:49 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 32959 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0
> Aug 09 11:00:49 XPSL702x kernel: Buffer I/O error on dev sdb1, logical block 32831, lost async page write
> Aug 09 11:00:49 XPSL702x kernel: blk_update_request: I/O error, dev sdb, sector 33894 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0
> Aug 09 11:00:49 XPSL702x kernel: Buffer I/O error on dev sdb1, logical block 33766, lost async page write
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46783, resource id: 52429095, major code: 19 (DeleteProperty), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46786, resource id: 52429095, major code: 19 (DeleteProperty), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46787, resource id: 52429095, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46788, resource id: 52429095, major code: 19 (DeleteProperty), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46789, resource id: 52429095, major code: 19 (DeleteProperty), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46790, resource id: 52429095, major code: 19 (DeleteProperty), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46791, resource id: 52429095, major code: 7 (ReparentWindow), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46792, resource id: 52429095, major code: 6 (ChangeSaveSet), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46793, resource id: 52429095, major code: 2 (ChangeWindowAttributes), minor code: 0
> Aug 09 11:00:50 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46794, resource id: 52429095, major code: 10 (UnmapWindow), minor code: 0
> Aug 09 11:04:06 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47662, resource id: 73400331, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:04:13 XPSL702x kded5[563]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
> Aug 09 11:04:13 XPSL702x kscreenlocker_greet[1459]: Qt: Session management error: networkIdsList argument is NULL
> Aug 09 11:04:14 XPSL702x kscreenlocker_greet[1459]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> Aug 09 11:04:14 XPSL702x kscreenlocker_greet[1459]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> Aug 09 11:20:04 XPSL702x kernel: iwlwifi 0000:03:00.0: RF_KILL bit toggled to enable radio.
> Aug 09 11:20:04 XPSL702x kernel: Bluetooth: hci0: unexpected event for opcode 0x0000
> Aug 09 11:20:06 XPSL702x kded5[563]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
> Aug 09 11:20:06 XPSL702x kdeconnectd[630]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
> Aug 09 11:20:10 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50466, resource id: 73400374, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:20:16 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf733e580) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 11:20:16 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> Aug 09 11:20:16 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> Aug 09 11:20:16 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
> Aug 09 11:20:16 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
> Aug 09 11:20:19 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
> Aug 09 11:20:19 XPSL702x kernel: exFAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
> Aug 09 11:20:54 XPSL702x kwin_x11[566]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
> Aug 09 11:20:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61790, resource id: 18878954, major code: 3 (GetWindowAttributes), minor code: 0
> Aug 09 11:20:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 61791, resource id: 18878954, major code: 14 (GetGeometry), minor code: 0
> Aug 09 11:20:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61794, resource id: 18878954, major code: 3 (GetWindowAttributes), minor code: 0
> Aug 09 11:20:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 61795, resource id: 18878954, major code: 14 (GetGeometry), minor code: 0
> Aug 09 11:20:56 XPSL702x dolphin[1176]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
> Aug 09 11:20:56 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62352, resource id: 71303289, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:20:56 XPSL702x kate[1772]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 11:21:02 XPSL702x kate[1772]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///run/media/pawel/INTENSO/.Inxi Faz.txt.kate-swp")
> Aug 09 11:21:46 XPSL702x dolphin[1176]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
> Aug 09 11:21:46 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4254, resource id: 71303290, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:46 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4262, resource id: 71303291, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:52 XPSL702x kate[1772]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 11:21:53 XPSL702x kate[1772]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///run/media/pawel/INTENSO/.Inxi Faz.txt.kate-swp")
> Aug 09 11:21:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7121, resource id: 79691781, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7125, resource id: 71303292, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7144, resource id: 77594635, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7148, resource id: 75497618, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:54 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7163, resource id: 71303293, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:21:56 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf73d7160) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 11:21:56 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> Aug 09 11:21:56 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> Aug 09 11:21:59 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11044, resource id: 71303294, major code: 15 (QueryTree), minor code: 0
> Aug 09 11:23:26 XPSL702x dolphin[1176]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
> Aug 09 11:23:26 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22949, resource id: 71303315, major code: 18 (ChangeProperty), minor code: 0
> Aug 09 11:23:26 XPSL702x kate[2147]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> Aug 09 11:23:29 XPSL702x kate[2147]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///run/media/pawel/INTENSO/.journalctl.txt.kate-swp")
> Aug 09 11:23:44 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
> Aug 09 11:23:44 XPSL702x plasmashell[620]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
> Aug 09 11:23:44 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
> Aug 09 11:23:44 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
> Aug 09 11:23:45 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
> Aug 09 11:23:45 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
> Aug 09 11:23:52 XPSL702x plasmashell[620]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:604:17: QML Loader: Binding loop detected for property "sourceComponent"
> Aug 09 11:23:52 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
> Aug 09 11:23:52 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
> Aug 09 11:23:52 XPSL702x kded5[563]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
> Aug 09 11:23:53 XPSL702x kded5[563]: org.kde.plasma.nm.kded: Unhandled active connection state change:  1
> Aug 09 11:23:53 XPSL702x kded5[563]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
> Aug 09 11:23:53 XPSL702x kdeconnectd[630]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
> Aug 09 11:23:53 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf7c6c670) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 11:23:53 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> Aug 09 11:23:53 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> Aug 09 11:23:54 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
> Aug 09 11:23:54 XPSL702x plasmashell[620]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
> Aug 09 11:23:57 XPSL702x plasmashell[620]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55faf7b03b60) QQmlContext(0x55faf55ced60) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> Aug 09 11:23:57 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> Aug 09 11:23:57 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> Aug 09 11:23:58 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36723, resource id: 52429168, major code: 20 (GetProperty), minor code: 0
> Aug 09 11:23:58 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36729, resource id: 52429168, major code: 15 (QueryTree), minor code: 0
> Aug 09 11:23:58 XPSL702x kwin_x11[566]: kwin_core: XCB error: 152 (BadDamage), sequence: 36817, resource id: 18881825, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> Aug 09 11:24:03 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41007, resource id: 52429183, major code: 15 (QueryTree), minor code: 0
> Aug 09 11:24:04 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41838, resource id: 18882904, major code: 3 (GetWindowAttributes), minor code: 0
> Aug 09 11:24:04 XPSL702x kwin_x11[566]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 41839, resource id: 18882904, major code: 14 (GetGeometry), minor code: 0
> Aug 09 11:24:04 XPSL702x plasmashell[620]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
> [    0.224130] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
> [    0.224130]  #2
> [    0.228257]  #3
> [    0.230646]  #4
> [    0.234171]  #5
> [    0.236875]  #6
> [    0.240276]  #7
> [    0.248850] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
> [    0.248858] mtrr: your CPUs had inconsistent variable MTRR settings
> [    0.317679] pnp 00:05: disabling [mem 0xfffff000-0xffffffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0xfff80000-0xffffffff pref]
> [    4.061797] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
> [    4.065095] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
> [    4.065115] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
> [    4.065127] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\GPIN) (20210730/utaddress-204)
> [    4.065139] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
> [    4.065156] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
> [    4.065164] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\GPIN) (20210730/utaddress-204)
> [    4.065170] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
> [    4.065178] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
> [    4.065189] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\GPIN) (20210730/utaddress-204)
> [    4.065196] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
> [    4.065202] lpc_ich: Resource conflict(s) found affecting gpio_ich
> [    4.073804] bbswitch: loading out-of-tree module taints kernel.
> [    4.103218] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
> [    4.381634] r8169 0000:0a:00.0: can't disable ASPM; OS doesn't have ASPM control
> [    4.556552] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
> [    4.645274] at24 0-0050: supply vcc not found, using dummy regulator
> [    4.646568] at24 0-0052: supply vcc not found, using dummy regulator
> [    4.743424] snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
> [    4.743440] snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
> [    4.744753] snd_hda_intel 0000:01:00.1: number of I/O streams is 30, forcing separate stream tags
> [    4.745850] Bluetooth: hci0: unexpected event for opcode 0x0000
> [    4.847653] hdaudio hdaudioC1D0: no AFG or MFG node found
> [    4.847665] hdaudio hdaudioC1D1: no AFG or MFG node found
> [    4.847671] hdaudio hdaudioC1D2: no AFG or MFG node found
> [    4.847676] hdaudio hdaudioC1D3: no AFG or MFG node found
> [    4.847684] hdaudio hdaudioC1D4: no AFG or MFG node found
> [    4.847689] hdaudio hdaudioC1D5: no AFG or MFG node found
> [    4.847695] hdaudio hdaudioC1D6: no AFG or MFG node found
> [    4.847700] hdaudio hdaudioC1D7: no AFG or MFG node found
> [    4.847703] snd_hda_intel 0000:01:00.1: no codecs initialized
> [    5.601408] kauditd_printk_skb: 27 callbacks suppressed
> [   14.527290] kauditd_printk_skb: 21 callbacks suppressed
> [  111.487773] sd 6:0:0:0: [sdb] No Caching mode page found
> [  111.487795] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [  282.701734] sd 6:0:0:0: [sdb] No Caching mode page found
> [  282.701741] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [  352.882130] blk_update_request: I/O error, dev sdb, sector 904 op 0x0:(READ) flags 0x84700 phys_seg 30 prio class 0
> [  352.883998] blk_update_request: I/O error, dev sdb, sector 1144 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
> [  352.884192] sd 6:0:0:0: [sdb] tag#0 device offline or changed
> [  352.884207] blk_update_request: I/O error, dev sdb, sector 904 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> [  352.884219] Buffer I/O error on dev sdb1, logical block 97, async page read
> [  352.884382] sd 6:0:0:0: [sdb] tag#0 device offline or changed
> [  352.884390] blk_update_request: I/O error, dev sdb, sector 33888 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
> [  352.884441] sd 6:0:0:0: [sdb] tag#0 device offline or changed
> [  352.884446] blk_update_request: I/O error, dev sdb, sector 33888 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> [  352.884454] Buffer I/O error on dev sdb1, logical block 4220, async page read
> [  355.065518] exFAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
> [  382.751501] blk_update_request: I/O error, dev sdb, sector 8299008 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 0
> [  382.751609] blk_update_request: I/O error, dev sdb, sector 32959 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0
> [  382.751635] Buffer I/O error on dev sdb1, logical block 32831, lost async page write
> [  382.751700] blk_update_request: I/O error, dev sdb, sector 33894 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0
> [  382.751716] Buffer I/O error on dev sdb1, logical block 33766, lost async page write
> [  588.558597] iwlwifi 0000:03:00.0: RF_KILL bit toggled to enable radio.
> [  588.988637] Bluetooth: hci0: unexpected event for opcode 0x0000
> [  604.184076] exFAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
pacman -Qs nvidia
> pacman -Qs nvidia         ✔
> local/bumblebee 3.2.1-22
>     NVIDIA Optimus support for Linux through Primus/VirtualGL
> local/egl-wayland 2:1.1.10-1
>     EGLStream-based Wayland external platform
> local/lib32-libvdpau 1.5-1
>     Nvidia VDPAU library
> local/lib32-nvidia-390xx-utils 390.154-1
>     NVIDIA drivers utilities (32-bit)
> local/libvdpau 1.5-1
> local/libxnvctrl-390xx 390.154-1
>     NVIDIA NV-CONTROL X extension
> local/linux515-nvidia-390xx 390.154-2 (linux515-extramodules)
>     NVIDIA drivers for linux
> local/mhwd-nvidia 515.65.01-2
>     MHWD module-ids for nvidia 515.65.01
> local/mhwd-nvidia-390xx 390.154-1
>     MHWD module-ids for nvidia 390.154
> local/mhwd-nvidia-470xx 470.141.03-1
>     MHWD module-ids for nvidia 470.141.03
> local/nvidia-390xx-utils 390.154-1
> local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
>     Open Source 3D acceleration driver for nVidia cards
i think its related to bbswitch:
also you have this:
also you may have a corrupt drive:
post output from:
pacman -Qs bbswitch
“sdb” is my usb flash drive so it’s not the drive’s fault
pacman -Qs bbswitch output:
> local/linux515-bbswitch 0.8-73 (linux515-extramodules)
>     kernel module allowing to switch dedicated graphics card on Optimus laptops
ok …
remove the bbswitch:
pamac remove linux515-bbswitch
then open this file:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add these 2 parameters:
pci=nommconf pcie_aspm=off
dont remove any parameters, just add these 2 to the existing ones
save the file, update grub: sudo update-grub
kate /etc/environment
and add there this:
QT_LOGGING_RULES='*=false'
it will disable the useless kwin/qt logs
then reboot and check with nvidia-smi
After doing everything: nvidia-smi output
> Tue Aug  9 12:07:10 2022
> | NVIDIA-SMI 390.154                Driver Version: 390.154                   |
> | GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
> | Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
> |   0  GeForce GT 555M     Off  | 00000000:01:00.0 N/A |                  N/A |
> | N/A   45C    P0    N/A /  N/A |      0MiB /  3006MiB |     N/A      Default |
> | Processes:                                                       GPU Memory |
> |  GPU       PID   Type   Process name                             Usage      |
> |    0                    Not Supported                                       |
it has to be because of the bbswitch, there was nothing mentioned in your logs regarding nvidia
post output from:
ls /etc/modprobe.d
> mhwd-bbswitch.conf mhwd-nvidia.conf
post output from:
cat /etc/modprobe.d/mhwd-bbswitch.conf
cat /etc/modprobe.d/mhwd-nvidia.conf
mhwd -li
> ## Generated by mhwd - Manjaro Hardware Detection
> options bbswitch load_state=0 unload_state=0
> blacklist nouveau
> blacklist nvidia
> blacklist nvidia-modeset
> blacklist nvidia-uvm
> blacklist ttm
> blacklist drm_kms_helper
> blacklist drm
mhwd -li
so remove the bbswitch conf:
sudo rm /etc/modprobe.d/mhwd-bbswitch.conf
open this file:
kate /etc/modprobe.d/mhwd-nvidia.conf
and remove these lines:
> blacklist nvidia
save it, and reboot
Nothing has changed the card as it did not work as it still does not work
post output from:
inxi -G && nvidia-smi
> inxi -G && nvidia-smi         ✔
> Graphics:
>   Device-2: NVIDIA GF116M [GeForce GT 555M/635M] driver: N/A
>   Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: intel gpu: i915
>     resolution: 1600x900~60Hz
>     22.1.6
> Tue Aug  9 12:34:46 2022
> | N/A   44C    P0    N/A /  N/A |      0MiB /  3006MiB |     N/A      Default |
> |    0                    Not Supported                                       |
and output from this:
optirun glxgears -info
> [  814.912782] [ERROR]You've no permission to communicate with the Bumblebee daemon. Try adding yourself to the 'bumblebee' group
> [  814.912825] [ERROR]Could not connect to bumblebee daemon - is it running?
it should be with sudo:
sudo optirun glxgears -info
