Background:
Some weeks ago I decided to partition and use a second NVME drive installed inside my machine. Its purpose was to be a data partition for my locally-hosted plex server. It’s just a small plex library that runs whenever my personal computer is on.
I had some initial issues when setting the drive to automount; which you can review from my prior post here.
Problem:
About half of the time when my machine boots, I get a screen about being in emergency mode after (what I believe is the systemd timeout) about 90 seconds of pause. There is a dependency warning message for the swap and plex-library partitions.
I can hit ctrl+D, as suggested, and boot normally past this screen. When I do, the drive is mounted. Functionally, everything works whether I get this emergency mode message or not - the drive will be mounted and working. It’s just an annoyance.
My suspicion is that the plex systemd service starts before the plex-library partition is mounted, and so when the server tries to read data from there it throws the warning. This is just a wild guess on my part. I’m not familiar enough with systemd units and their timing in the early boot process.
I appreciate any help. Let me know if you require any more info. I tried to include everything I thought pertinent.
Logs and System Info
fstab file:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=81864a47-ff36-46cf-9fb6-d0417118e994 / ext4 defaults,noatime 0 1
UUID=D750-671D /boot/efi vfat umask=0077 0 2
UUID=64e43074-1a4f-425f-9855-275995f80048 /mnt/plex-library ext4 defaults 0 2
UUID=a977bcd9-c308-499c-87a9-3a0bf8f15f25 swap swap defaults 0 0
lsblk output:
NAME FSTYPE UUID MOUNTPOINT
sda
└─sda1 linux_raid_member 8a3ffd27-ff57-f853-f262-802225f121fb
└─md127 ext4 873508d2-1ece-40c2-a5bb-02233a5854ec
sdb
└─sdb1 swap a977bcd9-c308-499c-87a9-3a0bf8f15f25 [SWAP]
sdc
└─sdc1 linux_raid_member 8a3ffd27-ff57-f853-f262-802225f121fb
nvme0n1
├─nvme0n1p1 vfat D750-671D /boot/efi
└─nvme0n1p2 ext4 81864a47-ff36-46cf-9fb6-d0417118e994 /
nvme1n1
└─nvme1n1p1 ext4 64e43074-1a4f-425f-9855-275995f80048 /mnt/plex-library
blkid for nvme0n1p2 (i.e. my root partition):
/dev/nvme0n1p2: UUID="81864a47-ff36-46cf-9fb6-d0417118e994" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="a1d50a65-7a9b-0d4a-bd07-824f63bb04d2"
blkid for nvm1n1p1 (i.e. plex-library data partition):
/dev/nvme1n1p1: UUID="64e43074-1a4f-425f-9855-275995f80048" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="plex-library" PARTUUID="c39c33f0-e467-40a4-b00e-59f3d30409e2"
journalctl log from last boot:
May 21 07:46:34 my-comp kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
May 21 07:46:34 my-comp kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
May 21 07:46:34 my-comp kernel: #9 #10 #11 #12 #13 #14 #15
May 21 07:46:34 my-comp kernel: ata2.00: supports DRM functions and may not be fully accessible
May 21 07:46:34 my-comp kernel: ata7.00: supports DRM functions and may not be fully accessible
May 21 07:46:34 my-comp kernel: nvidia: loading out-of-tree module taints kernel.
May 21 07:46:34 my-comp kernel: nvidia: module license 'NVIDIA' taints kernel.
May 21 07:46:34 my-comp kernel: Disabling lock debugging due to kernel taint
May 21 07:46:34 my-comp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.78 Sun Apr 14 06:35:45 UTC 2024
May 21 07:46:34 my-comp kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
May 21 07:46:34 my-comp kernel: VBoxNetAdp: Successfully started.
May 21 07:46:34 my-comp kernel: VBoxNetFlt: Successfully started.
May 21 07:46:34 my-comp systemd-udevd[474]: /etc/udev/rules.d/51-tablet.rules:11 Unknown group 'plugdev', ignoring.
May 21 07:46:34 my-comp systemd-udevd[474]: /etc/udev/rules.d/51-tablet.rules:12 Unknown group 'plugdev', ignoring.
May 21 07:46:34 my-comp systemd-udevd[474]: /etc/udev/rules.d/51-tablet.rules:15 Unknown group 'plugdev', ignoring.
May 21 07:46:34 my-comp systemd-udevd[474]: /etc/udev/rules.d/51-tablet.rules:16 Unknown group 'plugdev', ignoring.
May 21 07:46:34 my-comp systemd-udevd[474]: /etc/udev/rules.d/51-tablet.rules:17 Unknown group 'plugdev', ignoring.
May 21 07:46:35 my-comp kernel: usb 3-2: Warning! Unlikely big volume range (=18944), cval->res is probably wrong.
May 21 07:46:35 my-comp kernel: usb 3-2: [6] FU [Mic Capture Volume] ch = 1, val = -18944/0/1
May 21 07:46:36 my-comp kernel: nvidia-gpu 0000:0a:00.3: i2c timeout error e0000000
May 21 07:46:36 my-comp kernel: ucsi_ccg 1-0008: i2c_transfer failed -110
May 21 07:46:36 my-comp kernel: ucsi_ccg 1-0008: ucsi_ccg_init failed - -110
May 21 07:46:36 my-comp kernel: ucsi_ccg: probe of 1-0008 failed with error -110
May 21 07:48:04 my-comp systemd[1]: dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device: Job dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device/start timed out.
May 21 07:48:04 my-comp systemd[1]: Timed out waiting for device /dev/disk/by-uuid/64e43074-1a4f-425f-9855-275995f80048.
May 21 07:48:04 my-comp systemd[1]: Dependency failed for File System Check on /dev/disk/by-uuid/64e43074-1a4f-425f-9855-275995f80048.
May 21 07:48:04 my-comp systemd[1]: Dependency failed for /mnt/plex-library.
May 21 07:48:04 my-comp systemd[1]: Dependency failed for Local File Systems.
May 21 07:48:04 my-comp systemd[1]: dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device: Job dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device/start timed out.
May 21 07:48:04 my-comp systemd[1]: Timed out waiting for device /dev/disk/by-uuid/a977bcd9-c308-499c-87a9-3a0bf8f15f25.
May 21 07:48:04 my-comp systemd[1]: Dependency failed for /dev/disk/by-uuid/a977bcd9-c308-499c-87a9-3a0bf8f15f25.
May 21 07:48:04 my-comp systemd[1]: Dependency failed for Swaps.
May 21 07:48:04 my-comp systemd-coredump[936]: [🡕] Process 527 (ddcutil) of user 0 dumped core.
Stack trace of thread 527:
#0 0x00007f605cef909d n/a (libc.so.6 + 0x16309d)
#1 0x0000560921260031 strsplit (ddcutil + 0x8b031)
#2 0x00005609212724ba n/a (ddcutil + 0x9d4ba)
#3 0x0000560921272778 is_possible_monitor_by_hiddev_name (ddcutil + 0x9d778)
#4 0x00005609212728a9 check_usb_monitor (ddcutil + 0x9d8a9)
#5 0x00005609211f0752 main (ddcutil + 0x1b752)
#6 0x00007f605cdbbd4a n/a (libc.so.6 + 0x25d4a)
#7 0x00007f605cdbbe0c __libc_start_main (libc.so.6 + 0x25e0c)
#8 0x00005609211f0895 _start (ddcutil + 0x1b895)
May 21 07:48:04 my-comp (udev-worker)[519]: hiddev4: Process '/usr/bin/ddcutil chkusbmon /dev/usb/hiddev4 -v' terminated by signal SEGV.
May 21 07:48:04 my-comp (udev-worker)[519]: hiddev4: Failed to wait for spawned command '/usr/bin/ddcutil chkusbmon /dev/usb/hiddev4 -v': Input/output error
May 21 07:48:04 my-comp kernel: iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
May 21 07:48:05 my-comp kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
May 21 07:48:05 my-comp systemd[1]: mdmonitor.service: Failed with result 'exit-code'.
May 21 07:49:55 my-comp systemd[1]: snapd.service: Got notification message from PID 1491, but reception only permitted for main PID 1442
May 21 07:49:55 my-comp systemd[1]: snapd.service: Got notification message from PID 1512, but reception only permitted for main PID 1442
May 21 07:49:55 my-comp systemd[1]: snapd.service: Got notification message from PID 1586, but reception only permitted for main PID 1442
May 21 07:49:55 my-comp systemd[1]: snapd.service: Got notification message from PID 1593, but reception only permitted for main PID 1442
May 21 07:49:55 my-comp kernel: kauditd_printk_skb: 58 callbacks suppressed
May 21 07:49:55 my-comp systemd[1]: Cannot find unit for notify message of PID 1743, ignoring.
May 21 07:49:57 my-comp dbus-broker-launch[1433]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
May 21 07:49:57 my-comp dbus-broker-launch[3766]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
May 21 07:49:57 my-comp dbus-broker-launch[3766]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 21 07:49:57 my-comp dbus-broker-launch[3766]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 21 07:49:58 my-comp sddm-greeter-qt6[3762]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.26'
May 21 07:49:58 my-comp sddm-greeter-qt6[3762]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
May 21 07:50:00 my-comp dbus-broker-launch[1433]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
May 21 07:50:06 my-comp sddm-greeter-qt6[3762]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
May 21 07:50:06 my-comp systemd-xdg-autostart-generator[4169]: Configuration file /home/my-user/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
May 21 07:50:07 my-comp dbus-broker-launch[4195]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
May 21 07:50:07 my-comp dbus-broker-launch[4195]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 21 07:50:07 my-comp dbus-broker-launch[4195]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 21 07:50:07 my-comp systemd-xdg-autostart-generator[4207]: Configuration file /home/my-user/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
May 21 07:50:07 my-comp kded6[4262]: org.kde.wacomtablet.common: d->name.isEmpty? true
May 21 07:50:07 my-comp kded6[4262]: kf.coreaddons: The plugin "/usr/lib/qt6/plugins/kaccounts/daemonplugins/kaccounts_kio_webdav_plugin.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
May 21 07:50:07 my-comp kded6[4262]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
May 21 07:50:07 my-comp kded6[4262]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
May 21 07:50:07 my-comp plasmashell[4276]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
May 21 07:50:07 my-comp plasmashell[4276]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
May 21 07:50:07 my-comp ksplashqml[4199]: Texture 0x7f452c722200 () used with different accesses within the same pass, this is not allowed.
May 21 07:50:07 my-comp ksplashqml[4199]: Texture 0x55e70db0d880 () used with different accesses within the same pass, this is not allowed.
May 21 07:50:07 my-comp ksplashqml[4199]: Texture 0x7f451471afc0 () used with different accesses within the same pass, this is not allowed.
May 21 07:50:08 my-comp plasmashell[4276]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
May 21 07:50:08 my-comp plasmashell[4276]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
May 21 07:50:08 my-comp plasmashell[4276]: kf.coreaddons: The plugin "/usr/lib/qt6/plugins/plasma5support/dataengine/plasma_engine_wacomtablet.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/kleopatra.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp kconf_update[4369]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
May 21 07:50:08 my-comp backlighthelper[4386]: org.kde.powerdevil: no kernel backlight interface found
May 21 07:50:08 my-comp org_kde_powerdevil[4315]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
May 21 07:50:08 my-comp org_kde_powerdevil[4315]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
May 21 07:50:08 my-comp org_kde_powerdevil[4315]: busno=9. Monitor apparently returns -EIO for unsupported features. This cannot be relied on.
May 21 07:50:09 my-comp kded6[4262]: kscreen.kded: PowerDevil SuspendSession action not available!
May 21 07:50:09 my-comp plasmashell[4276]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
May 21 07:50:10 my-comp org_kde_powerdevil[4315]: org.kde.powerdevil: Handle button events action could not check for screen configuration
May 21 07:50:10 my-comp org_kde_powerdevil[4315]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
May 21 07:50:10 my-comp plasmashell[4276]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
May 21 07:50:11 my-comp pipewire-media-session[4415]: spa.bluez5: BlueZ system service is not available
May 21 07:50:13 my-comp plasmashell[4276]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
May 21 07:50:13 my-comp plasmashell[4276]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
May 21 07:50:13 my-comp plasmashell[4276]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:22:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
May 21 07:50:13 my-comp plasmashell[4276]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
May 21 07:50:13 my-comp plasmashell[4276]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
May 21 07:50:14 my-comp plasmashell[4276]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
May 21 07:50:15 my-comp plasmashell[4276]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:62:17: Unable to assign [undefined] to int
May 21 07:50:16 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/index.xml")
May 21 07:50:16 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/index.xml")
May 21 07:50:16 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://www.weather.gov/xml/current_obs/KFWS.xml")
May 21 07:50:17 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 07:50:17 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 07:50:18 my-comp plasmashell[4276]: file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/SwitchPanel.qml:46:5: QML TabBar: Binding loop detected for property "implicitWidth"
May 21 07:50:24 my-comp plasmashell[4276]: kf.coreaddons: The plugin "/usr/lib/qt6/plugins/plasma5support/dataengine/plasma_engine_wacomtablet.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
May 21 07:51:55 my-comp baloo_file_extractor[5585]: kf.idletime: Could not find any system poller plugin
May 21 07:51:55 my-comp baloo_file_extractor[5585]: qt.core.qobject.connect: QObject::connect(KAbstractIdleTimePoller, KIdleTime): invalid nullptr parameter
May 21 07:51:58 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 07:52:35 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 07:52:55 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 07:54:55 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 07:58:08 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:01:24 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:01:27 my-comp plasmashell[4276]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
May 21 08:01:28 my-comp plasmashell[4276]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
May 21 08:01:29 my-comp plasmashell[4276]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
May 21 08:01:30 my-comp plasmashell[4276]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
May 21 08:01:34 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:02:39 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:03:03 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:03:39 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:03:49 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:20:20 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://www.weather.gov/xml/current_obs/KFWS.xml")
May 21 08:20:20 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 08:20:20 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 08:50:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://www.weather.gov/xml/current_obs/KFWS.xml")
May 21 08:50:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 08:50:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 08:59:41 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 08:59:42 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 09:20:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://www.weather.gov/xml/current_obs/KFWS.xml")
May 21 09:20:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 09:20:16 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 09:50:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://www.weather.gov/xml/current_obs/KFWS.xml")
May 21 09:50:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 09:50:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 09:50:16 my-comp plasmashell[4276]: file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/SwitchPanel.qml:46:5: QML TabBar: Binding loop detected for property "implicitWidth"
May 21 10:04:04 my-comp systemd-xdg-autostart-generator[7669]: Configuration file /home/my-user/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
May 21 10:04:05 my-comp (uetoothd)[7707]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support bap plugin
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support bass plugin
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support mcp plugin
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support vcp plugin
May 21 10:04:05 my-comp bluetoothd[7707]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support micp plugin
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support ccp plugin
May 21 10:04:05 my-comp bluetoothd[7707]: src/plugin.c:init_plugin() System does not support csip plugin
May 21 10:06:41 my-comp plasmashell[4276]: kf.coreaddons: The plugin "/usr/lib/qt6/plugins/plasma5support/dataengine/plasma_engine_wacomtablet.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
May 21 10:20:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://www.weather.gov/xml/current_obs/KFWS.xml")
May 21 10:20:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("http://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 10:20:15 my-comp plasmashell[4276]: kf.kio.core: mimetype() emitted again, or after sending first data!; job URL = QUrl("https://w1.weather.gov/xml/current_obs/KFWS.xml")
May 21 10:22:07 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 10:22:09 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 10:22:22 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
May 21 10:22:28 my-comp kglobalacceld[4218]: kf.windowsystem.keyserver.x11: Your keyboard setup doesn't provide a key to use for meta. See 'xmodmap -pm' or 'xkbcomp $DISPLAY'
journalctl I piped to file from chroot in emergency mode. This was taken about a week ago, but is representative of the same message I’m getting today:
A start job for unit systemd-repart.service has finished successfully.
░░ The job identifier is 404.
May 11 18:53:31 my-comp systemd[1]: dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device: Job dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device/start timed out.
May 11 18:53:31 my-comp systemd[1]: Timed out waiting for device /dev/disk/by-uuid/64e43074-1a4f-425f-9855-275995f80048.
░░ Subject: A start job for unit dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device has failed
░░ Defined-By: systemd
░░ A start job for unit dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device has finished with a failure.
░░ The job identifier is 82 and the job result is timeout.
May 11 18:53:31 my-comp systemd[1]: Dependency failed for /mnt/plex-library.
░░ Subject: A start job for unit mnt-plex\x2dlibrary.mount has failed
░░ A start job for unit mnt-plex\x2dlibrary.mount has finished with a failure.
░░ The job identifier is 80 and the job result is dependency.
May 11 18:53:31 my-comp systemd[1]: Dependency failed for Local File Systems.
░░ Subject: A start job for unit local-fs.target has failed
░░ A start job for unit local-fs.target has finished with a failure.
░░ The job identifier is 75 and the job result is dependency.
May 11 18:53:31 my-comp systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'.
May 11 18:53:31 my-comp systemd[1]: local-fs.target: Triggering OnFailure= dependencies.
May 11 18:53:31 my-comp systemd[1]: mnt-plex\x2dlibrary.mount: Job mnt-plex\x2dlibrary.mount/start failed with result 'dependency'.
May 11 18:53:31 my-comp systemd[1]: Dependency failed for File System Check on /dev/disk/by-uuid/64e43074-1a4f-425f-9855-275995f80048.
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.service has failed
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.service has finished with a failure.
░░ The job identifier is 81 and the job result is dependency.
May 11 18:53:31 my-comp systemd[1]: systemd-fsck@dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.service: Job systemd-fsck@dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.service/start failed with result 'dependency'.
May 11 18:53:31 my-comp systemd[1]: dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device: Job dev-disk-by\x2duuid-64e43074\x2d1a4f\x2d425f\x2d9855\x2d275995f80048.device/start failed with result 'timeout'.
May 11 18:53:31 my-comp systemd[1]: dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device: Job dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device/start timed out.
May 11 18:53:31 my-comp systemd[1]: Timed out waiting for device /dev/disk/by-uuid/a977bcd9-c308-499c-87a9-3a0bf8f15f25.
░░ Subject: A start job for unit dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device has failed
░░ A start job for unit dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device has finished with a failure.
░░ The job identifier is 69 and the job result is timeout.
May 11 18:53:31 my-comp systemd[1]: Dependency failed for /dev/disk/by-uuid/a977bcd9-c308-499c-87a9-3a0bf8f15f25.
░░ Subject: A start job for unit dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.swap has failed
░░ A start job for unit dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.swap has finished with a failure.
░░ The job identifier is 68 and the job result is dependency.
May 11 18:53:31 my-comp systemd[1]: Dependency failed for Swaps.
░░ Subject: A start job for unit swap.target has failed
░░ A start job for unit swap.target has finished with a failure.
░░ The job identifier is 67 and the job result is dependency.
May 11 18:53:31 my-comp systemd[1]: swap.target: Job swap.target/start failed with result 'dependency'.
May 11 18:53:31 my-comp systemd[1]: dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.swap: Job dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.swap/start failed with result 'dependency'.
May 11 18:53:31 my-comp systemd[1]: dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device: Job dev-disk-by\x2duuid-a977bcd9\x2dc308\x2d499c\x2d87a9\x2d3a0bf8f15f25.device/start failed with result 'timeout'.
