Dragging files from desktop into desktop-folders copies instead of moves
Ive noticed that when I drag a file FROM desktop, INTO a folder that is on the desktop : the file gets copied rather than moved.
I can drag a file FROM any folder, TO the desktop & it ‘moves’ correctly.
SO, for example:
  • Create a folder on desktop & place a file inside.
  • Open the folder & drag the file to the desktop. The file is moved to the desktop. :white_check_mark:
  • Drag the file back to the folder = a copy is created. :warning:
This only applies to folders (or folder aliases) on the desktop, Dragging from desktop to /Pictures works as expected (move)
What’s all that about?
Manjaro 21.1, Gnome 40.4
It works properly on Cinnamon
Short explanation:
  1. If you drag and drop a file/folder within a partition, then it will be moved.
  2. If you drag and drop a file/folder from one partition to another, then it will be copied.
I believe it is is the same behavior on any OS.
Yes, I understand those 2 points, that’s normal.
However my topic is not across partitions, its just in & out of any folder on the desktop.
& its not even both directions, 1 direction is copy & the other is move.
Ah ok… then note this:
  1. Gnome removed Desktop Icons completely on the stock release.
  2. I guess you added (or it was preinstalled?) an extension to extend this functionality on the gnome desktop.
I guess it this extension: Desktop Icons NG (DING) - GNOME Shell Extensions
Here you report an Issue: Issues · Rastersoft / Desktop Icons NG · GitLab
Here is the functionality of “Drag&Drop”: Files · master · Rastersoft / Desktop Icons NG · GitLab As you might see, it uses a Dbus to communicate with nautilus.
Since this is at alpha state, expect bugs like this:
Desktop Icons NG for GNOME Shell. It is a fork/rewrite of the official ‘Desktop Icons’ extension, with these advantages:
  • Drag’n’Drop, both inside the desktop, between desktop and applications, and nautilus windows
  • Allows to use “Open with…” option with several files
  • When hovering or clicking on an icon with a name too large to fit, it shows the full name
  • Doesn’t hang the compositor when there is too much activity in the desktop folder
But it is still an alpha development, so it probably still have a lot of bugs. Use with care.
Thank you @megavolt . I think this must be the issue!
I checked using Nautilus windows only, & then I can drag between [desktop & desktop-folder] without files copying, as long as I do so inside nautilus.
So, it seems very likely DING is causing this bug, as you noted.
Great answer. I appreciate your knowledge & time to reply & helpful links.
It makes me feel relieved knowing the explanation for this, rather than worrying that I have done something to cause it. :+1: Have a great day.
