I have a bottom panel with Icons only task manager and visibility of panel set to “Dodge windows”
I recently switched to plasma6 and wayland session and the issue now is that I cannot drag and drop a file to one of an application currently open in task manager (below) when dragging file from dolphin (as my panel is hidden) even reaching the panel with cursor doesnt work.
This is the issue only when I am dragging a file, it works normally and becomes visible if i take my cursor directly there without a file being dragged.
*You can see in this image i am trying to reach to panel but its not un-hiding
