Hello,
It seems a manjaro update (2-3 months ago) made power save for monitor not working anymore.
I have Cinnamon, and never had this problem.
When I set “Turn off the screen when inactive for …” 5 minutes, the screen turns black 2-3 seconds, then wake up again.
I search plenty of help in many forums, manjaro, archlinux, cinnamon, xorg.conf, xset dpms, … nothing works.
I booted with a fresh manjaro cinnamon live usb : after 5 minutes, only screensaver is launching. No power save.
But with a linuxmint cinnamon live usb, it worked as expected : black screen after 5 minutes, then screen wake up only after I moved the mouse.
Any idea ?
Thanks
assuming you are on X11
query to find your current configuration;
$ xset q
also get;
$ inxi -Gazy
refer;
https://wiki.archlinux.org/title/Display_Power_Management_Signaling
Thanks for you suggestion, but I already tried it, and it doesn’t work …
I’ve got the same problem.
When I do a sleep 1; xset dpms force off
, screen goes blank, but after a couple of seconds, it wakes up again.
My system information:
System information
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 off: DP-3 empty: DP-1,DP-2 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-3 mapped: DisplayPort-2 note: disabled
model: EIZO NANAO EV2313W serial: built: 2011 res: N/A dpi: 96
gamma: 1.2 size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9
modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary
model: Idek Iiyama PL3493WQ serial: built: 2020 res: 3440x1440
hz: 75 dpi: 109 gamma: 1.2 size: 800x345mm (31.5x13.58")
diag: 871mm (34.3") modes: max: 3440x1440 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.56 6.7.0-4-MANJARO) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.274 layers: 2 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:73df surfaces: xcb,xlib
