DP monitor sound
Hello all,
thank you for manjaro!
I have three monitors - all with speakers - connected to an nVidia graphics card via display port. Now there is the following situation in gnome settings:
  • monitor 1 always has sound
  • monitor 2 and 3 only have sound when I power off the other monitor, respectively
Please let me know how to fix this!
Best regards
Gerrit
Can you switch output between monitor 2 and 3 in the audio settings?
… It will help if you provide a bit of system info: inxi -zv8 (use the </> button to format it so it appears in a scrollable box).
Then we’ll know e.g. if you are using PulseAudio or Pipewire etc. .
Same probably for output of pactl list sinks … may help. (Disclaimer: I’m no expert on audio stuff like this, though there are some very knowledgeable members here in this regard).
   ~  inxi -zv8         ✔  21s   
  Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=319bf7d3-8a5c-4792-8db7-4df6981a2bbc rw quiet splash apparmor=1
    security=apparmor resume=UUID=fc9e3ee8-7dee-416a-a1ec-e6d6b877967c
    udev.log_priority=3 nvidia-drm.modeset=1
  Desktop: GNOME v: 46.5 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
    base: Arch Linux
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
    UEFI: American Megatrends v: 4805 date: 03/18/2024
  System RAM: total: 64 GiB available: 62.7 GiB used: 15.39 GiB (24.5%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMD32GX4M2C3200C16 serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    part-no: CMD32GX4M2B3000C15 serial: N/A
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
    desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2200 min/max: 2200/5083 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
    29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 217673
    xsaves
    affected
  Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ZOTAC driver: nvidia
    v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-1,DP-2,DP-3
    empty: HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 10de:2684 class-ID: 0300
  Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.1:3
    chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 11520x2160 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right
    model: Philips PHL 329P1 serial: <filter> built: 2022 res: 3840x2160 hz: 60
    dpi: 140 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green: x: 0.286
    y: 0.659 blue: x: 0.153 y: 0.039 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 3840x2160, 1920x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x960, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  Monitor-2: DP-2 note: disabled pos: center model: Gigabyte AORUS FO32U2P
    serial: <filter> built: 2024 res: 3840x2160 dpi: 141 gamma: 1.2 chroma: red:
    x: 0.686 y: 0.306 green: x: 0.243 y: 0.710 blue: x: 0.141 y: 0.055 white:
    x: 0.314 y: 0.329 size: 690x390mm (27.17x15.35") diag: 793mm (31.2")
    ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768,
    1440x480, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 117 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95 6: parse_edid:
    unhandled CEA mode 96 7: parse_edid: unknown tag 112
  Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left
    model: Acer XV322QK KV serial: <filter> built: 2022 res: 3840x2160 dpi: 139
    gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green: x: 0.271 y: 0.627 blue:
    x: 0.145 y: 0.051 white: x: 0.314 y: 0.329 size: 700x390mm (27.56x15.35")
    diag: 800mm (31.5") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
    1680x1050, 1280x1024, 1440x900, 1280x960, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
    unhandled CEA mode 118 3: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
    memory: 23.43 GiB
  Device-1: NVIDIA AD102 High Definition Audio vendor: ZOTAC
    bus-ID: 0c:00.1 chip-ID: 10de:22ba class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
    10G] vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:07b1 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  IF: enp7s0 state: down mac: <filter>
  Device-4: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp8s0 state: up mac: <filter>
  Device-5: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.1.1:13
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp9s0f1u3u1u1 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 5.87 TiB used: 2.79 TiB (47.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 PRO 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B6QCXP7 temp: 43.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Lexar model: SSD NM790 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 53.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4 size: 238.47 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 1.5 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Generic model: STORAGE DEVICE
    size: 999.02 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 1532 scheme: MBR
  ID-1: / raw-size: 3.66 TiB size: 3.6 TiB (98.40%) used: 1.73 TiB (48.1%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6 label: N/A
    uuid: 319bf7d3-8a5c-4792-8db7-4df6981a2bbc
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5 label: N/A
    uuid: 1B4B-4B52
  ID-3: /mnt/data raw-size: 952.65 GiB size: 936.63 GiB (98.32%)
    used: 885 GiB (94.5%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: ac045e9d-3702-464e-b302-e3f3272276ee
  ID-4: /mnt/data2 raw-size: 237.5 GiB size: 232.71 GiB (97.98%)
    used: 203.98 GiB (87.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 5ee340bd-d824-4be0-9bf9-ca6b25e2cd31
  ID-1: swap-1 type: partition size: 68.98 GiB used: 1024 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:7 label: swap
    uuid: fc9e3ee8-7dee-416a-a1ec-e6d6b877967c
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
    uuid: C03F-3115
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 732 MiB fs: ext4 label: N/A
    uuid: 127196f1-376c-432a-a3ce-482b654b06f9
  ID-3: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
    uuid: 8CF4-A3A8
  ID-4: /dev/sda2 maj-min: 8:2 size: 488 MiB fs: ext2 label: N/A
    uuid: 1134c2dc-a524-44e1-bb1a-5aa54c90e38e
  ID-5: /dev/sdc1 maj-min: 8:33 size: 999.02 GiB fs: vfat label: N/A
    uuid: F6CD-5F81
  Hub-2: 1-1:15 info: Realtek RTS5411 Hub ports: 6 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 1-1.3:16 info: Integrated Express ITE Device(8595)
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8295 class-ID: 0301
  Device-2: 1-1.6:17 info: Realtek HID Device type: HID
    chip-ID: 0bda:1100 class-ID: 0300
  Hub-3: 1-3:2 info: ATEN USB2.1 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0557:5411
  Hub-4: 1-3.1:12 info: Fresco Logic USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d5c:5012
  Device-1: 1-3.1.1:13 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
  Device-2: 1-3.1.2:14 info: Genesys Logic SD Card Reader and Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
    chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
  Hub-5: 1-3.3:6 info: ATEN Hub ports: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0557:8021 class-ID: 0900
  Device-1: 1-3.3.1:8 info: ATEN CS1942DP_1944DP type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0557:2200 class-ID: 0301
  Hub-6: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5.3:7 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Device-2: 1-6:5 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-7: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 2-3:3 info: Realtek Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-9: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-10: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-5:3 info: STMicro Solo 4.1.2 type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0483:a2ca class-ID: 0300
    serial: <filter>
  Hub-11: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-12: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-13: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-14: 5-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 5-3.1:3 info: Logitech Webcam C930e type: video,audio
  Device-2: 5-3.2:4 info: Ultra-Link 8K type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0
    chip-ID: 362d:d028 class-ID: 0300
  Device-3: 5-3.3:5 info: Keychron Q0 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0130 class-ID: 0300
    serial: <filter>
  Device-4: 5-3.4:6 info: Keychron Q3 keychron/q3/iso_encoder
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 3434:0123 class-ID: 0300 serial: <filter>
  Hub-15: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 47.0 C mobo: 38.0 C gpu: nvidia temp: 50 C
  Fan Speeds (rpm): cpu: 0 gpu: nvidia fan: 0%
  Packages: 1893 pm: pacman pkgs: 1856 libs: 496
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 37
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    3: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    6: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    7: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 640
  1: cpu: 12.5% command: tracker-extract-3 pid: 162172 mem: 31.5 MiB (0.0%)
  2: cpu: 9.6% command: vivaldi-bin pid: 154403 mem: 399.7 MiB (0.6%)
  3: cpu: 7.2% command: vivaldi-bin pid: 161629 mem: 315.9 MiB (0.4%)
  4: cpu: 4.5% command: gnome-shell pid: 1466 mem: 911.6 MiB (1.4%)
  5: cpu: 3.2% command: vivaldi-bin pid: 4377 mem: 1232.9 MiB (1.9%)
  Memory top: 5 of 640
  1: mem: 1392.7 MiB (2.1%) command: thunderbird pid: 119238 cpu: 2.8%
  2: mem: 1232.9 MiB (1.9%) command: vivaldi-bin pid: 4377 cpu: 3.2%
  3: mem: 1065.3 MiB (1.6%) command: vivaldi-bin pid: 3078 cpu: 1.3%
  4: mem: 911.6 MiB (1.4%) command: gnome-shell pid: 1466 cpu: 4.5%
  5: mem: 769.6 MiB (1.1%) command: ./jetbrains-toolbox pid: 1696 cpu: 0.2%
  Processes: 640 Power: uptime: 15h 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.04 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
    running-in: terminator inxi: 3.3.36
   ~  pactl list sinks         ✔  
Sink #57
	State: IDLE
	Description: Starship/Matisse HD Audio Controller Analog Stereo
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 26241 /  40% / -23,85 dB,   front-right: 26241 /  40% / -23,85 dB
	        balance 0,00
	Base Volume: 65536 / 100% / 0,00 dB
	Monitor Source: alsa_output.pci-0000_0e_00.4.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "1"
		alsa.card_name = "HD-Audio Generic"
		alsa.class = "generic"
		alsa.components = "HDA:10ec1220,104387c4,00100101"
		alsa.device = "0"
		alsa.id = "Generic"
		alsa.long_card_name = "HD-Audio Generic at 0xfc500000 irq 145"
		alsa.mixer_name = "Realtek ALC1220"
		alsa.name = "ALC1220 Analog"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.sync.id = "00000000:00000000:00000000:00000000"
		api.alsa.card.longname = "HD-Audio Generic at 0xfc500000 irq 145"
		api.alsa.card.name = "HD-Audio Generic"
		api.alsa.path = "front:1"
		api.alsa.pcm.card = "1"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "5"
		device.api = "alsa"
		device.class = "sound"
		device.id = "51"
		device.profile.description = "Analog Stereo"
		device.profile.name = "analog-stereo"
		device.routes = "2"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		device.description = "Starship/Matisse HD Audio Controller"
		node.name = "alsa_output.pci-0000_0e_00.4.analog-stereo"
		node.nick = "ALC1220 Analog"
		node.pause-on-idle = "false"
		object.path = "alsa:acp:Generic:5:playback"
		port.group = "playback"
		priority.driver = "1009"
		priority.session = "1009"
		factory.id = "19"
		clock.quantum-limit = "8192"
		client.id = "47"
		node.driver = "true"
		node.loop.name = "data-loop.0"
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "57"
		object.serial = "57"
		node.max-latency = "16384/48000"
		api.alsa.period-size = "1024"
		api.alsa.period-num = "32"
		api.alsa.headroom = "0"
		api.acp.auto-port = "false"
		api.alsa.card = "1"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1 = "Audio1"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.bus = "pci"
		device.bus_path = "pci-0000:0e:00.4"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_0e_00.4"
		device.nick = "HD-Audio Generic"
		device.plugged.usec = "10637582"
		device.product.id = "0x1487"
		device.product.name = "Starship/Matisse HD Audio Controller"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1"
		device.vendor.id = "0x1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		device.string = "1"
	Ports:
		analog-output-lineout: Line-Ausgang (type: Line, priority: 9000, availability group: Legacy 4, available)
		analog-output-headphones: Kopfhörer (type: Headphones, priority: 9900, availability group: Legacy 5, not available)
	Active Port: analog-output-lineout
	Formats:
		pcm
Sink #573
	State: IDLE
	Description: AD102 High Definition Audio Controller Digital Stereo (HDMI)
	Driver: PipeWire
	Mute: no
	Volume: front-left: 38012 /  58% / -14,19 dB,   front-right: 38012 /  58% / -14,19 dB
	        balance 0,00
	Monitor Source: alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor
	Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
	Properties:
		alsa.card = "0"
		alsa.card_name = "HDA NVidia"
		alsa.components = "HDA:10de00a3,19da1675,00100100"
		alsa.device = "3"
		alsa.id = "NVidia"
		alsa.long_card_name = "HDA NVidia at 0xfb080000 irq 143"
		alsa.mixer_name = "Nvidia GPU a3 HDMI/DP"
		alsa.name = "PHL 329P1"
		api.alsa.card.longname = "HDA NVidia at 0xfb080000 irq 143"
		api.alsa.card.name = "HDA NVidia"
		api.alsa.path = "hdmi:0"
		api.alsa.pcm.card = "0"
		card.profile.device = "4"
		device.api = "alsa"
		device.id = "49"
		device.profile.description = "Digital Stereo (HDMI)"
		device.profile.name = "hdmi-stereo"
		device.routes = "1"
		device.description = "AD102 High Definition Audio Controller"
		node.name = "alsa_output.pci-0000_0c_00.1.hdmi-stereo"
		node.nick = "PHL 329P1"
		object.path = "alsa:acp:NVidia:4:playback"
		priority.driver = "696"
		priority.session = "696"
		factory.id = "19"
		client.id = "47"
		object.id = "87"
		object.serial = "573"
		api.alsa.card = "0"
		device.bus = "pci"
		device.bus_path = "pci-0000:0c:00.1"
		device.name = "alsa_card.pci-0000_0c_00.1"
		device.nick = "HDA NVidia"
		device.plugged.usec = "10605803"
		device.product.id = "0x22ba"
		device.product.name = "AD102 High Definition Audio Controller"
		sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0"
		device.vendor.id = "0x10de"
		device.vendor.name = "NVIDIA Corporation"
		device.string = "0"
	Ports:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
	Active Port: hdmi-output-0
	Formats:
		pcm
Thanks!
For this, it looks like you have one monitor actually running on an analogue source and the other(s) running on HDMI audio source, but I could be mistaken here.
My suspicion is that the HDMI audio has only one possible (stereo) audio output channel. Not sure if Jack or Wireplumber could fix that? A bit like my old Dell machine having only 2 “pipes” for graphics? Although I wouldn’t think that to be the case with a decent graphics card? :thinking:
It looks like the primary monitor is the one using the analogue source.
Hopefully someone who knows more about this than I do will see this!
All three monitors are connected via DP. The silent one is new and has DP mini.
I have three audio devices for HDMI/Display Port output in gnome settings, one of them not working properly…
It could be a hardware limitation (I hope not); I guess something to try would be to spin up a Live session of one of the other DEs (Plasma or Xfce)? See if the results are the same there. Particularly Plasma, as I’d be in a better position to show where the settings are.
Will do…
inxi shows 3 monitors connected to system
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right model: Philips PHL 329P1
Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left model: Acer XV322QK
pactl list sinks shows only one HDMI output sink available
Sink #573
	State: IDLE
  Ports:
Please post more information about audio devices in PipeWire to show if the other two HDMI sinks are available
pactl list cards
in the meantime sometimes all three monitor audio do work. Sometimes only one monitor audio works…
Still an issue: monitor one is the only audio sink
Nvidia proprietary drivers issue?
Nvidia proprietary drivers are for graphical display
    v: 550.120
HDMI audio uses Linux audio driver snd_hda_intel
Sink #573
	Properties:
		alsa.card = "0"
		alsa.device = "3"
		alsa.id = "NVidia"
System would usually play audio to one HDMI sink output, but audio GUI controls should allow user to change the card profile to use another output
Please post more information about card profiles
pactl list cards
Or an intermittent connection — in other words, a hardware issue.
Several years ago, I had a brand-new computer whereby most of the time I would only get sound out of one speaker, and only sometimes out of both speakers. The shop replaced the motherboard under warranty, and the problem never returned.
If there is an intermittent HDMI audio connection pactl list cards would show the corresponding output:hdmi-stereo Profile as available: no
