DP hot-replug never re-trains link on X11
  • Driver: [575.xx], proprietary, nvidia-drm.modeset=1, fbdev=1
  • Kernel: [6.x.x-arch], X11 (no display manager issues — bspwm/sxhkd)
  • Monitors: 2× 2560x1440@180Hz over DisplayPort (DP-0, DP-2)
Steps to reproduce:
  1. Boot to X11, both monitors active at 2560x1440@180
  2. Unplug the DP cable of one monitor
  3. Wait ~10 s, plug it back in
Expected: link re-trains, signal returns.
Actual: monitor stays black indefinitely. Signal only returns after a forced modeset:
xrandr --output DP-0 --off && xrandr --output DP-0 --auto
Diagnostics performed:
  • udevadm monitor --kernel --udev during replug: zero events emitted — the hotplug never reaches userspace, so no udev-based workaround is possible
  • Reproduces with and without ConnectedMonitor/CustomEDID pinning in xorg.conf
report generated by fable 5
Please post more information about system:
inxi -v8z
for nVidia GPU it is suggested to check configuration in nvidia-settings
Configure X Screen settings (OpenGL Settings, Antialiasing, X Server XVideo) - Manjaro Wiki
Quality information. No AI generated posts - Forum Rules
In a community oriented software project like Manjaro, we want to provide quality information. Therefore we expect everybody to verify their proposals or make it clear that it’s a guess. That’s why a post generated by an AI and not verified by the poster has to be considered inaccurate…
If you verified a proposal from an AI yourself then you can also write the post in your own words.
