Hello everyone I have wifi connection and speed is 20 mbps. It works fine during download etc. But I can not connect to somewebsites or it takes significant time to connect. Myphone is also connected to the same wifi I have not such issue.
Systemd resolver
Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
resolv.conf mode: foreign
Current DNS Server: 192.168.3.254
DNS Servers: 192.168.3.254
Fallback DNS Servers: 1.1.1.1#cloudflare-dns.com 9.9.9.9#dns.quad9.net
8.8.8.8#dns.google 2606:4700:4700::1111#cloudflare-dns.com
2620:fe::9#dns.quad9.net 2001:4860:4860::8888#dns.google
DNS Domain: Wireless-N
networkctl status -all
systemd-networkd is not running, output might be incomplete.
Failed to query link bit rates: Could not activate remote peer: activation requ>
Failed to query link DHCP leases: Could not activate remote peer: activation re>
â—Ź 1: lo
Link File: n/a
Network File: n/a
State: n/a (unmanaged)
Online state: unknown
Type: loopback
Hardware Address: 00:00:00:00:00:00
MTU: 65536
QDisc: noqueue
IPv6 Address Generation Mode: eui64
Number of Queues (Tx/Rx): 1/1
Address: 127.0.0.1
::1
yes it is 127.0.0.1 so can you explain me whay we’ve done here and also is this aproblem ```
My guess is that the problem is a crappy DNS server on the router. I don’t why your phone works ok with it, perhaps you changed DNS servers on that in the past? You can manually set DNS servers for your connection like this;
I think Android uses a Google-powered DoH server (If I recall that correctly) for DNS, unless you change and customize it. So it might be that. I don’t know if it’s the same for iOS or not.
As far as I know, by default Manjaro uses NetworkManager and resolvconf. But I don’t know other than knowing your system. (In this case, the defaults. Don’t worry, I’m using the defaults myself.)
