Downgrading and downscaling from 3840*2160 to 1920*1080 => wrong sized menus and windows
Hello,
I have a 27" screen, and have to switch regularly between resolutions.
In 4k the menus and fonts were unreadable, too small. I had to use the force DPI option, that was at 96. The option box it is now unticked.
I’m now in HD, and the menus are enormous. I tried to look at global scaling again, but it doesn’t permit to reduce, only increase the scale (no value below the 100% of the current situation.
How can I get this to work?
Edit.: the “hide” bbcode thing is failing for me. An error?
[hide=inxi --admin --verbosity=7 --filter --no-host --width]System:
Kernel: 5.12.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=e81ee2fe-5bf4-43d1-b4b7-d19895f827b4 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: MAXIMUS V FORMULA v: Rev 1.xx
serial: BIOS: American Megatrends v: 1903 date: 08/19/2013
ID-1: hidpp_battery_1 charge: N/A condition: N/A volts: 3.7 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: status: Discharging
RAM: total: 7.72 GiB used: 3.72 GiB (48.2%)
Info: Quad Core model: Intel Core i5-3570 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB bogomips: 27208
Speed: 3012 MHz min/max: 1600/4000 MHz Core speeds (MHz): 1: 3012 2: 1800
3: 2862 4: 2688
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms
est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sep
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia
v: 460.80 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:128b
class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.7:5 chip-ID: 046d:0825 class-ID: 0102 serial:
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 161 s-size: 302x170mm (11.9x6.7")
s-diag: 347mm (13.6")
Monitor-1: HDMI-0 res: 1920x1080 hz: 120 dpi: 81
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 460.80
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 3.33 TiB used: 193.69 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: rev: 3B1Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: rev: 1B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD5000AACS-00ZUB0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: rev: 1B01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DL003-9VT166
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: 5900 rpm serial: rev: CC32 scheme: GPT
ID-5: /dev/sdf maj-min: 8:80 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 29.31 GiB block-size: physical: 512 B
logical: 512 B serial: rev: PMAP scheme: MBR
ID-1: / raw-size: 438.89 GiB size: 431 GiB (98.20%) used: 193.69 GiB (44.9%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: e81ee2fe-5bf4-43d1-b4b7-d19895f827b4
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs
label: R\xc3\xa9serv\xc3\xa9 au syst\xc3\xa8me uuid: D6EE7C33EE7C0DCD
ID-2: /dev/sda2 maj-min: 8:2 size: 119.14 GiB fs: ntfs label: N/A
uuid: 0EC48B54C48B3CC9
ID-3: /dev/sdb1 maj-min: 8:17 size: 146.91 GiB fs: ext4 label: N/A
uuid: 0a5255c8-681f-44aa-9369-bca4762ed93e
ID-4: /dev/sdb4 maj-min: 8:20 size: 8.8 GiB fs: swap label: N/A
uuid: 1b195052-3ce3-433f-8c89-775571c619b0
ID-5: /dev/sdc1 maj-min: 8:33 size: 300 MiB fs: ntfs
label: R\xc3\xa9cup\xc3\xa9ration uuid: FC7000DE7000A20E
ID-6: /dev/sdc2 maj-min: 8:34 size: 100 MiB fs: vfat label: N/A
uuid: 0403-F65E
ID-7: /dev/sdc3 maj-min: 8:35 size: 128 MiB fs:
label: N/A uuid: N/A
ID-8: /dev/sdc4 maj-min: 8:36 size: 465.24 GiB fs: ntfs
label: donn\xc3\xa9es 0,5T uuid: 383C0E893C0E427C
ID-9: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ntfs
label: donn\xc3\xa9es 2T uuid: 4FA15E3371BCF52B
ID-10: /dev/sdf1 maj-min: 8:81 size: 2.89 GiB fs: iso9660
label: MANJARO_KDE_202 uuid: 2020-12-07-13-36-18-00
ID-11: /dev/sdf2 maj-min: 8:82 size: 4 MiB fs: vfat label: MISO_EFI
uuid: EC08-A711
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.5:13 info: Canon PIXMA MP560 type: Printer,Mass Storage
driver: usb-storage,usblp interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04a9:173e class-ID: 0806 serial:
Device-2: 2-1.6:4 info: Logitech C-U0007 [Unifying Receiver] type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c531 class-ID: 0300
Device-3: 2-1.7:5 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial:
Device-4: 2-1.8:15 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:3 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 5-2:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 300mA chip-ID: 0951:1666 class-ID: 0806
serial:
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 40 C
Processes: 233 Uptime: 19h 54m wakeups: 4 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1628 pacman: 1623 lib: 456
flatpak: 0 snap: 5 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04[/hide]
[hide=xrandr]Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.00 + 59.94 50.00 30.00 29.97 25.00 23.98 23.98
1920x1080 119.88* 60.00 59.94 50.00 29.97 23.98
1280x720 59.94 50.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93[/hide]
