Switched some days ago from testing to stable due to error “Signature is invalid”, yet some packages are newer than stable.
Could I just downgrade them to pamac build $(pamac list -qm) all of them?
Hi,
You can downgrade using sudo pacman -Syyuu but you can also leave them as stable will catch up with testing.
EDIT: A stable update has just been released today which might bring many/all of the packages up to the version you already have into stable.
Hi @Tribble,
I believe you’s have to sync with pacman again, to do that:
sudo pacman -Syyuu
I don’t know what the pamac equivalent is, but I know you have to set EnableDowngrade in /etc/pamac.conf by uncommenting it:
$ sudo micro /etc/pamac.conf
EnableDowngrade
Followed by, I believe, updating the system:
pamac update
Edit:
For anyone finding this afterward, the command is not:
pamac upgrade
But actually:
pamac update --enable-downgrade --force-refresh
(Thanks to @cscs for enlightening me.)
Yeah say the update. Yet some packages with higher version:
pamac update
Preparing...
Warning: lib32-libva-mesa-driver: local (21.3.1-0.1) is newer than multilib (21.2.5-1)
Warning: lib32-mesa: local (21.3.1-0.1) is newer than multilib (21.2.5-1)
Warning: lib32-mesa-vdpau: local (21.3.1-0.1) is newer than multilib (21.2.5-1)
Warning: lib32-vulkan-intel: local (21.3.1-0.1) is newer than multilib (21.2.5-1)
Warning: lib32-vulkan-radeon: local (21.3.1-0.1) is newer than multilib (21.2.5-1)
Warning: libva-mesa-driver: local (21.3.1-0.1) is newer than extra (21.2.5-1)
Warning: mesa: local (21.3.1-0.1) is newer than extra (21.2.5-1)
Warning: mesa-vdpau: local (21.3.1-0.1) is newer than extra (21.2.5-1)
Warning: vulkan-intel: local (21.3.1-0.1) is newer than extra (21.2.5-1)
Warning: vulkan-radeon: local (21.3.1-0.1) is newer than extra (21.2.5-1)
Nothing to do.
AH! Think I just figured it out. Try:
Maybe not all packages in the latest stable update were aligned with testing, for whatever reason.
Use the pacman command above to downgrade (I’ve had a message about manjaro hello local being newer for ages, and I have just left it).
@Mirdarthos Perfect as expected:
Preparing...
Warning: lib32-libva-mesa-driver: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: lib32-mesa: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: lib32-mesa-vdpau: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: lib32-vulkan-intel: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: lib32-vulkan-radeon: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: libva-mesa-driver: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: mesa: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: mesa-vdpau: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: vulkan-intel: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Warning: vulkan-radeon: downgrading from version 21.3.1-0.1 to version 21.2.5-1
Resolving dependencies...
Checking inter-conflicts...
To downgrade (10):
lib32-libva-mesa-driver 21.2.5-1 (21.3.1-0.1) multilib 3.2 MB
mesa 21.2.5-1 (21.3.1-0.1) extra 17.6 MB
lib32-mesa 21.2.5-1 (21.3.1-0.1) multilib 14.1 MB
lib32-mesa-vdpau 21.2.5-1 (21.3.1-0.1) multilib 3.3 MB
lib32-vulkan-intel 21.2.5-1 (21.3.1-0.1) multilib 2.3 MB
lib32-vulkan-radeon 21.2.5-1 (21.3.1-0.1) multilib 1.8 MB
libva-mesa-driver 21.2.5-1 (21.3.1-0.1) extra 3.1 MB
mesa-vdpau 21.2.5-1 (21.3.1-0.1) extra 3.3 MB
vulkan-intel 21.2.5-1 (21.3.1-0.1) extra 2.4 MB
vulkan-radeon 21.2.5-1 (21.3.1-0.1) extra 1.8 MB
Total download size: 52.9 MB
Total installed size: -18.5 MB
Apply transaction ? [y/N] y
Download of mesa (21.2.5-1) started
Download of lib32-libva-mesa-driver (21.2.5-1) started
Download of lib32-libva-mesa-driver (21.2.5-1) finished
Download of lib32-mesa (21.2.5-1) started
Download of lib32-mesa (21.2.5-1) finished
Download of lib32-mesa-vdpau (21.2.5-1) started
Download of mesa (21.2.5-1) finished
Download of lib32-vulkan-radeon (21.2.5-1) started
Download of lib32-vulkan-radeon (21.2.5-1) finished
Download of lib32-vulkan-intel (21.2.5-1) started
Download of lib32-mesa-vdpau (21.2.5-1) finished
Download of libva-mesa-driver (21.2.5-1) started
Download of lib32-vulkan-intel (21.2.5-1) finished
Download of mesa-vdpau (21.2.5-1) started
Download of libva-mesa-driver (21.2.5-1) finished
Download of vulkan-intel (21.2.5-1) started
Download of mesa-vdpau (21.2.5-1) finished
Download of vulkan-radeon (21.2.5-1) started
Download of vulkan-radeon (21.2.5-1) finished
Download of vulkan-intel (21.2.5-1) finished
Checking keyring... [10/10]
Checking integrity... [10/10]
Loading packages files... [10/10]
Checking file conflicts... [10/10]
Checking available disk space... [10/10]
Downgrading lib32-libva-mesa-driver (21.3.1-0.1 -> 21.2.5-1)... [1/10]
Downgrading mesa (21.3.1-0.1 -> 21.2.5-1)... [2/10]
Downgrading lib32-mesa (21.3.1-0.1 -> 21.2.5-1)... [3/10]
Downgrading lib32-mesa-vdpau (21.3.1-0.1 -> 21.2.5-1)... [4/10]
Downgrading lib32-vulkan-intel (21.3.1-0.1 -> 21.2.5-1)... [5/10]
Downgrading lib32-vulkan-radeon (21.3.1-0.1 -> 21.2.5-1)... [6/10]
Downgrading libva-mesa-driver (21.3.1-0.1 -> 21.2.5-1)... [7/10]
Downgrading mesa-vdpau (21.3.1-0.1 -> 21.2.5-1)... [8/10]
Downgrading vulkan-intel (21.3.1-0.1 -> 21.2.5-1)... [9/10]
Downgrading vulkan-radeon (21.3.1-0.1 -> 21.2.5-1)... [10/10]
Arming ConditionNeedsUpdate... [1/1]
A restart is required for the changes to take effect.
As shown in the wiki and other guides …
sudo pacman -Syyuu
Thats it.
With pamac you also want the --force-refresh flag after touching mirrors.
So assuming it handles this properly the command should ostensibly be:
