This package seems to have quite a few issues, at least with any driver older than 496.xx. Not only that most of the provided patches fail, even after adjusting the patches, it is not possible to compile any older driver. For example, trying to build the 396.18 driver, I get errors like this:
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.c:88:1: warning: data definition has no type or storage class
88 | NV_DEFINE_PROCFS_SINGLE_FILE(permissions);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.c:88:1: error: type defaults to 'int' in declaration of 'NV_DEFINE_PROCFS_SINGLE_FILE' [-Werror=implicit-int]
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.c:88:1: warning: parameter names (without types) in function declaration
In file included from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-linux.h:299,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.c:30:
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.c: In function 'nvlink_permissions_init':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:47: error: 'nv_procfs_permissions_fops' undeclared (first use in this function)
60 | const struct file_operations *fops = &nv_procfs_##__name##_fops; \
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.c:108:26: note: in expansion of macro 'NV_CREATE_PROC_FILE'
108 | nvlink_permissions = NV_CREATE_PROC_FILE("permissions",
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:47: note: each undeclared identifier is reported only once for each function it appears in
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:61:19: error: 'const struct file_operations' has no member named 'proc_write'; did you mean 'splice_write'?
61 | if (fops->proc_write != 0) \
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:63:60: error: passing argument 4 of 'proc_create_data' from incompatible pointer type [-Werror=incompatible-pointer-types]
63 | __entry = proc_create_data(filename, mode, parent, fops, __data);\
In file included from ./include/linux/efi.h:19,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-linux.h:205,
./include/linux/proc_fs.h:106:48: note: expected 'const struct proc_ops *' but argument is of type 'const struct file_operations *'
106 | const struct proc_ops *,
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:280: /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nvlink_linux.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_api.h:30,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_global.c:24:
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_va_range.h: In function 'uvm_va_range_vma_check':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_va_range.h:670:45: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
670 | uvm_assert_mmap_sem_locked(&vma->vm_mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:492:14: note: in definition of macro 'uvm_assert_mmap_sem_locked_mode'
492 | typeof(mmap_sem) _sem = (mmap_sem); \
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_va_range.h:670:5: note: in expansion of macro 'uvm_assert_mmap_sem_locked'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:492:32: note: in definition of macro 'uvm_assert_mmap_sem_locked_mode'
In file included from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:29,
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:493:34: warning: passing argument 1 of 'rwsem_is_locked' makes pointer from integer without a cast [-Wint-conversion]
493 | UVM_ASSERT(rwsem_is_locked(_sem) && uvm_check_locked_mmap_sem(_sem, (mode))); \
| int
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm_common.h:126:47: note: in definition of macro 'UVM_IGNORE_EXPR'
126 | #define UVM_IGNORE_EXPR(expr) ((void)sizeof(!(expr)))
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm_common.h:156:26: note: in expansion of macro '_UVM_ASSERT_MSG'
156 | #define UVM_ASSERT(expr) _UVM_ASSERT_MSG(expr, #expr, "\n")
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:493:7: note: in expansion of macro 'UVM_ASSERT'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:496:53: note: in expansion of macro 'uvm_assert_mmap_sem_locked_mode'
496 | #define uvm_assert_mmap_sem_locked(mmap_sem) uvm_assert_mmap_sem_locked_mode((mmap_sem), UVM_LOCK_MODE_ANY)
In file included from ./include/linux/mm_types.h:11,
from ./include/linux/mmzone.h:21,
from ./include/linux/gfp.h:6,
from ./include/linux/mm.h:10,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-pgprot.h:17,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-linux.h:21,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm_linux.h:41,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_api.h:29,
./include/linux/rwsem.h:57:56: note: expected 'struct rw_semaphore *' but argument is of type 'int'
57 | static inline int rwsem_is_locked(struct rw_semaphore *sem)
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:493:69: warning: passing argument 1 of 'uvm_check_locked' makes pointer from integer without a cast [-Wint-conversion]
| int
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:462:38: note: expected 'void *' but argument is of type 'int'
462 | static bool uvm_check_locked(void *lock, uvm_lock_mode_t mode)
make[2]: *** [scripts/Makefile.build:280: /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_global.o] Error 1
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:24:
| int
| int
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm_vm_open_managed':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:305:50: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
305 | uvm_record_lock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:305:5: note: in expansion of macro 'uvm_record_lock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:354:52: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
354 | uvm_record_unlock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:354:5: note: in expansion of macro 'uvm_record_unlock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm_vm_close_managed':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:364:54: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
364 | uvm_record_lock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:364:9: note: in expansion of macro 'uvm_record_lock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:394:56: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
394 | uvm_record_unlock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:394:9: note: in expansion of macro 'uvm_record_unlock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm_vm_fault':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:422:48: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
422 | uvm_record_lock_mmap_sem_read(&vma->vm_mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:422:5: note: in expansion of macro 'uvm_record_lock_mmap_sem_read'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:482:50: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
482 | uvm_record_unlock_mmap_sem_read(&vma->vm_mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:482:5: note: in expansion of macro 'uvm_record_unlock_mmap_sem_read'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm_vm_open_semaphore_pool':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:551:50: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
551 | uvm_record_lock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:551:5: note: in expansion of macro 'uvm_record_lock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:589:52: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
589 | uvm_record_unlock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:589:5: note: in expansion of macro 'uvm_record_unlock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm_vm_close_semaphore_pool':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:599:54: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
599 | uvm_record_lock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:599:9: note: in expansion of macro 'uvm_record_lock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:608:56: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
608 | uvm_record_unlock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:608:9: note: in expansion of macro 'uvm_record_unlock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm_mmap':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:634:50: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
634 | uvm_record_lock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:634:5: note: in expansion of macro 'uvm_record_lock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:720:52: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
720 | uvm_record_unlock_mmap_sem_write(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:720:5: note: in expansion of macro 'uvm_record_unlock_mmap_sem_write'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c: In function 'uvm8_initialize':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:860:43: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
860 | uvm_down_write_mmap_sem(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:519:16: note: in definition of macro 'uvm_down_write_mmap_sem'
519 | typeof(mmap_sem) _sem = (mmap_sem); \
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:519:34: note: in definition of macro 'uvm_down_write_mmap_sem'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:521:20: warning: passing argument 1 of 'down_write' makes pointer from integer without a cast [-Wint-conversion]
521 | down_write(_sem); \
| int
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:860:5: note: in expansion of macro 'uvm_down_write_mmap_sem'
./include/linux/rwsem.h:137:45: note: expected 'struct rw_semaphore *' but argument is of type 'int'
137 | extern void down_write(struct rw_semaphore *sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:879:41: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
879 | uvm_up_write_mmap_sem(¤t->mm->mmap_sem);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:525:16: note: in definition of macro 'uvm_up_write_mmap_sem'
525 | typeof(mmap_sem) _sem = (mmap_sem); \
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:525:34: note: in definition of macro 'uvm_up_write_mmap_sem'
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_lock.h:526:18: warning: passing argument 1 of 'up_write' makes pointer from integer without a cast [-Wint-conversion]
526 | up_write(_sem); \
| int
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.c:879:5: note: in expansion of macro 'uvm_up_write_mmap_sem'
./include/linux/rwsem.h:153:43: note: expected 'struct rw_semaphore *' but argument is of type 'int'
153 | extern void up_write(struct rw_semaphore *sem);
make[2]: *** [scripts/Makefile.build:280: /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8.o] Error 1
In file included from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_pmm_gpu.h:55,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_gpu.h:37,
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_tools.c:24:
In file included from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_tools.c:23:
| int
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm_common.h:48,
| int
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_tools.c: In function 'map_user_pages':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_tools.c:273:29: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
273 | down_read(¤t->mm->mmap_sem);
| mmap_base
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_tools.c:275:27: error: 'struct mm_struct' has no member named 'mmap_sem'; did you mean 'mmap_base'?
275 | up_read(¤t->mm->mmap_sem);
| mmap_base
make[2]: *** [scripts/Makefile.build:280: /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia-uvm/uvm8_tools.o] Error 1
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:161:1: warning: data definition has no type or storage class
161 | NV_DEFINE_PROCFS_SINGLE_FILE(gpu_info);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:161:1: error: type defaults to 'int' in declaration of 'NV_DEFINE_PROCFS_SINGLE_FILE' [-Werror=implicit-int]
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:161:1: warning: parameter names (without types) in function declaration
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:175:1: warning: data definition has no type or storage class
175 | NV_DEFINE_PROCFS_SINGLE_FILE(version);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:175:1: error: type defaults to 'int' in declaration of 'NV_DEFINE_PROCFS_SINGLE_FILE' [-Werror=implicit-int]
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:175:1: warning: parameter names (without types) in function declaration
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:346:1: warning: data definition has no type or storage class
346 | NV_DEFINE_PROCFS_SINGLE_FILE(params);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:346:1: error: type defaults to 'int' in declaration of 'NV_DEFINE_PROCFS_SINGLE_FILE' [-Werror=implicit-int]
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:346:1: warning: parameter names (without types) in function declaration
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:700:1: warning: data definition has no type or storage class
700 | NV_DEFINE_PROCFS_SINGLE_FILE(text_file);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:700:1: error: type defaults to 'int' in declaration of 'NV_DEFINE_PROCFS_SINGLE_FILE' [-Werror=implicit-int]
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:700:1: warning: parameter names (without types) in function declaration
from /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:15:
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c: In function 'nv_procfs_add_text_file':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:47: error: 'nv_procfs_text_file_fops' undeclared (first use in this function); did you mean 'nv_procfs_registry_fops'?
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:709:5: note: in expansion of macro 'NV_CREATE_PROC_FILE'
709 | NV_CREATE_PROC_FILE(filename, parent, text_file, (void *)text);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c: In function 'nv_register_procfs':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:47: error: 'nv_procfs_params_fops' undeclared (first use in this function); did you mean 'nv_procfs_registry_fops'?
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:763:13: note: in expansion of macro 'NV_CREATE_PROC_FILE'
763 | entry = NV_CREATE_PROC_FILE("params", proc_nvidia, params, NULL);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:46: error: initialization of 'const struct file_operations *' from incompatible pointer type 'struct proc_ops *' [-Werror=incompatible-pointer-types]
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:767:13: note: in expansion of macro 'NV_CREATE_PROC_FILE'
767 | entry = NV_CREATE_PROC_FILE("registry", proc_nvidia, registry, NULL);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:47: error: 'nv_procfs_version_fops' undeclared (first use in this function); did you mean 'nv_procfs_registry_fops'?
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:788:13: note: in expansion of macro 'NV_CREATE_PROC_FILE'
788 | entry = NV_CREATE_PROC_FILE("version", proc_nvidia, version, NULL);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c: In function 'nv_procfs_add_gpu':
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/common/inc/nv-procfs.h:60:47: error: 'nv_procfs_gpu_info_fops' undeclared (first use in this function)
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:831:13: note: in expansion of macro 'NV_CREATE_PROC_FILE'
831 | entry = NV_CREATE_PROC_FILE("information", proc_nvidia_gpu, gpu_info,
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:836:13: note: in expansion of macro 'NV_CREATE_PROC_FILE'
836 | entry = NV_CREATE_PROC_FILE("registry", proc_nvidia_gpu, registry, nv);
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:842:17: note: in expansion of macro 'NV_CREATE_PROC_FILE'
842 | entry = NV_CREATE_PROC_FILE("exercise_error_forwarding", proc_nvidia_gpu,
/home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.c:850:17: note: in expansion of macro 'NV_CREATE_PROC_FILE'
850 | entry = NV_CREATE_PROC_FILE("unbindLock", proc_nvidia_gpu, unbind_lock, nv);
make[2]: *** [scripts/Makefile.build:280: /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO/nvidia/nv-procfs.o] Error 1
make[1]: *** [Makefile:1822: /home/gerd/Downloads/nvidia-390xx/nvidia-all/src/NVIDIA-Linux-x86_64-396.18/kernel-5.10.85-1-MANJARO] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.10.85-1-MANJARO/build'
make: *** [Makefile:79: modules] Error 2
==> ERROR: A failure occurred in build().
Aborting...
