I did some more reasearch, it appears to be a problem with .NET Core 3.1
which has a limitation of max ICU version it can use, which is 70
End of Support
for .NET Core 3.1
is December 13, 2022, in about 6 months so they are not going to support icu 71
The project I’m working on is mostly .NET 6.0
but it still has some 3.1
code inside it.
For the .NET 6.0
i narrowed down the problem to Microsoft.NET.Sdk.Functions
package:
Microsoft.Azure.WebJobs.Script.ExtensionsMetadataGenerator.targets(37, 5): Metadata generation failed. Exit code: '134' Error: 'Process terminated. Couldn't find a valid ICU package installed on the system. Set the configuration flag System.Globalization.Invariant to true if you want to run with no globalization support. at System.Environment.FailFast(System.String) at System.Globalization.GlobalizationMode.GetGlobalizationInvariantMode() at System.Globalization.GlobalizationMode..cctor() at System.Globalization.CultureData.CreateCultureWithInvariantData() at System.Globalization.CultureData.get_Invariant() at System.Globalization.CultureInfo..cctor() at System.String.ToLowerInvariant() at System.IO.PathInternal.GetIsCaseSensitive() at System.IO.PathInternal..cctor() at System.IO.Enumeration.FileSystemEnumerableFactory.MatchesPattern(System.String, System.ReadOnlySpan`1<Char>, System.IO.EnumerationOptions) at System.IO.Enumeration.FileSystemEnumerableFactory+<>c__DisplayClass3_0.<UserFiles>b__1(System.IO.Enumeration.FileSystemEntry ByRef) at System.IO.Enumeration.FileSystemEnumerable`1+DelegateEnumerator[[System.__Canon, System.Private.CoreLib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]].ShouldIncludeEntry(System.IO.Enumeration.FileSystemEntry ByRef) at System.IO.Enumeration.FileSystemEnumerator`1[[System.__Canon, System.Private.CoreLib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]].MoveNext() at System.Linq.Enumerable+WhereEnumerableIterator`1[[System.__Canon, System.Private.CoreLib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]].ToArray() at System.Linq.Enumerable.ToArray[[System.__Canon, System.Private.CoreLib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]](System.Collections.Generic.IEnumerable`1<System.__Canon>) at ExtensionsMetadataGenerator.ExtensionsMetadataGenerator.Generate(System.String, System.String, ExtensionsMetadataGenerator.ConsoleLogger) at ExtensionsMetadataGenerator.Console.Program.Main(System.String[])'
The strange thing about this error is that System.Globalization.GlobalizationMode.GetGlobalizationInvariantMod
method doesn’t exist in .NET 6.0
anymore
@linux-aarhus
Since you already have the environmen setup, would you mind running a sample .NET 6.0
project that references Microsoft.NET.Sdk.Functions
and seeing if you get the same error?
<Project Sdk="Microsoft.NET.Sdk">
<PropertyGroup>
<OutputType>Exe</OutputType>
<TargetFramework>net6.0</TargetFramework>
<ImplicitUsings>enable</ImplicitUsings>
<Nullable>enable</Nullable>
</PropertyGroup>
<ItemGroup>
<PackageReference Include="Microsoft.NET.Sdk.Functions" Version="4.1.1" />
</ItemGroup>
</Project>
dotnet --info
.NET SDK (reflecting any global.json):
Version: 6.0.301
Commit: 43f9b18481
Runtime Environment:
OS Name: manjaro
OS Version:
OS Platform: Linux
RID: linux-x64
Base Path: /usr/share/dotnet/sdk/6.0.301/
Host (useful for support):
Version: 6.0.6
Commit: 7cca709db2
.NET SDKs installed:
3.1.414 [/usr/share/dotnet/sdk]
6.0.301 [/usr/share/dotnet/sdk]
.NET runtimes installed:
Microsoft.AspNetCore.App 3.1.20 [/usr/share/dotnet/shared/Microsoft.AspNetCore.App]
Microsoft.AspNetCore.App 6.0.6 [/usr/share/dotnet/shared/Microsoft.AspNetCore.App]
Microsoft.NETCore.App 3.1.20 [/usr/share/dotnet/shared/Microsoft.NETCore.App]
Microsoft.NETCore.App 6.0.6 [/usr/share/dotnet/shared/Microsoft.NETCore.App]
To install additional .NET runtimes or SDKs:
https://aka.ms/dotnet-download
