Installed Dota 2 via Steam. I log in without using Proton and so on. (rendered the shaders) it works, but after a couple of minutes everything just freezes along with the system.
CMPXCHG16B instruction support (cx16 in /proc/cpuinfo flags)
SSE3 instruction support (pni in /proc/cpuinfo flags)
512 megabytes of RAM and 5 gigabytes of hard drive space, or better
Internet connection (Cable/DSL speeds recommended)
Latest Manjaro, fully updated
64-bit (x86-64, AMD64) Linux kernel
64-bit (x86-64, AMD64) and 32-bit (i386, IA32) graphics drivers and glibc
Latest graphics driver
NVidia driver support - For recent cards (e.g. series 8), you will need to install 310.x. For older cards, driver 304.x supports the NVidia 6 and 7 GPU series. To access these drivers, first update your cache and then install the specific driver you need from the list in Additional Drivers.
AMD and Intel driver support - you will need to use the latest Mesa drivers, Mesa 9 or later. These should be preinstalled
