Hello there. Everything was working and the monitor was also connected. I have two video cards in my laptop and decided to switch to Nvidia, installed optimus-manager and stopped connecting the monitor. Here are my settings, logs …
System Details Report
Report details
- Date generated: 2023-12-11 08:51:09
Hardware Information:
- Hardware Model: Acer Aspire A715-72G
- Memory: 16,0 GiB
- Processor: Intel® Core™ i7-8750H × 12
- Graphics: Intel® UHD Graphics 630 (CFL GT2)
- Disk Capacity: 752,2 GB
Software Information:
- Firmware Version: V1.24
- OS Name: Manjaro Linux
- OS Build: rolling
- OS Type: 64-bit
- GNOME Version: 45.2
- Windowing System: X11
- Kernel Version: Linux 6.1.66-1-MANJARO
inix -G
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 545.29.06
Device-3: Quanta HD Webcam driver: uvcvideo type: USB
Display: x11 server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
NVIDIA Settings
Optimus-manager service info:
systemctl status optimus-manager.service ✔
● optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; preset: disabled)
Active: active (running) since Mon 2023-12-11 07:25:00 EET; 1h 32min ago
Process: 746 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_daemon_start (code=exited, status=0/SUCCESS)
Process: 779 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_xorg_start (code=exited, status=0/SUCCESS)
Main PID: 794 (python3)
Tasks: 1 (limit: 18970)
Memory: 18.1M
CPU: 246ms
CGroup: /system.slice/optimus-manager.service
└─794 /usr/bin/python3 -u -m optimus_manager.daemon
гру 11 07:25:00 parano1a-aspire7 python3[779]: [34] INFO: Available modules: ['nouveau', 'bbswitch', 'acpi_call', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'n>
гру 11 07:25:00 parano1a-aspire7 python3[779]: [34] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
гру 11 07:25:00 parano1a-aspire7 python3[779]: [37] INFO: switching=none, nothing to do
гру 11 07:25:00 parano1a-aspire7 python3[779]: [63] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
гру 11 07:25:00 parano1a-aspire7 python3[779]: [63] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20231211T072500', 'requested_mode': >
гру 11 07:25:00 parano1a-aspire7 python3[779]: [63] INFO: Xorg pre-start hook completed successfully.
гру 11 07:25:00 parano1a-aspire7 systemd[1]: Started Optimus Manager Commands Daemon.
гру 11 07:25:00 parano1a-aspire7 python3[794]: [1] INFO: # Commands daemon
гру 11 07:25:00 parano1a-aspire7 python3[794]: [1] INFO: Opening UNIX socket
гру 11 07:25:00 parano1a-aspire7 python3[794]: [1] INFO: Awaiting commands
Run optimus-manager
optimus-manager INT ✘ 55s
ERROR: a GPU setup was initiated but Xorg post-start hook did not run.
Log at /var/log/optimus-manager/switch/switch-20231211T072500.log
If your login manager is GDM, make sure to follow those instructions:
https://github.com/Askannz/optimus-manager#important--gnome-and-gdm-users
If your display manager is neither GDM, SDDM nor LightDM, or if you don't use one, read the wiki:
https://github.com/Askannz/optimus-manager/wiki/FAQ,-common-issues,-troubleshooting
Cannot execute command because of previous errors.
Optimus-manager logs:
journalctl -xe | grep optimus-manager 1 ✘
гру 11 08:55:52 parano1a-aspire7 optimus-manager-qt[33007]: Unable to read current mode from Optimus Manager state file
гру 11 08:55:52 parano1a-aspire7 systemd-coredump[33020]: Process 33007 (optimus-manager) of user 1000 dumped core.
#4 0x000055b39e58eba1 n/a (optimus-manager-qt + 0x12ba1)
#7 0x000055b39e591455 n/a (optimus-manager-qt + 0x15455)
░░ Subject: Process 33007 (optimus-manager) dumped core
░░ Process 33007 (optimus-manager) crashed and dumped core.
journalctl -u optimus-manager.service -b0 1 ✘
гру 11 07:25:00 parano1a-aspire7 systemd[1]: Starting Optimus Manager Commands Daemon...
гру 11 07:25:00 parano1a-aspire7 python3[746]: [24] INFO: # Daemon pre-start hook
гру 11 07:25:00 parano1a-aspire7 python3[746]: [24] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
гру 11 07:25:00 parano1a-aspire7 python3[746]: [25] INFO: Startup mode is: integrated
гру 11 07:25:00 parano1a-aspire7 python3[746]: [25] INFO: Writing state {'type': 'pending_pre_xorg_start', 'requested_mode': 'integrated', 'current_mode': Non>
гру 11 07:25:00 parano1a-aspire7 python3[746]: [25] INFO: Daemon pre-start hook completed successfully.
гру 11 07:25:00 parano1a-aspire7 python3[746]: [25] INFO: Calling Xorg pre-start hook.
гру 11 07:25:00 parano1a-aspire7 python3[779]: [9] INFO: # Xorg pre-start hook
гру 11 07:25:00 parano1a-aspire7 python3[779]: [9] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'integrated', 'current_mode'>
гру 11 07:25:00 parano1a-aspire7 python3[779]: [9] INFO: Requested mode is: integrated
MHWD:
mhwd --listinstalled ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
mhwd --list ✔
> 0000:01:00.0 (0300:10de:1c8c) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia-390xx 2023.03.23 false PCI
video-vesa 2017.03.12 true PCI
> 0000:07:00.1 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
