How do I turn off hibernate? Clearly I followed one guy on YouTube, and all he did was go into power settings, and I copied the few things he did and save. But when I reboot my computer, everything I had open is open. I wanna disable it cuz I’ve had performance issues with my RAM. I heard disabling hibernation and adjusting swappiness is a good idea. Can I only do it in the terminal? if so, I once again ask how?
Try this:
sudo nano /etc/systemd/sleep.conf.d/no-hibernate.conf
paste the following in there save and exit.
[Sleep]
# disable hibernation
# doc : https://archived.forum.manjaro.org/t/turn-off-disable-hibernate-completely/139939
AllowHibernation=no
AllowHybridSleep=no
AllowSuspendThenHibernate=no
Once you reboot the hibernate option should be gone.
I get this error when I nano in " No such file or directory"
Which directory is “missing”
do this first:
sudo mkdir /etc/systemd/sleep.conf.d
thank you very much! worked perfectly
Is there a similar solution for no-sleep (in the Plasma menu Suspend to RAM)?
