Hello, well my problem will be quick to explain: Dolphin simply doesn’t open anymore. If I try to launch it from a terminal, nothing happens, and there’s no error or any log:
$ dolphin
Dolphin version : 24.12.2
Kernel: 6.6.80-1-MANJARO
DE: Plasma 6.3.2
Packages are up to date.
I noticed that the exact same problem happens for Filezilla, in case it might give you a clue, or maybe it’s not related at all.
I’m not sure where to start looking, since I don’t have any errors.
Yes, because that is the ID of the dolphin process, if I’m not mistaken. basically this means that is actually is starting up, it’s just not visible. You don’t have any other monitors it can hide on do you? Or perhaps it’s starting minimized.
Indeed I can see the process running in htop, but they are not visible anywhere. I have two monitors (laptop + external screen).
But no Dolphin shown in the windows list when I press alt+tab, also the Dolphin icon in the taskbar has a dark background, like if the app was not running. (Yeah, that is a real technical description )
Do you have other services running?
I have NFS server running on other computer occasionally. When I shut down that computer, Dolphin on my computer gets unresponsive and I have to kill it. If I try to launch Dolphin again, it never appears. Only a reboot fixes it.
I’m not running any special services, even on a fresh reboot it still doesn’t open.
I’m using docker for work (which is not started on login) so I don’t have anything special installed on my system.
Thanks for the help tho, I’ll keep investigating.
Yes, it happens in a Live environment, I’m not using virtual desktop or anything
Edit : ok I just noticed the same problem happens with Gwenview, the KDE image viewer.
So… So far the problem occurs with
If it happens in a Live Environment as well, I’m thinking it has something to do with your environment rather than software. Or your computer. Try using a different keyboard.
I deleted the cache and the config, and still same problem.
Thanks for your help tho, I’ll keep you informed if I find a fix, or if it solves itself with an update :')
If it shows any dolphin processes, then kill them all:
pkill -f dolphin
Then try launching dolphin from a terminal again and, if it seems to be running (i.e. the terminal does not return to the command prompt), then from a separate terminal run the ps ax | grep dolphin command again. Does anything change?
Also, a Stable Update was issued a few hours ago. Maybe that will fix the issue.
