Hello.
Copying process to webdav storage gets stuck with files larger than few megabytes.
This is journalctl log with successefull copying of small (few kilobytes) file:
plasmashell[1208]: New URI "file:///home/popombo" "" ""
plasmashell[1208]: New URI "webdavs://popombo@webdav.yandex.ru/bin" "" ""
plasmashell[1208]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
plasmashell[1208]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/CompactRepresentation.qml:145:13: QML PropertyChanges: Cannot assign to non-existent property "visible"
plasmashell[1208]: New URI "" "" ""
This is log of stuck file with 7.5 MB
dolphin[3761]: ""
plasmashell[1208]: New URI "file:///home/popombo/Загрузки" "" ""
I just don’t know why it is not copying. Popup keeps hanging showing 100% and file does not appear in webdav directory.
I had an old laptop, where everything worked fine, but it died last week. On this backup laptop it stucks. What am I missing? Or what settings might changed in newer Manjaro installations? Old laptop was with Manjaro installed 5-6 years ago, but upgraded to latest packages(of last week)
My inxi of laptop that I’m using now:
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=something rw quiet apparmor=1
intel_idle.max_cstate=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80FG v: Lenovo Z70-80 serial: <filter>
Chassis: type: 10 v: Lenovo Z70-80 serial: <filter>
Mobo: LENOVO model: Lenovo Z70-80 v: NO DPK serial: <filter>
UEFI [Legacy]: LENOVO v: ABCN73WW date: 02/06/2015
ID-1: BAT0 charge: 32.7 Wh condition: 32.7/37.6 Wh (87%) volts: 16.2/14.4
model: Lenovo IdeaPad type: Unknown serial: <filter> status: Full
Info: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F
L2 cache: 4096 KiB
bogomips: 19160
Speed: 2402 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 2393 2: 1794
3: 2395 4: 2395
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1616
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Lenovo driver: nvidia
v: 450.80.02 alternate: nouveau,nvidia_drm bus ID: 04:00.0
chip ID: 10de:1341
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus ID: 2-6:4
chip ID: 5986:0249
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k5.9.11-3-MANJARO
vendor: Lenovo driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 4000
bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: 4000
bus ID: 03:00.0 chip ID: 8086:08b4
Local Storage: total: 1.35 TiB used: 954.84 GiB (69.3%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1103 scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST1000LM014-SSHD-8GB size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: LVD4 scheme: MBR
ID-1: / raw size: 56.50 GiB size: 55.36 GiB (97.99%) used: 33.18 GiB (59.9%)
fs: ext4 dev: /dev/sda1
ID-2: /home raw size: 390.63 GiB size: 383.48 GiB (98.17%)
used: 164.93 GiB (43.0%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: zram size: 492.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram0
ID-2: swap-2 type: zram size: 492.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 492.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 492.6 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: partition size: 9.00 GiB used: 0 KiB (0.0%)
priority: 1024 dev: /dev/sdb3
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 243 Uptime: 26m Memory: 7.70 GiB used: 2.07 GiB (26.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 clang: 11.0.0
Packages: 1985 pacman: 1978 lib: 440 snap: 7 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.08
P.s. I can’t add right tags, like Dolphin and webdav, only kde. so…
