The last couple days, each time I insert a USB to back up a single 8 MiB file, Dolphin starts consuming over 80%-100% of CPU and the desktop fan starts blowing hard.
The files writes without error and completes. The message states that the USB can be removed. But the fan keeps blowing hard and Dolphin keeps consuming CPU until the USB is removed. Once removed, it calms down immediately and stops using CPU. Except I noticed, now, because I’m writing this message and usually shutdown immediately afterward, that Dolphin kicked up to 54% and the fan blew a moment and then both calmed again. This is after the USB had been removed for several minutes and doing nothing else but writing this question.
I had been doing the same thing each night for the past several months witthout issue.
Any idea where I can start looking to figure out why? Thank you.
The stick is formatted for Linux only. Using KDE and kernel 6.12.
Not sure if that’s needed? I don’t have it on my system, so I guess it’s not needed for sync to work (which does seem to, here). I use that after transferring stuff to USB.
This is a weird one, though. @Gary1 Is it the same with other USB sticks?
Thank you. I’ll have to experiment with that because this is the only USB I have formatted correctly and was using exFAT (or whatever it’s called) I suppose because when I formatted them I still had a windows machine with many of my files on it. Now I have no windows machines at all, and need to reformat those USB drives. But I have a new one here that I can test it on. (Just as an aside, deos anyone know why the price of USB drives appears to have more than doubled? The last time I purchased one, I bought directly from Samsung online and paid about $17 for a 256 GB. Now they’re about $40.)
I was thinking it might be the stick itself, so at least you do have others you can try.
As for the price … I recently needed to get one quite urgently. I found one local shop which still had one in stock … at £18 for a 64G stick. At least it’s a trusted brand.
The reason I ask is because of how you describe your issue.
I am thinking it is hardware related - your usb stick - USB stick degrades while in use - technically a USB stick can last - almost - for ever, if the use case is long term storage of e.g. personal and family documents which are rarely changed.
A stick that is used daily to read and write will degrade over time.
The general state of the world - flooding, earthquakes, war in Ukraine, war in the Middle East, tariffs imposed by US, China imposing restrictions on rare metals, the same components that is used for memory chips, and AI memory demands has sent the prices up and up and…
