Hi,
ive bought a used fujitsu S510 documentscanner, since sane bosts to support it fully.
lsusb detects the thing flawlessly:
Bus 002 Device 006: ID 04c5:1155 Fujitsu, Ltd ScanSnap S510
sane-find-scanner outputs:
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
# Also you need support for SCSI Generic (sg) in your operating system.
# If using Linux, try "modprobe sg".
could not fetch string descriptor: Pipe error
found possible USB scanner (vendor=0x04c5, product=0x1155) at libusb:002:012
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
scanimage -L outputs:
device `fujitsu:ScanSnap S510:22022’ is a FUJITSU ScanSnap S510 scanner
Scanimage -T outputs:
Output format is not set, using pnm as a default.
scanimage: sane_start: Error during device I/O
i added to /etc/udev/rules.d/65-sane-missing-scanner.rules:
#Fujitsu snapscan S510
ATTRS{idVendor}==“04c5”, ATTRS{idProduct}==“1155”, MODE=“0664”, GROUP=“scanner”, ENV{libsane_matched}=“yes”
i have added to /etc/sane.d/fujitsu.conf
#S510
usb 0x04c5 0x1155
and deleted the very same again, since its a doubling…
i added my user to both the scanner and the lp group. added scanner to saned.
I disabled usb-autosuspend in tlp-ui.
i rebooted several times in order to be sure, settings would take effect. No luck so far…
how to get the scanner working ?
