Dolphin no copy no moving since some days
surprisingly I can no longer copy or move between 2 windows with Dolphin. With Krusader it works.
What exactly do you see? Is there an error message?
Plasma 6.6 has new settings for what happens as the default action when objects are being dragged in dolphin. :backhand_index_pointing_down:
it’s not that.
There are folders in the same folder hierarchy that I can copy/move to. But I didn’t find any differences in the permissions for the folders.
How are you trying to move the files? Are you dragging-and-dropping, or are you cutting (Ctrl-X) & pasting (Ctrl-V)?
Also, when you state that you are moving the files between dolphin windows, do you mean 2 separate instances of dolphin, 2 different tabs in the same dolphin window, or are you using the Split View?
I just successfully moved files between directories located on different drives using all of the above scenarios.
I guess ownership as well? :wink:
What about the folders that you want to move them to? Permissions in UNIX are a lot more complex than what you might think. :backhand_index_pointing_down:
It might also be a failing disk/faulty partition that gets remounted as read-only…
Edit:
…although, that wouldn’t explain why it works in Krusader…
Can you please specify exactly which directory hierarchy you refer to? The presumption is that source and destination are within your User directories – is that the case, or is it a foreign hierarchy such as a network location or directories on another partition?
System info?
Are you using BTRFS?
Indeed!
@semperlin
Please provide system information:
inxi -zv8
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window, then paste the output in between two lines containing three backticks ``` or three tildes ~~~
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Yes, it is
No, ext4
  Kernel: 6.12.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=3b5daa01-9132-4629-a86b-e0877a13ec24 rw quiet splash
    resume=UUID=a5465aa8-4d32-4369-8f32-6101d0a8d162 udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
  Type: Mini-pc System: ASUSTeK product: MINIPC PN52 v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: PN52 v: Rev 1.xx serial: <superuser required>
    part-nu: SKU uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: 11800 date: 09/07/2022
  System RAM: total: 24 GiB available: 22.88 GiB used: 7 GiB (30.6%)
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: 9905700-101.A00G serial: <filter>
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    manufacturer: Micron Technology part-no: 8ATF1G64HZ-3G2R1 serial: <filter>
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500012
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1108 min/max: 400/4280 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1108 2: 1108 3: 1108
    4: 1108 5: 1108 6: 1108 7: 1108 8: 1108 9: 1108 10: 1108 11: 1108 12: 1108
    bogomips: 79085
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2 bus-ID: 05:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 42.0 C
  Device-2: Creative Live! Cam Chat HD [VF0700/VF0790]
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:5 chip-ID: 041e:4097
    class-ID: 0300
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
    display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,left model: EIZO NANAO FS2434
    serial: <filter> built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 92 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.322 y: 0.612
    blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-2 pos: right model: Dell E2310H serial: <filter>
    built: 2010 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
    chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 510x287mm (20.08x11.3")
    diag: 585mm (23") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 640x480,
    720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
    renoir ACO DRM 3.61 6.12.85-1-MANJARO) device-ID: 1002:1638
    memory: 500 MiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.0.6-arch1.1
    device-ID: 1002:1638 surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
    snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
    bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Creative Live! Cam Chat HD [VF0700/VF0790]
    class-ID: 0300
  API: ALSA v: k6.12.85-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 0489:e0e2
  Local Storage: total: 2.98 TiB used: 737.36 GiB (24.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V0210A0 temp: 38.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Verbatim model: Vi5000
    size: 953.87 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0213 scheme: GPT
  ID-1: / raw-size: 219.92 GiB size: 215.41 GiB (97.95%)
    used: 56.53 GiB (26.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 3b5daa01-9132-4629-a86b-e0877a13ec24
  ID-2: /boot/efi raw-size: 976 MiB size: 974.1 MiB (99.80%)
    used: 324 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4BFA-4D1B
  ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 680.69 GiB (37.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: aebb7b1c-0d48-45de-b8c0-53f28271c52f
  ID-1: swap-1 type: partition size: 12.01 GiB used: 153 MiB (1.2%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: a5465aa8-4d32-4369-8f32-6101d0a8d162
  ID-1: /dev/sdb1 maj-min: 8:17 size: 953.87 GiB fs: ext4 label: N/A
    uuid: 372f3707-0224-4dd9-822c-416c628133e2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 5-2.3:4 info: CHERRY USB Wireless Device
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046a:010e class-ID: 0300
  Device-2: 5-2.4:5 info: Creative Live! Cam Chat HD [VF0700/VF0790]
    type: video,audio,HID driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
    interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 041e:4097 class-ID: 0300
  Device-3: 5-3:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Device-1: 6-2.2:3 info: JMicron / USA JMS567 SATA 6Gb/s bridge
    type: mass storage driver: uas interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 152d:0562 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 61.1 C mobo: 36.0 C gpu: amdgpu temp: 42.0 C
  Fan Speeds (rpm): N/A
  Packages: 1691 pm: pacman pkgs: 1611 libs: 399 tools: pamac pm: flatpak
    pkgs: 80
    1: https://mirror.init7.net/manjaro/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    3: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    5: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    6: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 352
  1: cpu: 8.2% command: kwin_wayland pid: 975 mem: 349.3 MiB (1.4%)
  2: cpu: 6.1% command: typesetter pid: 3149 mem: 2211.4 MiB (9.4%)
  3: cpu: 5.0% command: baloo_file pid: 974 mem: 141.5 MiB (0.6%)
  4: cpu: 3.5% command: dolphin pid: 4134 mem: 294.4 MiB (1.2%)
  5: cpu: 2.5% command: firefox pid: 3446 mem: 695.1 MiB (2.9%)
  Memory top: 5 of 352
  1: mem: 2211.4 MiB (9.4%) command: typesetter pid: 3149 cpu: 6.1%
  2: mem: 695.1 MiB (2.9%) command: firefox pid: 3446 cpu: 2.5%
  3: mem: 646.3 MiB (2.7%) command: kontact pid: 5970 cpu: 0.3%
  4: mem: 553.6 MiB (2.3%) command: plasmashell pid: 1215 cpu: 0.8%
  5: mem: 349.3 MiB (1.4%) command: kwin_wayland pid: 975 cpu: 8.2%
  Processes: 352 Power: uptime: 1h 42m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 9.1 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Mod edit: Consecutive posts merged. Please edit your previous post(s) instead to add further information.
I don’t have this problem’s with my KDE System’s.
Could it be related to Encryption? Try to copy+paste or drag and drop in different area’s
and find out whats going on.
