Hi everyone. I installed two weeks ago the latest image Of Manjaro Plasma and I have the following issue with Dolphin. I do not get the progress bar on the notification tray and I cannot monitor the progress when I am copying/transferring files, the worst part is that I cannot cancel copy/transfer operations because of this.
P.S: The only “weird” thing I have done is to set the kernel parameter ibt=off to be able to install the nvidia driver for deep learning (an issue with latest kernel + new intel cpus + nvidia drivers)
I have checked some solutions given to older posts but nothing works.
Thank you in advance.
The solution that worked for me is in the second url.
Thank you very much. I am using latte dock maybe this is the issue I will check out tomorrow the respective answer that you sent and will let you know <3
Good morning my friend! Indeed I followed what the guy at the second URL did and it worked. Thank you very much again. Btw what kind of search did you do? Because I did not find this posts, I was just taking the same and same posts googling
