I updated my whole system and now dolphin-emu and pcsx2-qt only give a segmentation fault.
I had to delete lib32-wxgtk2 and python2-wxpython3
because I’m slow to update my machine and keeping them created conflicts.
The former is an AUR package and I can’t reinstall the latter so I don’t think they are the problem.
How can I know what is going on.
Is it Dolphin emulator from official repo? Because I installed it and I can start it without issue.
Yes, it and pcsx2 are in the official repos but they still get segmentation faults
You will need to give relevant system info, and crash logs, something people can work with to help.
What command do I use to have them?
Here’s what I got with inix -Fazy
Kernel: 5.10.148-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=637d4512-3245-45bc-a5df-1e1a56b28d88 rw quiet apparmor=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F50 date: 11/27/2019
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3065 high: 4099 min/max: 2200/4714:4588:4461:4335:4208
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
1: 4099 2: 2051 3: 3351 4: 4094 5: 3380 6: 2580 7: 4078 8: 2046 9: 2054
10: 2226 11: 4092 12: 2734 bogomips: 86276
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 09:00.0
chip-ID: 1002:7340 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x286mm (35.00x11.26")
s-diag: 934mm (36.77")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right model: Acer
KG241Q S serial: <filter> built: 2020 res: 1920x1080 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: HP LE1901w
serial: <filter> built: 2009 res: 1440x900 hz: 60 dpi: 89 gamma: 1.2
size: 410x256mm (16.14x10.08") diag: 483mm (19") ratio: 16:10 modes:
max: 1440x900 min: 720x400
OpenGL: renderer: AMD Radeon RX 5500 XT (navi14 LLVM 14.0.6 DRM 3.40
5.10.148-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
bus-ID: 09:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.10.148-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 1.01 TiB (74.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 193.91 GiB
(42.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 280 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 64.9 C mobo: N/A gpu: amdgpu temp: 69.0 C
mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1369
Processes: 401 Uptime: 2d 11h 20m wakeups: 43 Memory: 15.64 GiB used: 9.11
GiB (58.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2716 pm: pacman pkgs: 2713
libs: 557 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 pm: snap
pkgs: 3 Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.22
For the crash log the best I can do is :
~ >>> dolphin-emu
zsh: segmentation fault (core dumped) dolphin-emu
List all coredumps:
coredumpctl list --no-pager
Display it by putting in the PID:
coredumpctl info <PID> --no-pager
Btw I installed it and it starts normally.
Thanks for the command, here’s the result :
PID: 123143 (dolphin-emu)
UID: 1000 ([REDACTED])
GID: 1000 ([REDACTED])
Signal: 11 (SEGV)
Timestamp: Tue 2022-10-25 10:48:07 CEST (38s ago)
Command Line: dolphin-emu
Executable: /usr/bin/dolphin-emu
Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-kitty-123102.scope
Unit: user@1000.service
User Unit: app-gnome-kitty-123102.scope
Slice: user-1000.slice
Owner UID: 1000 ([REDACTED])
Boot ID: 1e8dac951ae54abc80e2ff78a0e77eb2
Machine ID: 51b36bd4649f4c55a02f2db0757dbd63
Hostname: [REDACTED]
Storage: /var/lib/systemd/coredump/core.dolphin-emu.1000.1e8dac951ae54abc80e2ff78a0e77eb2.123143.1666687687000000.zst (present)
Disk Size: 1.4M
Message: Process 123143 (dolphin-emu) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 8e9318f0e32fdbb7ceb5716ca6237580fbfa8e3e
Module libqt6ct.so with build-id b33f2301ca6ab69c95f7b38bfb29a80a7b5944e0
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
Module libQt6XcbQpa.so.6 with build-id 25b9675bdd9d2a213a39759b1eadc200aa074ea9
Module libqxcb.so with build-id b1ebe7743227f6a9051d44c34d9e9fd40aad0c55
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libpangoft2-1.0.so.0 with build-id d2aac9e9a7523c05b32ddc00621a1e371147485c
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libtiff.so.5 with build-id 62a8aefb339c3cbe35d1089c66c527a7b090804c
Module libjpeg.so.8 with build-id 46dfd8b2cbe8a10d13cd3182a7b490d0959534f9
Module libgmodule-2.0.so.0 with build-id 95ec7a190858206b2eaba22e06b126e4a4449200
Module libFLAC.so.12 with build-id 33c73690d24bc47897a89c69fa78e39e0953d835
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
Module libgomp.so.1 with build-id 117ab7458eb756ac0e9e4791c510ae72fe710bd5
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libmvec.so.1 with build-id 87830691ff1275668548231fddf8ff8eaa937fd6
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
Module libpango-1.0.so.0 with build-id 2cbe86c0a6de777fa7bc584d74ce48d39fc595d0
Module libpangocairo-1.0.so.0 with build-id 2e46c234e5b532d7b0da24a79d0803cd67dd127f
Module libgio-2.0.so.0 with build-id 804d947f8cb14bbbbf97e8bf2f93fd17b744e719
Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libsoxr.so.0 with build-id 9e49936ed807c1e52705b88d5d71706fe11d9ed1
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libasyncns.so.0 with build-id 3ed7e52f247b08f1dff19aef6a253ee4c5c785c0
Module libsndfile.so.1 with build-id 923361ca7a51d29651ef1e282559cbff70e31cde
Module libatomic.so.1 with build-id 30d6c8e955af99c57aa98b4d7c3f80196e82f174
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libnghttp2.so.14 with build-id 2b3da1b8c8fef25bf3aa4dbfea446a7ac94e41f9
Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
Module libb2.so.1 with build-id e39ae9514401c72c0e5cafa1abe0741360c22e87
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id ef3e323faf54271c824851913c119a7767c6bff1
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libOpenGL.so.0 with build-id 3df533822644f44fa89abdb75b9f89220dfdee56
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libQt6DBus.so.6 with build-id cd5a01c0313f99f4d1009205cddccff5d860bd6c
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libOpenCL.so.1 with build-id fd888c7280e1e95f15313b126285ee5fcb03508c
Module libdrm.so.2 with build-id 5b59e55b50556f6d541e4d73fd6a2dcfb1983894
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libva-x11.so.2 with build-id a3471b7f03ff54119b97b89a7f0996203b220da0
Module libva-drm.so.2 with build-id e98c416d6cb8aa19eb870a619ea0ce5481ac22d5
Module libmfx.so.1 with build-id d817dae78e0662e7206a66a41843a66cf0fb0b2f
Module libva.so.2 with build-id 53551f71c1e329a02561e3a9d5f5cf1b58c6965d
Module libxvidcore.so.4 with build-id 43bc390a7842a7ca3a0302e93442ea561d7f013a
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libx264.so.164 with build-id e0682a4f896560615b726e8b4d2659f541f50fa4
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libtheoradec.so.1 with build-id 19d321fd5455c7b7611ca9602a804b496124e06f
Module libtheoraenc.so.1 with build-id cde750f0621140f313e4ef4e5f212e662f24a38b
Module libSvtAv1Enc.so.1 with build-id 17c44f1a31c27a1bbe420223d8ff973d2ab58d92
Module libspeex.so.1 with build-id fd7a3d6df98e453f2513c929f26950060ec8ff48
Module librav1e.so.0 with build-id 71e3a64e4f1fd0bda7ec80b255af3de4ea403ac1
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libopenjp2.so.7 with build-id 5fa7037f0c932c285735dbcd42365abe6c3abb05
Module libopencore-amrnb.so.0 with build-id 6690c607f7a7480e92f8690974e7e30575428cb1
Module libmp3lame.so.0 with build-id 19eef0793322b522143e4f8e602197f1a22be3f4
Module libgsm.so.1 with build-id 4e1e1890ec2f93119f1a2ecb3312741cbd1ea84c
Module libaom.so.3 with build-id eacc2c29204604b1ebf7a40325dcaab738ce0bd1
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
Module libgobject-2.0.so.0 with build-id afb0315fefdf602be0615bd5c97f35a7ac1d6bbe
Module librsvg-2.so.2 with build-id c5d3f3e2ba0718c84f4f6f02974929f5459dde04
Module libopencore-amrwb.so.0 with build-id 8d1526cc5d013c2638ad4588e7582e3cc7559ff8
Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
Module libwebp.so.7 with build-id 96dd01a02a3b0b4dae0d744fc3200fd36f1c2148
Module libwebpmux.so.3 with build-id c987ad73c6cbbfcdb4d632ead20256769852066e
Module libvpx.so.7 with build-id accaef32c955264d758e0348e7da476c5979d711
Module libswresample.so.4 with build-id 0f9bdf9b8f33bf71a1639ecd64e8d094ee7ce320
Module libssh.so.4 with build-id 16dc8b8699fa997e88b9c37a4045deca27360751
Module libsrt.so.1.5 with build-id 3bc4bb473f08dd091a16f3b5fb85c354811efeec
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libbluray.so.2 with build-id 4024c00050a4c02f1b1248b09b264a82566b18b7
Module libmodplug.so.1 with build-id b00dcb12e7d2d5882b4fa414295eba449875dae4
Module libxml2.so.2 with build-id 49868de417eee9052facae410a866ebfbd5cceb8
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libdbus-1.so.3 with build-id 6dece245a58f1549ed98431e1242f487e8ebf9a2
Module libpulsecommon-16.1.so with build-id 17e5c781f557e60fbc789cb631816a4a29230f4a
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libusb-1.0.so.0 with build-id 98d3b69176fc359d2c574759c2064f83e5cdf8ed
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libminizip-ng.so.3 with build-id d24b35e89d1c4d2d38eeb7cf0af448fb5f780acd
Module libfmt.so.9 with build-id be218116c2cf11088323847aac60b2e939458533
Module libpugixml.so.1 with build-id 5312154ab332374248e96f4ca55dcb9d89900c96
Module libminiupnpc.so.17 with build-id fc9bab4581a0e9135c276946051a1f1df72f0390
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libEGL.so.1 with build-id 14389538015bb4a3a44e794e2466e31bf0834209
Module libcurl.so.4 with build-id 93344344927f7c4bc68cba8e664b3744a7d69df7
Module libmbedcrypto.so.7 with build-id ac03f5e42467e8669808a742b59275671865457b
Module libmbedx509.so.1 with build-id 9d163a053ef1056154bc70cf90e08e69dc9b4dc4
Module libmbedtls.so.14 with build-id edfe21793d1c184e27897d4df7bfc7a7a3c1e94d
Module libenet.so.7 with build-id a12b19fe402b64aee313fa8f0f8d86f3665d644d
Module libQt6Core.so.6 with build-id 58691aace71818944994ca8feaf835e774031d59
Module libQt6Gui.so.6 with build-id fc60e808c0e0f8caef00cfdb1f0feae4b6702759
Module libavutil.so.57 with build-id 7a1435be743f883eea5869c0e8638efbaf7fe013
Module libswscale.so.6 with build-id dcb3f09e897261fccb27f61d429c2bf55adc58e6
Module libavcodec.so.59 with build-id 5794c410adce8d76ae7ce3ec6065b2c60ef78629
Module libavformat.so.59 with build-id e47829723d006314f41d24ef5d35828cba722e0b
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libhidapi-hidraw.so.0 with build-id 0a4f40f0e8357f6a264b2b31efa4e1c72abe35cd
Module libbluetooth.so.3 with build-id f6ceb35cdbfe583d9ecb8120583b2922003e7719
Module liblzo2.so.2 with build-id ed8e33ba505954ca344aea58d10c7b8a37fd2f39
Module libsfml-system.so.2.5 with build-id f1f66450bdcaafced185410fb9e70ed63c178c7d
Module libsfml-network.so.2.5 with build-id bf7506f4496e7777b0f8075d117f08a1b41a0a34
Module libudev.so.1 with build-id 8c459883f08a1890f2f1daa9f6eeaae357e9e790
Module libevdev.so.2 with build-id 9ded5f5a6c45f3b30cf380d8a505e90b5f85f164
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libpulse.so.0 with build-id 0c1618cb1e11cc14128914e45965433374cbd10e
Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
Module libQt6Widgets.so.6 with build-id fb5fb1f09b6a1ddefd2c330d68dc538a75bbfa91
Module dolphin-emu with build-id 0f0553bcfd4f31218468c45c6c7897156d6f9631
Stack trace of thread 123143:
#0 0x00007f2c2433b47c _ZNK5QFonteqERKS_ (libQt6Gui.so.6 + 0x38547c)
#1 0x00007f2c2433b86e _ZNK5QFontneERKS_ (libQt6Gui.so.6 + 0x38586e)
#2 0x00007f2c2415a0a2 _ZN15QGuiApplication7setFontERK5QFont (libQt6Gui.so.6 + 0x1a40a2)
#3 0x00007f2c12ab697d n/a (libqt6ct.so + 0xb97d)
#4 0x00007f2c12ab6f2a n/a (libqt6ct.so + 0xbf2a)
#5 0x00007f2c24185d0d _ZN21QPlatformThemeFactory6createERK7QStringS2_ (libQt6Gui.so.6 + 0x1cfd0d)
#6 0x00007f2c2414c0b0 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt6Gui.so.6 + 0x1960b0)
#7 0x00007f2c2414dbc9 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x197bc9)
#8 0x00007f2c23b5928c _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x12f28c)
#9 0x00007f2c2414dc51 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x197c51)
#10 0x00007f2c2672bade _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0x16cade)
#11 0x000055787590dfbe n/a (dolphin-emu + 0x13efbe)
#12 0x00007f2c232b8290 n/a (libc.so.6 + 0x23290)
#13 0x00007f2c232b834a __libc_start_main (libc.so.6 + 0x2334a)
#14 0x000055787592feb5 n/a (dolphin-emu + 0x160eb5)
Stack trace of thread 123144:
#0 0x00007f2c233900bf __poll (libc.so.6 + 0xfb0bf)
#1 0x00007f2c2316720b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f2c23168ccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
#3 0x00007f2c12b923b2 n/a (libQt6XcbQpa.so.6 + 0x4e3b2)
#4 0x00007f2c23cafdd1 n/a (libQt6Core.so.6 + 0x285dd1)
#5 0x00007f2c2331b8fd n/a (libc.so.6 + 0x868fd)
#6 0x00007f2c2339da60 n/a (libc.so.6 + 0x108a60)
EDIT :
Here’s also PCSX2’s core dump :
PID: 50736 (pcsx2-qt)
Signal: 11 (SEGV)
Timestamp: Tue 2022-10-25 21:19:02 CEST (37s ago)
Command Line: pcsx2-qt
Executable: /usr/bin/pcsx2-qt
Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-kitty-50672.scope
User Unit: app-gnome-kitty-50672.scope
Boot ID: 8cb324c5ce8748c3b67a3b9a181d38c9
Storage: /var/lib/systemd/coredump/core.pcsx2-qt.1000.8cb324c5ce8748c3b67a3b9a181d38c9.50736.1666725542000000.zst (present)
Disk Size: 807.9K
Message: Process 50736 (pcsx2-qt) of user 1000 dumped core.
Module libnl-3.so.200 with build-id 46f3feeefe77129f1eeaa5f20ddd8561821f1924
Module libnl-genl-3.so.200 with build-id 4d1bfe8da05df88b7314c3f4b7e6547bd6b6b4f4
Module libpcap.so.1 with build-id 4fae575d69deafa5796ba5878a8a661a8b95bb27
Module libSoundTouch.so.2 with build-id 3b96a602637d671c0482c99e105763c1a189a410
Module libzip.so.5 with build-id f8c4b9ffe819d599e0a2465d652a3fd3e40d85a6
Module libryml.so.0.4.1 with build-id 7ab1c3964eee44e78bf767d3a5589cd4e271ecd7
Module libaio.so.1 with build-id f41b69db8468baa07d466cc240c0794b5ff52b92
Module libSDL2-2.0.so.0 with build-id 46afd0f6d4a71c06aa8bce39fb91aa59f031258b
Module libQt6Network.so.6 with build-id 0428be8cf2a7e5d36a8af6f011b3c4fe8cd62267
Module pcsx2-qt with build-id 102922b4b2c0077e07127ac35c580363450775b4
Stack trace of thread 50736:
#0 0x00007f9380d7a47c _ZNK5QFonteqERKS_ (libQt6Gui.so.6 + 0x38547c)
#1 0x00007f9380d7a86e _ZNK5QFontneERKS_ (libQt6Gui.so.6 + 0x38586e)
#2 0x00007f9380b990a2 _ZN15QGuiApplication7setFontERK5QFont (libQt6Gui.so.6 + 0x1a40a2)
#3 0x00007f9379b3297d n/a (libqt6ct.so + 0xb97d)
#4 0x00007f9379b32f2a n/a (libqt6ct.so + 0xbf2a)
#5 0x00007f9380bc4d0d _ZN21QPlatformThemeFactory6createERK7QStringS2_ (libQt6Gui.so.6 + 0x1cfd0d)
#6 0x00007f9380b8b0b0 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt6Gui.so.6 + 0x1960b0)
#7 0x00007f9380b8cbc9 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x197bc9)
#8 0x00007f938059828c _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x12f28c)
#9 0x00007f9380b8cc51 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x197c51)
#10 0x00007f9381916ade _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0x16cade)
#11 0x0000562a1b0ec6d3 n/a (pcsx2-qt + 0xcf6d3)
#12 0x00007f937ff64290 n/a (libc.so.6 + 0x23290)
#13 0x00007f937ff6434a __libc_start_main (libc.so.6 + 0x2334a)
#14 0x0000562a1b0f1ed5 n/a (pcsx2-qt + 0xd4ed5)
Stack trace of thread 50737:
#0 0x00007f938003c0bf __poll (libc.so.6 + 0xfb0bf)
#1 0x00007f937ebec20b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f937ebedccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
#3 0x00007f9379c2b3b2 n/a (libQt6XcbQpa.so.6 + 0x4e3b2)
#4 0x00007f93806eedd1 n/a (libQt6Core.so.6 + 0x285dd1)
#5 0x00007f937ffc78fd n/a (libc.so.6 + 0x868fd)
#6 0x00007f9380049a60 n/a (libc.so.6 + 0x108a60)
EDIT 2:
Looking around I tried to use a debugger on dolphin and PCSX2 and it seem to be a problem with Qt6.
Here’s the output of gdb dolphin-emu
~ >>> gdb dolphin-emu
GNU gdb (GDB) 12.1
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from dolphin-emu...
(No debugging symbols found in dolphin-emu)
(gdb) r
Starting program: /usr/bin/dolphin-emu
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
[New Thread 0x7fffe3cee6c0 (LWP 77849)]
Thread 1 "dolphin-emu" received signal SIGSEGV, Segmentation fault.
0x00007ffff55bf47c in QFont::operator==(QFont const&) const () from /usr/lib/libQt6Gui.so.6
(gdb) bt
#0 0x00007ffff55bf47c in QFont::operator==(QFont const&) const () at /usr/lib/libQt6Gui.so.6
#1 0x00007ffff55bf86e in QFont::operator!=(QFont const&) const () at /usr/lib/libQt6Gui.so.6
#2 0x00007ffff53de0a2 in QGuiApplication::setFont(QFont const&) () at /usr/lib/libQt6Gui.so.6
#3 0x00007fffe3d3a97d in () at /usr/lib/qt6/plugins/platformthemes/libqt6ct.so
#4 0x00007fffe3d3af2a in () at /usr/lib/qt6/plugins/platformthemes/libqt6ct.so
#5 0x00007ffff5409d0d in QPlatformThemeFactory::create(QString const&, QString const&) () at /usr/lib/libQt6Gui.so.6
#6 0x00007ffff53d00b0 in QGuiApplicationPrivate::createPlatformIntegration() () at /usr/lib/libQt6Gui.so.6
#7 0x00007ffff53d1bc9 in QGuiApplicationPrivate::createEventDispatcher() () at /usr/lib/libQt6Gui.so.6
#8 0x00007ffff4ddd28c in QCoreApplicationPrivate::init() () at /usr/lib/libQt6Core.so.6
#9 0x00007ffff53d1c51 in QGuiApplicationPrivate::init() () at /usr/lib/libQt6Gui.so.6
#10 0x00007ffff79afade in QApplicationPrivate::init() () at /usr/lib/libQt6Widgets.so.6
#11 0x0000555555692fbe in ()
#12 0x00007ffff453c290 in () at /usr/lib/libc.so.6
#13 0x00007ffff453c34a in __libc_start_main () at /usr/lib/libc.so.6
#14 0x00005555556b4eb5 in ()
Update:
I saw that a update for qt6-base
was available and it seemed to have fixed the issue.
