Dolphin does not start for 1 or 2 minutes
Hi, again here :slight_smile:
Dolphin does not open immediately. When I launch it, nothing happens for about 1–2 minutes (the cursor shows loading), and then it finally opens and works normally.
I didn’t update my system or change any configuration before this started happening.
journalctl --user -xe | grep dolphin
STDIN
1569 β–‘β–‘
1570 β–‘β–‘ The job identifier is 522.
1571 nov 01 11:38:51 manjaro sudo[4773]:    diego : TTY=pts/1 ; PWD=/home/diego ; USER=root ; COMMAND=/usr/bin/mv /usr/share/dbus-1/services/org.freedesktop.FileManager1.service /usr/share/d
     bus-1/services/org.kde.dolphin.FileManager1.service
1572 nov 01 11:38:51 manjaro sudo[4773]: pam_unix(sudo:session): session opened for user root(uid=0) by diego(uid=1000)
1573 nov 01 11:38:51 manjaro dbus-broker-launch[1720]: Noticed file-system modification, trigger reload.
 ...─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ 8< ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─ ─
1589 β–‘β–‘ reladed again.
1590 nov 01 11:38:51 manjaro sudo[4773]: pam_unix(sudo:session): session closed for user root
1591 nov 01 11:38:51 manjaro dbus-broker-launch[1720]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.File
     Manager1'.
1592 β–‘β–‘ Subject: Invalid service file
1593 β–‘β–‘ Defined-By: dbus-broker
1630 β–‘β–‘ reladed again.
1631 nov 01 11:38:51 manjaro sudo[4793]: pam_unix(sudo:session): session closed for user root
1632 nov 01 11:38:51 manjaro dbus-broker-launch[1720]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.File
     Manager1'.
1633 β–‘β–‘ Subject: Invalid service file
1634 β–‘β–‘ Defined-By: dbus-broker
1690 β–‘β–‘ reladed again.
1691 nov 01 11:38:51 manjaro sudo[4797]: pam_unix(sudo:session): session closed for user root
1692 nov 01 11:38:51 manjaro dbus-broker-launch[1720]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.File
     Manager1'.
1693 β–‘β–‘ Subject: Invalid service file
1694 β–‘β–‘ Defined-By: dbus-broker
1814 β–‘β–‘
1815 β–‘β–‘ The job identifier is 594.
1816 nov 01 11:40:47 manjaro systemd[1703]: app-org.kde.dolphin@78a928ff18c14ea89df9ff5d0cc7b880.service: Consumed 1.059s CPU time, 152.2M memory peak.
1817 β–‘β–‘ Subject: Resources consumed by unit runtime
1818 β–‘β–‘ Defined-By: systemd
My system:
inxi -Fazy
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=e8ad0b83-8ba5-4838-bd74-fb0464854b35 rw
    resume=UUID=f868137e-dac2-4bd8-b260-70ad9aef5f1d udev.log_priority=3
    optimus-manager.startup=hybrid nvidia_drm.modeset=1
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Laptop System: PCSpecialist product: GM6PX0X v: Standard
    serial: <superuser required>
  Mobo: TongFang model: GM6PX0X v: Standard serial: <superuser required>
    part-nu: 0001 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: N.1.09A02 date: 05/15/2023
  ID-1: BAT0 charge: 93.1 Wh (94%) condition: 99.1/99.1 Wh (100%) volts: 16.37
    min: 15.48 model: standard type: Li-ion serial: <filter> charging:
    status: not charging cycles: N/A
  Info: model: 13th Gen Intel Core i9-13900HX bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x12F
  Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
    st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
    KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
  Speed (MHz): avg: 800 min/max: 800/5200:5400:3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
    24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
    bogomips: 154880
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: AIstone Global
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: none off: eDP-1 empty: DP-1, DP-2, HDMI-A-1,
    HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:a788
    class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
    vendor: AIstone Global driver: nvidia v: 580.82.09
    alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    ports: active: none off: DP-3,HDMI-A-5 empty: DP-4,eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:28a0 class-ID: 0300
  Device-3: Trust USB Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 145f:0203
    class-ID: 0102 serial: <filter>
  Device-4: Chicony FHD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 04f2:b7c2
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4520x1920 s-dpi: 110 s-size: 1045x444mm (41.14x17.48")
    s-diag: 1135mm (44.7")
  Monitor-1: not-matched mapped: DP-0 pos: primary,bottom-r res:
    mode: 3440x1440 hz: 160 scale: 100% (1) dpi: 109
    size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
  Monitor-2: not-matched mapped: HDMI-0 pos: top-left res: mode: 1920x1080
    hz: 60 scale: 177% (0.5625) to: 1080x1920 dpi: 94
    size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
  Monitor-3: eDP-1 mapped: eDP-1-1 note: disabled model: BOE Display 0x0a3b
    built: 2021 res: 1920x1080 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 2560x1600
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Laptop
    GPU/PCIe/SSE2 memory: 7.81 GiB
  API: Vulkan v: 1.4.321 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: nvidia v: 580.82.09
    device-ID: 10de:28a0 surfaces: N/A device: 1 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 25.2.3-arch1.2
    device-ID: 8086:a788 surfaces: N/A
  Device-1: Intel Raptor Lake High Definition Audio vendor: AIstone Global
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: NVIDIA AD107 High Definition Audio vendor: AIstone Global
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: AIstone Global driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3a:00.0
  IF: enp58s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  Info: services: NetworkManager,sshd
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.86 TiB used: 698.96 GiB (36.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Solidgm model: SSDPFKNU020TZ
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 28.9 C scheme: GPT
  ID-1: / raw-size: 120 GiB size: 117.81 GiB (98.17%) used: 83.93 GiB (71.2%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 1.34 TiB size: 1.31 TiB (98.35%)
    used: 615.03 GiB (45.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 46.8 C mobo: N/A gpu: nvidia temp: 40 C
  Fan Speeds (rpm): N/A
  Memory: total: 64 GiB note: est. available: 62.53 GiB used: 5.48 GiB (8.8%)
  Processes: 551 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 24.98 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1833 pm: pacman pkgs: 1759 libs: 425 tools: pamac,yay pm: flatpak
    pkgs: 60 pm: snap pkgs: 14 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh
    v: 5.9 running-in: kitty inxi: 3.3.39
Any idea?
Thanks!
Hi @ZeR0ByTe,
My first thought when I read this was Network mount. So double-check that if you have any.
Another thing I can think of is a disc problem, so check your disc health:
sudo smartctl -x /dev/nvme0
The last folder you had open was a network folder on another network.
I have a Samba mounted to my RaspberryPi. But I had never problems with it. I don’t know if the problem can be Tailscale (VPN). I have two accounts one self-hosted (headscale) and another one for my work. Just in case
//192.168.1.88/data on /mnt/raspberryPi type cifs (rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.88,file_mode=0755,dir_mode=0755,iocharset=utf8,soft,nounix,serverino,mapposix,reparse=nfs,rsize=4194304,wsize=4194304,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1,_netdev,x-systemd.automount,x-systemd.idle-timeout=30,x-systemd.mount-timeout=5)
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.12.48-1-MANJARO] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       SOLIDIGM SSDPFKNU020TZ
Serial Number:                      PHEH315101M72P0C
Firmware Version:                   002C
PCI Vendor/Subsystem ID:            0x025e
IEEE OUI Identifier:                0xc8d6b7
Controller ID:                      1
NVMe Version:                       1.4
Number of Namespaces:               1
Namespace 1 Size/Capacity:          2.048.408.248.320 [2,04 TB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Sat Nov  1 12:07:04 2025 CET
Firmware Updates (0x14):            2 Slots, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x00df):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp Verify
Log Page Attributes (0x1f):         S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Pers_Ev_Lg
Maximum Data Transfer Size:         128 Pages
Warning  Comp. Temp. Threshold:     77 Celsius
Critical Comp. Temp. Threshold:     80 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     5.50W       -        -    0  0  0  0        0       0
 1 +     3.60W       -        -    1  1  1  1     4000    5000
 2 +     2.60W       -        -    2  2  2  2    22000   37000
 3 -   0.0250W       -        -    3  3  3  3      225    2000
 4 -   0.0040W       -        -    4  4  4  4     3000   11999
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
 1 -    4096       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02, NSID 0xffffffff)
Critical Warning:                   0x00
Temperature:                        29 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    1%
Data Units Read:                    20.826.264 [10,6 TB]
Data Units Written:                 26.560.462 [13,5 TB]
Host Read Commands:                 278.247.446
Host Write Commands:                331.767.529
Controller Busy Time:               3.687
Power Cycles:                       1.104
Power On Hours:                     3.655
Unsafe Shutdowns:                   49
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
Self-test Log (NVMe Log 0x06, NSID 0xffffffff)
Self-test status: No self-test in progress
No Self-tests Logged
Maybe my RaspberryPi?
Thanks
Might be that. Try commenting the line out of fstab, and see if it helps. If it does the problem is something related to the mount.
When you are connected to vpn - you loose connection to local devices - so your raspberrypi data share will no longer be accessible.
The behavior is normal and expected.
I will try it but only happens when I init the laptop. After that it’s working perfectly.
It’s weird because my raspberry pi has the same software installed (tailscale), my laptop and raspberry pi shared the same vpn it’s not different. Should be ok, right?
Maybe I should change the IP to: 100.64.0.1 (This is the Raspberry IP in Tailscale), right?
I have no idea what you are talking about.
If your raspberry pi and your laptop should be able to connect using a vpn network - then you will have to look at your vpn configuraiton(s) - tailscale is outside my experience.
I had a similar problem.
You could try this:
https://forum.manjaro.org/t/dolphin-wont-start-up/180644/4
