In a plain install of Manjaro KDE Nibia 20.2, every few minutes the following things happen (video time codes provided);
- Taskbar lockup, can’t click Start button or any task buttons: 1:18
- Dolphin browser lockup: 4:30
- Force close Dolphin browser at 4:50
- Frozen taskbar recovered by closing other Dolphin windows: 5:37
I recorded live for about 6 minutes and was able to reproduce all the above problems. Fingers crossed you guys know some random thing I can type into the terminal to fix all this… ![]()
[domarius@domarius-manjaro ~]$ inxi -Fazy
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=80d8c5eb-8161-42e6-91d4-c18148131aad rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: Z170-AR v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 3801 date: 03/14/2018
Device-1: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 100%
rechargeable: yes status: Discharging
Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 64026
Speed: 4200 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4201 2: 4200
3: 4200 4: 4200 5: 4200 6: 4200 7: 4201 8: 4200
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Gigabyte
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f06
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1200 s-dpi: 93 s-size: 983x321mm (38.7x12.6")
s-diag: 1034mm (40.7")
Monitor-1: HDMI-0 res: 1680x1050 hz: 60 dpi: 99 size: 430x270mm (16.9x10.6")
diag: 508mm (20")
Monitor-2: DP-3 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
OpenGL: renderer: GeForce RTX 2060 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA TU106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: Audio-Technica AT2020USB+ type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-14:7 chip ID: 0909:001c
Device-4: Microsoft LifeChat LX-3000 Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1:2 chip ID: 045e:070f
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
bus ID: 1-9:3 chip ID: 045e:0719 serial: <filter>
Local Storage: total: 8.64 TiB used: 7.32 TiB (84.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST31000528AS size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC38 scheme: MBR
ID-3: /dev/sdb vendor: Seagate model: ST2000DL003-9VT166 size: 1.82 TiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: 5900 rpm serial: <filter> rev: CC32 scheme: MBR
ID-4: /dev/sdc vendor: Seagate model: ST3000DM007-1WY10G size: 2.73 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
ID-5: /dev/sdd type: USB vendor: Hitachi model: G ST size: 2.73 TiB
block size: physical: 4096 B logical: 4096 B serial: <filter> rev: 0000
scheme: MBR
ID-1: / raw size: 50.00 GiB size: 48.97 GiB (97.93%) used: 20.14 GiB (41.1%)
fs: ext4 dev: /dev/nvme0n1p5
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 55 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 243 Uptime: 1h 16m Memory: 31.30 GiB used: 2.97 GiB (9.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
pacman: 1380 lib: 390 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
