Dolphin bookmarks - not accepting a context input in the menu
I’m curious (and seriously doubt) that anyone might have this issue. It appears to be another ghost in the machine.
I have Dolphin set up nicely, using Places and quite a number of bookmarks.
So to start with, just open a random folder - or dual pane two folders, then save them as bookmarks.
Then try to delete those bookmarks via context click - it usually pulls up a context menu… but it’s not something I do every day and I just realised that I cannot do this - I have to open an editor to remove a bookmark.
The context click simply opens the bookmark… there’s no context menu.
Troubleshooting:
  1. Tested with an ISO - behaves as expected, not a default issue.
  2. Created a new user ‘nOOb’ and verified - bug exists with new user.
So, given that the issue doesn’t lie with the USER files, how can I figure this out?
inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.12.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=a0074377-fd97-4125-9151-1b09cc8e32cb rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.9.0
    wm: kwin_wayland with: krunner vt: 7 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550M Steel Legend
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: P2.30 date: 02/24/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
    status: discharging
  System RAM: total: 16 GiB available: 15 GiB used: 6.07 GiB (40.4%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3600C17D4/8GX serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500011
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2994 min/max: 400/4464 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2994 2: 2994 3: 2994
    4: 2994 5: 2994 6: 2994 7: 2994 8: 2994 9: 2994 10: 2994 11: 2994 12: 2994
    bogomips: 93466
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1,DP-2
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 41.0 C
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.59 6.12.5-2-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :0.0
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
    surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.5-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  Info: services: NetworkManager, smbd, systemd-timesyncd
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.2:4
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 8.42 TiB used: 5.15 TiB (61.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MD04ACA400
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA300
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 vendor: SanDisk model: Cruzer Blade
    size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
    scheme: MBR
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 147.27 GiB (64.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: a0074377-fd97-4125-9151-1b09cc8e32cb
    used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: F99D-EAF9
  ID-3: /mnt/T3 raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
    used: 1.74 TiB (64.6%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: T3
    uuid: ee9f99fa-d221-4123-adaf-83d1076e1e00
  ID-4: /mnt/T4 raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 1.94 TiB (54.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: T4
    uuid: 1e85632e-1c5f-4da4-a229-e349fba9efc9
  ID-5: /mnt/W2 raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.33 TiB (73.2%) fs: btrfs dev: /dev/sdd1 maj-min: 8:49 label: W2
    uuid: 7a89257a-6b14-46ba-85d9-55f079184774
  ID-1: swap-1 type: file size: 512 MiB used: 137 MiB (26.8%) priority: -2
    file: /swapfile
  ID-1: /dev/sde1 maj-min: 8:65 size: 7.42 GiB fs: exfat label: Ventoy
    uuid: F994-3B47
  ID-2: /dev/sde2 maj-min: 8:66 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 3F32-27F5
  Hub-2: 1-7:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.1:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-8:3 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-2.1:3 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Device-2: 3-2.2:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
    class-ID: e001
  Device-3: 3-2.4:5 info: Areson Corp 2.4G Receiver type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): N/A
  Packages: 2483 pm: pacman pkgs: 2464 libs: 555 tools: pamac,paru,yay
    pm: flatpak pkgs: 19
  Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
    1: https://cdn-mirror.chaotic.cx/$repo/$arch
    2: https://geo-mirror.chaotic.cx/$repo/$arch
    3: https://br-mirror.chaotic.cx/$repo/$arch
    4: https://bg-mirror.chaotic.cx/$repo/$arch
    5: https://ca-mirror.chaotic.cx/$repo/$arch
    6: https://cl-mirror.chaotic.cx/$repo/$arch
    7: https://de-2-mirror.chaotic.cx/$repo/$arch
    8: https://de-3-mirror.chaotic.cx/$repo/$arch
    9: https://de-4-mirror.chaotic.cx/$repo/$arch
    10: https://fr-mirror.chaotic.cx/$repo/$arch
    11: https://gr-mirror.chaotic.cx/$repo/$arch
    12: https://in-mirror.chaotic.cx/$repo/$arch
    13: https://in-2-mirror.chaotic.cx/$repo/$arch
    14: https://in-3-mirror.chaotic.cx/$repo/$arch
    15: https://in-4-mirror.chaotic.cx/$repo/$arch
    16: https://kr-mirror.chaotic.cx/$repo/$arch
    17: https://es-mirror.chaotic.cx/$repo/$arch
    18: https://es-2-mirror.chaotic.cx/$repo/$arch
    19: https://us-mi-mirror.chaotic.cx/$repo/$arch
    20: https://us-tx-mirror.chaotic.cx/$repo/$arch
    21: https://us-ut-mirror.chaotic.cx/$repo/$arch
    1: https://mirrors2.manjaro.org/testing/$repo/$arch
    2: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    3: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 351
  1: cpu: 5.6% command: firefox pid: 64914 mem: 640.4 MiB (4.1%)
  2: cpu: 3.4% command: firefox pid: 73976 mem: 258.8 MiB (1.6%)
  3: cpu: 2.4% command: kwin_wayland pid: 63687 mem: 433.6 MiB (2.8%)
  4: cpu: 2.2% command: firefox pid: 65126 mem: 362.1 MiB (2.3%)
  5: cpu: 2.2% command: firefox pid: 67053 mem: 370.0 MiB (2.4%)
  Memory top: 5 of 351
  1: mem: 640.4 MiB (4.1%) command: firefox pid: 64914 cpu: 5.6%
  2: mem: 555.2 MiB (3.6%) command: plasmashell pid: 63913 cpu: 0.7%
  3: mem: 550.3 MiB (3.5%) command: telegram-desktop pid: 64234 cpu: 0.0%
  4: mem: 433.6 MiB (2.8%) command: kwin_wayland pid: 63687 cpu: 2.4%
  5: mem: 402.6 MiB (2.6%) command: firefox pid: 65237 cpu: 0.8%
  Processes: 351 Power: uptime: 3h 27m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: fish v: 3.7.1 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.36
I have a few journal entries:
`journalctl -p3 -xb --nohostname`
journalctl -p3 -xb
Dec 21 13:18:47 SteelLegend kernel: Bluetooth: hci0: unexpected event for opcode 0x0000
Dec 21 13:18:51 SteelLegend systemd[846]: pacnew-checker.path: Job paths.target/start deleted to break ordering cycle starting with pacnew-checker.path/start
Dec 21 13:19:12 SteelLegend systemd[1187]: basic.target: Job paths.target/start deleted to break ordering cycle starting with basic.target/start
Dec 21 13:19:14 SteelLegend org_kde_powerdevil[1578]: busno=0, sleep-multiplier =  1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, cause>
Dec 21 13:20:23 SteelLegend bluetoothd[734]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free unit: getpeername: Transport endpoint is not connected (107)
lines 1-5/5 (END)
So who’s up for a challenge? This is a bit weird…
I think you’re simply meant to use the menu… :point_down:
Go → Bookmarks → Edit Bookmarks
:man_shrugging:
No - from the Live USB session I verified this, you can right click and remove a single bookmark…
Can you not do this either?
Indeed, it doesn’t work here either.
So this is likely an issue with Installed Manjaro (not present on the ISO)!
I’ve been trying to figure it out for the last 4 hours already :rofl:
If the functionality is present on the ISO - it should be present on the installed system.
However - it may be an issue which only appears after the system is updated and as such it becomes an upstream issue.
  • I don’t even have the edit bookmark …
  • I am thinking the bookmark functionality is related to a functional baloo indexer …
  • Nope - not that …
Edit Bookmarks is an option available in the settings if you edit your toolbar - but that’s interesting, now I’m tempted to install to a virtual machine from the ISO and see how that goes.
Not even that …
Stable Manjaro on bare-metal, synced with release on 24-12-16 …
Syncing keditbookmarks package gave me the Edit Bookmarks… command which opens the Bookmark Editor (possibly caused by the minimal edition used).
The Bookmarks Editor - at first glance - does not add context action to the Go → Bookmarks menu items.
After looking around - I don’t think the Bookmarks menu listing bookmarked items is intended to provide a context-click.
Yes, I looked at that thread - then today mentioned it to a fedora user who argued with me - then sent this screenshot today:
Fedora40
Strange that it would only work on Manjaro’s live session… or fresh install.
Indeed - still pointing to some kind of regression - but where … ?
The subseqent missing functionality points to something happening during the first system sync.
This seems to work as expected for me. Choosing Add Bookmark creates the expected bookmark of whatever directory is current in Dolphin.
At the risk of invoking a Troubleshooting 101 scenario, have you tested this in a fresh User account?
Creating a fresh account doesn’t change things, but the live USB session - you can right click a bookmark and get the delete option.
I’m booting it up again as we speak…
Live
However, if you go into the Bookmark menu, hover a bookmark, you should be able to RIGHT click to call up the context, but on my install, right click does the same as left.
I can’t install this ISO - I got the same message this time as last, maybe I should get a fresh one.
All I have is Edit Bookmarks which opens the Bookmark Editor – from there, I can right-click any previously created bookmark and Delete. Deactivated my Global Panel extension in case that might have interfered, but still remains as described.
I’ve never known there to be a secondary context menu, but I have to admit, it seems much more intuitive for there to be one.
I just booted in a vm the latest full ISO from 24-12-16.
The context action on a bookmark - Go → Bookmarks - does not exist.
The keditbookmarks package is not available on live ISO.
Syncing the package and reopeing dolphin makes it possible to edit bookmarks - still no context menu.
Likely some version differences between Fedora and Manjaro.
Haha it looks as if you never will.
  • This worked with the previous Manjaro-kde-24.1 ISO, screenshot above - also with Fedora 40 (likely an older Plasma)…
  • manjaro-kde-24.2.1-241216-linux612: this function is removed.
  • RMB and LMB now have the same behaviour, the context is not available… so you have to open the editor…
If you do this often, I suggest you go into the keyboard settings (Dolphin) pressing CtrlAlt,
Search ‘edit’ to find ‘Bookmark Editor’ and set a shortcut. I set CtrlAltB for now… because CtrlB adds a bookmark it seems an easy one to remember…
So this is indeed a regression of sorts - a very intuitive interaction has disappeared.
So the solution is to stick the editor icon next to it (and make it a pencil, because that icon sucked).
Screenshot_20241221_190413
For the old-schoolers maybe
Méven Car identifies this as a ‘small bug’;
but no specifics were given in the following article:
It seems to not be a new discovery. Still, if the context works on Fedora, that suggests someone has found a quick fix at some point.
I simply added Bookmarks to the Dolphin toolbar; it saves an unnecessary click and hover.
