Games based on api vulkan don’t work
System specifications:
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9771d547-db18-4863-b04c-f93464b4c88e rw quiet
resume=UUID=cfd3f574-a521-45cd-956b-8ae7115695aa udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: OMEN by HP Laptop v: N/A
Mobo: HP model: 8469 v: 68.21 serial: <superuser required> UEFI: AMI
v: F.09 date: 04/24/2019
ID-1: BAT0 charge: 7.0 Wh (71.4%) condition: 9.8/9.8 Wh (100.0%) volts: 15.5
min: 14.6 model: HP Primary type: Li-ion serial: N/A status: N/A
RAM: total: 7.58 GiB used: 1.1 GiB (14.6%)
RAM Report:
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c
flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify
ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear
mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Realtek HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0bda:58eb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 68.17 GiB (7.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
type: HDD rpm: 7200 serial: <filter> rev: RXM3 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 68.13 GiB (7.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9771d547-db18-4863-b04c-f93464b4c88e
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 3031-73DD
ID-1: swap-1 type: partition size: 8.8 GiB used: 45.5 MiB (0.5%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: cfd3f574-a521-45cd-956b-8ae7115695aa
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-6:2 info: Realtek HP Wide Vision HD Camera type: Video
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C pch: 43.0 C mobo: N/A
Processes: 227 Uptime: 11h 22m wakeups: 2 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1012 lib: 295
Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
So i read a bit wiki and installed it via commands
sudo pacman -Syu vulkan-icd-loader
sudo pacman -Syu vulkan-validation-layer
sudo pacman -Syu vulkan-tools
to check it type in terminal vulkaninfo
and other aditional just in case
[mariam@mariam-omenbyhplaptop ~]$ sudo pacman -Syu vulkan-icd-loader
[sudo] password for mariam:
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: vulkan-icd-loader-1.2.202-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) vulkan-icd-loader-1.2.202-1
Total Installed Size: 0,46 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
vulkan-icd-loader-1.2.202-1-x86_64 is up to date
(1/1) checking keys in keyring [####################################################################] 100%
(1/1) checking package integrity [####################################################################] 100%
(1/1) loading package files [####################################################################] 100%
(1/1) checking for file conflicts [####################################################################] 100%
(1/1) checking available disk space [####################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling vulkan-icd-loader [####################################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
[mariam@mariam-omenbyhplaptop ~]$ sudo pacman -Syu vulkan-headers
core is up to date
extra is up to date
Packages (1) vulkan-headers-1:1.2.202-1
Total Download Size: 0,81 MiB
Total Installed Size: 15,07 MiB
vulkan-headers-1:1.2.202-1-any 833,0 KiB 1232 KiB/s 00:01 [####################################################################] 100%
(1/1) installing vulkan-headers [####################################################################] 100%
[mariam@mariam-omenbyhplaptop ~]$ sudo pacman -Syu vulkan-validation-layers
core is up to date
extra is up to date
Packages (1) vulkan-validation-layers-1.2.199-1
Total Download Size: 87,38 MiB
Total Installed Size: 367,28 MiB
vulkan-validation-layers-1.2.199-1-x86_64 87,4 MiB 789 KiB/s 01:53 [####################################################################] 100%
(1/1) installing vulkan-validation-layers [####################################################################] 100%
[mariam@mariam-omenbyhplaptop ~]$ sudo pacman -Syu vulkan-tools
core is up to date
extra is up to date
Packages (1) vulkan-tools-1.2.199-1
Total Download Size: 0,24 MiB
Total Installed Size: 1,12 MiB
vulkan-tools-1.2.199-1-x86_64 242,8 KiB 582 KiB/s 00:00 [####################################################################] 100%
(1/1) installing vulkan-tools [####################################################################] 100%
[mariam@mariam-omenbyhplaptop ~]$ vulkaninfo
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
VULKANINFO
Vulkan Instance Version: 1.2.202
Instance Extensions: count = 19
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 6
VK_LAYER_KHRONOS_validation (Khronos Validation Layer) Vulkan version 1.2.199, layer version 1:
Layer Extensions: count = 3
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 1
VK_EXT_validation_features : extension revision 2
Devices: count = 2
GPU id = 0 (NVIDIA GeForce GTX 1050)
Layer-Device Extensions: count = 3
VK_EXT_debug_marker : extension revision 4
VK_EXT_tooling_info : extension revision 1
VK_EXT_validation_cache : extension revision 1
GPU id = 1 (Intel(R) UHD Graphics 630 (CFL GT2))
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.186, layer version 1:
Layer Extensions: count = 0
Devices: count = 2
Layer-Device Extensions: count = 0
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 2
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 2
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 2
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 2
Presentable Surfaces:
GPU id : 0 (NVIDIA GeForce GTX 1050):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_UNORM
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_SRGB
Present Modes: count = 3
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
PRESENT_MODE_IMMEDIATE_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 2
maxImageCount = 8
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 1
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
supportedUsageFlags: count = 6
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
GPU id : 1 (Intel(R) UHD Graphics 630 (CFL GT2)):
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
SurfaceFormat[1]:
Present Modes: count = 4
PRESENT_MODE_MAILBOX_KHR
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 5
None
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
NVIDIA GeForce GTX 1050 (ID: 0)
subsetAllocation = 0
Present Capabilities:
NVIDIA GeForce GTX 1050 (ID: 0):
Can present images from the following devices: count = 1
Present modes: count = 1
DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Group 1:
Properties:
Intel(R) UHD Graphics 630 (CFL GT2) (ID: 0)
Intel(R) UHD Graphics 630 (CFL GT2) (ID: 0):
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4202682 (1.2.186)
driverVersion = 2076901376 (0x7bcb0000)
vendorID = 0x10de
deviceID = 0x1c8d
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = NVIDIA GeForce GTX 1050
pipelineCacheUUID = 31bf712c-e972-10e2-2d3a-14b93a604791
VkPhysicalDeviceLimits:
maxImageDimension1D = 32768
maxImageDimension2D = 32768
maxImageDimension3D = 16384
maxImageDimensionCube = 32768
maxImageArrayLayers = 2048
maxTexelBufferElements = 134217728
maxUniformBufferRange = 65536
maxStorageBufferRange = 4294967295
maxPushConstantsSize = 256
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 4000
bufferImageGranularity = 0x00000400
sparseAddressSpaceSize = 0xffffffffff
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 1048576
maxPerStageDescriptorUniformBuffers = 15
maxPerStageDescriptorStorageBuffers = 1048576
maxPerStageDescriptorSampledImages = 1048576
maxPerStageDescriptorStorageImages = 1048576
maxPerStageDescriptorInputAttachments = 1048576
maxPerStageResources = 4294967295
maxDescriptorSetSamplers = 1048576
maxDescriptorSetUniformBuffers = 90
maxDescriptorSetUniformBuffersDynamic = 15
maxDescriptorSetStorageBuffers = 1048576
maxDescriptorSetStorageBuffersDynamic = 16
maxDescriptorSetSampledImages = 1048576
maxDescriptorSetStorageImages = 1048576
maxDescriptorSetInputAttachments = 1048576
maxVertexInputAttributes = 32
maxVertexInputBindings = 32
maxVertexInputAttributeOffset = 2047
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 120
maxTessellationControlTotalOutputComponents = 4216
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 128
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 1024
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 128
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 4294967295
maxComputeSharedMemorySize = 49152
maxComputeWorkGroupCount: count = 3
2147483647
65535
65535
maxComputeWorkGroupInvocations = 1536
maxComputeWorkGroupSize: count = 3
1536
1024
64
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 15
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
32768
32768
viewportBoundsRange: count = 2
-65536
65536
viewportSubPixelBits = 8
minMemoryMapAlignment = 64
minTexelBufferOffsetAlignment = 0x00000010
minUniformBufferOffsetAlignment = 0x00000100
minStorageBufferOffsetAlignment = 0x00000010
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 32768
maxFramebufferHeight = 32768
maxFramebufferLayers = 2048
framebufferColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferNoAttachmentsSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
storageImageSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 1
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
1
2047.94
lineWidthRange: count = 2
1
64
pointSizeGranularity = 0.0625
lineWidthGranularity = 0.0625
strictLines = true
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000001
optimalBufferCopyRowPitchAlignment = 0x00000001
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = true
residencyStandard2DMultisampleBlockShape = true
residencyStandard3DBlockShape = true
residencyAlignedMipSize = false
residencyNonResidentStrict = true
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
advancedBlendMaxColorAttachments = 8
advancedBlendIndependentBlend = false
advancedBlendNonPremultipliedSrcColor = true
advancedBlendNonPremultipliedDstColor = true
advancedBlendCorrelatedOverlap = true
advancedBlendAllOperations = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
primitiveOverestimationSize = 0
maxExtraPrimitiveOverestimationSize = 0.75
extraPrimitiveOverestimationSizeGranularity = 0.25
primitiveUnderestimation = false
conservativePointAndLineRasterization = true
degenerateTrianglesRasterized = true
degenerateLinesRasterized = false
fullyCoveredFragmentShaderInputVariable = false
conservativeRasterizationPostDepthCoverage = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
maxCustomBorderColorSamplers = 4000
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 3
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 4294967295
shaderUniformBufferArrayNonUniformIndexingNative = true
shaderSampledImageArrayNonUniformIndexingNative = true
shaderStorageBufferArrayNonUniformIndexingNative = true
shaderStorageImageArrayNonUniformIndexingNative = true
shaderInputAttachmentArrayNonUniformIndexingNative = true
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = true
maxPerStageDescriptorUpdateAfterBindSamplers = 1048576
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 15
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 1048576
maxPerStageDescriptorUpdateAfterBindSampledImages = 1048576
maxPerStageDescriptorUpdateAfterBindStorageImages = 1048576
maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
maxPerStageUpdateAfterBindResources = 4294967295
maxDescriptorSetUpdateAfterBindSamplers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffers = 90
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
maxDescriptorSetUpdateAfterBindStorageBuffers = 1048576
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
maxDescriptorSetUpdateAfterBindSampledImages = 1048576
maxDescriptorSetUpdateAfterBindStorageImages = 1048576
maxDescriptorSetUpdateAfterBindInputAttachments = 1048576
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
maxDiscardRectangles = 8
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 495.44
conformanceVersion = 1.2.6.1
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 1
renderMajor = 226
renderMinor = 129
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = true
shaderDenormPreserveFloat32 = false
shaderDenormPreserveFloat64 = false
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = false
shaderDenormFlushToZeroFloat64 = false
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = false
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceIDProperties:
deviceUUID = 4f748193-b96e-1bc2-85b4-ac54e4d37309
driverUUID = 77a1b102-7c87-5864-beec-846253941470
deviceNodeMask = 1
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
maxInlineUniformBlockSize = 256
maxPerStageDescriptorInlineUniformBlocks = 32
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
maxDescriptorSetInlineUniformBlocks = 32
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 8
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 4294967295
maxMemoryAllocationSize = 0xffe00000
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 4294967295
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 32
maxMultiviewInstanceIndex = 134217727
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 1
pciDevice = 0
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000001
robustUniformBufferAccessSizeAlignment = 0x00000100
VkPhysicalDeviceSampleLocationsPropertiesEXT:
sampleLocationSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
maxSampleLocationGridSize:
width = 1
height = 1
sampleLocationCoordinateRange: count = 2
0
0.9375
sampleLocationSubPixelBits = 4
variableSampleLocations = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = true
filterMinmaxImageComponentMapping = true
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 32
supportedStages: count = 8
SHADER_STAGE_VERTEX_BIT
SHADER_STAGE_TESSELLATION_CONTROL_BIT
SHADER_STAGE_TESSELLATION_EVALUATION_BIT
SHADER_STAGE_GEOMETRY_BIT
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
SHADER_STAGE_ALL_GRAPHICS
SHADER_STAGE_ALL
supportedOperations: count = 9
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_ARITHMETIC_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_CLUSTERED_BIT
SUBGROUP_FEATURE_QUAD_BIT
SUBGROUP_FEATURE_PARTITIONED_BIT_NV
quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
minSubgroupSize = 32
maxSubgroupSize = 32
maxComputeWorkgroupSubgroups = 3145728
requiredSubgroupSizeStages: count = 8
SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
storageTexelBufferOffsetAlignmentBytes = 0x00000010
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000010
uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 2147483647
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0xffffffffffffffff
maxTransformFeedbackStreamDataSize = 2048
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 2048
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = false
transformFeedbackRasterizationStreamSelect = true
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 1
subgroupSize = 32
subgroupSupportedStages: count = 8
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 9
subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
driverName = NVIDIA
driverInfo = 495.44
framebufferIntegerColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
Device Extensions: count = 123
VK_EXT_4444_formats : extension revision 1
VK_EXT_blend_operation_advanced : extension revision 2
VK_EXT_buffer_device_address : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_custom_border_color : extension revision 12
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_fragment_shader_interlock : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_global_priority_query : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_robustness : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 2
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_image_atomic_int64 : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_vertex_input_dynamic_state : extension revision 2
VK_EXT_ycbcr_2plane_444_formats : extension revision 1
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_present_id : extension revision 1
VK_KHR_present_wait : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_extended_types : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_synchronization2 : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NVX_multiview_per_view_attributes : extension revision 1
VK_NV_clip_space_w_scaling : extension revision 1
VK_NV_coverage_reduction_mode : extension revision 1
VK_NV_dedicated_allocation : extension revision 1
VK_NV_dedicated_allocation_image_aliasing : extension revision 1
VK_NV_device_diagnostic_checkpoints : extension revision 2
VK_NV_device_diagnostics_config : extension revision 1
VK_NV_device_generated_commands : extension revision 3
VK_NV_fill_rectangle : extension revision 1
VK_NV_fragment_coverage_to_color : extension revision 1
VK_NV_framebuffer_mixed_samples : extension revision 1
VK_NV_geometry_shader_passthrough : extension revision 1
VK_NV_inherited_viewport_scissor : extension revision 1
VK_NV_sample_mask_override_coverage : extension revision 1
VK_NV_shader_sm_builtins : extension revision 1
VK_NV_shader_subgroup_partitioned : extension revision 1
VK_NV_viewport_array2 : extension revision 1
VK_NV_viewport_swizzle : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 16
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
timestampValidBits = 64
present support = true
queueProperties[1]:
queueCount = 2
queueFlags = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
present support = false
queueProperties[2]:
queueCount = 8
queueFlags = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
memoryHeaps[0]:
size = 4294967296 (0x100000000) (4.00 GiB)
budget = 4229169152 (0xfc140000) (3.94 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryHeaps[1]:
size = 6101256192 (0x16ba9c800) (5.68 GiB)
budget = 6101256192 (0x16ba9c800) (5.68 GiB)
flags:
None
memoryHeaps[2]:
size = 257949696 (0x0f600000) (246.00 MiB)
budget = 252641280 (0x0f0f0000) (240.94 MiB)
usage = 5308416 (0x00510000) (5.06 MiB)
flags: count = 1
memoryTypes: count = 11
memoryTypes[0]:
heapIndex = 1
propertyFlags = 0x0000:
None
usable for:
IMAGE_TILING_OPTIMAL:
None
IMAGE_TILING_LINEAR:
color images
(non-sparse, non-transient)
memoryTypes[1]:
heapIndex = 1
None
usable for:
color images
None
memoryTypes[2]:
heapIndex = 1
None
usable for:
FORMAT_D16_UNORM
None
memoryTypes[3]:
heapIndex = 1
None
usable for:
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D24_UNORM_S8_UINT
None
memoryTypes[4]:
heapIndex = 1
None
usable for:
FORMAT_D32_SFLOAT
None
memoryTypes[5]:
heapIndex = 1
None
usable for:
FORMAT_D32_SFLOAT_S8_UINT
None
memoryTypes[6]:
heapIndex = 1
None
usable for:
FORMAT_S8_UINT
None
memoryTypes[7]:
heapIndex = 0
propertyFlags = 0x0001: count = 1
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[8]:
heapIndex = 1
propertyFlags = 0x0006: count = 2
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
usable for:
None
color images
memoryTypes[9]:
heapIndex = 1
propertyFlags = 0x000e: count = 3
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
None
color images
memoryTypes[10]:
heapIndex = 2
propertyFlags = 0x0007: count = 3
usable for:
None
color images
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = true
shaderStorageImageReadWithoutFormat = true
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = true
shaderInt64 = true
shaderInt16 = true
shaderResourceResidency = true
shaderResourceMinLod = true
sparseBinding = true
sparseResidencyBuffer = true
sparseResidencyImage2D = true
sparseResidencyImage3D = true
sparseResidency2Samples = true
sparseResidency4Samples = true
sparseResidency8Samples = true
sparseResidency16Samples = true
sparseResidencyAliased = true
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = true
uniformAndStorageBuffer8BitAccess = true
storagePushConstant8 = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
advancedBlendCoherentOperations = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = true
bufferDeviceAddressCaptureReplay = false
bufferDeviceAddressMultiDevice = true
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
customBorderColors = true
customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = true
shaderUniformTexelBufferArrayDynamicIndexing = true
shaderStorageTexelBufferArrayDynamicIndexing = true
shaderUniformBufferArrayNonUniformIndexing = true
shaderSampledImageArrayNonUniformIndexing = true
shaderStorageBufferArrayNonUniformIndexing = true
shaderStorageImageArrayNonUniformIndexing = true
shaderInputAttachmentArrayNonUniformIndexing = true
shaderUniformTexelBufferArrayNonUniformIndexing = true
shaderStorageTexelBufferArrayNonUniformIndexing = true
descriptorBindingUniformBufferUpdateAfterBind = false
descriptorBindingSampledImageUpdateAfterBind = true
descriptorBindingStorageImageUpdateAfterBind = true
descriptorBindingStorageBufferUpdateAfterBind = true
descriptorBindingUniformTexelBufferUpdateAfterBind = true
descriptorBindingStorageTexelBufferUpdateAfterBind = true
descriptorBindingUpdateUnusedWhilePending = true
descriptorBindingPartiallyBound = true
descriptorBindingVariableDescriptorCount = true
runtimeDescriptorArray = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = true
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
fragmentShaderSampleInterlock = true
fragmentShaderPixelInterlock = true
fragmentShaderShadingRateInterlock = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesEXT:
globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = true
bresenhamLines = true
smoothLines = true
stippledRectangularLines = true
stippledBresenhamLines = true
stippledSmoothLines = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePresentIdFeaturesKHR:
presentId = true
VkPhysicalDevicePresentWaitFeaturesKHR:
presentWait = true
VkPhysicalDevicePrivateDataFeaturesEXT:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = true
shaderBufferFloat64Atomics = true
shaderBufferFloat64AtomicAdd = true
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = true
shaderSharedFloat64Atomics = true
shaderSharedFloat64AtomicAdd = true
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = true
sparseImageFloat32Atomics = true
sparseImageFloat32AtomicAdd = true
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = true
shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = false
shaderInt8 = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
shaderImageInt64Atomics = true
sparseImageInt64Atomics = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceSynchronization2FeaturesKHR:
synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVertexInputDynamicStateFeaturesEXT:
vertexInputDynamicState = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = true
descriptorIndexing = true
samplerFilterMinmax = true
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = true
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcr2Plane444FormatsFeaturesEXT:
ycbcr2plane444Formats = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
shaderZeroInitializeWorkgroupMemory = true
GPU1:
apiVersion = 4202678 (1.2.182)
driverVersion = 88088581 (0x5402005)
vendorID = 0x8086
deviceID = 0x3e9b
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = Intel(R) UHD Graphics 630 (CFL GT2)
pipelineCacheUUID = 8832e7a7-e6dc-73f8-a00b-2ab9df390573
maxImageDimension1D = 16384
maxImageDimension2D = 16384
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxUniformBufferRange = 134217728
maxStorageBufferRange = 1073741824
maxPushConstantsSize = 128
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000040
sparseAddressSpaceSize = 0x00000000
maxBoundDescriptorSets = 8
maxPerStageDescriptorSamplers = 65535
maxPerStageDescriptorUniformBuffers = 64
maxPerStageDescriptorStorageBuffers = 65535
maxPerStageDescriptorSampledImages = 65535
maxPerStageDescriptorStorageImages = 65535
maxPerStageDescriptorInputAttachments = 64
maxDescriptorSetSamplers = 393210
maxDescriptorSetUniformBuffers = 384
maxDescriptorSetUniformBuffersDynamic = 8
maxDescriptorSetStorageBuffers = 393210
maxDescriptorSetStorageBuffersDynamic = 8
maxDescriptorSetSampledImages = 393210
maxDescriptorSetStorageImages = 393210
maxDescriptorSetInputAttachments = 256
maxVertexInputAttributes = 28
maxVertexInputBindings = 28
maxTessellationControlPerPatchOutputComponents = 128
maxTessellationControlTotalOutputComponents = 2048
maxGeometryOutputVertices = 256
maxFragmentInputComponents = 116
maxFragmentCombinedOutputResources = 8
maxComputeSharedMemorySize = 65536
65535
65535
65535
maxComputeWorkGroupInvocations = 1792
1792
1792
1792
maxSamplerLodBias = 16
maxViewports = 16
16384
16384
-32768
32767
viewportSubPixelBits = 13
minMemoryMapAlignment = 4096
minUniformBufferOffsetAlignment = 0x00000040
minStorageBufferOffsetAlignment = 0x00000004
minTexelOffset = -8
maxTexelOffset = 7
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
framebufferColorSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferDepthSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
sampledImageColorSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
sampledImageIntegerSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
sampledImageDepthSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
storageImageSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
timestampPeriod = 83.3333
0.125
255.875
0
2047.99
pointSizeGranularity = 0.125
lineWidthGranularity = 0.0078125
strictLines = false
optimalBufferCopyOffsetAlignment = 0x00000080
optimalBufferCopyRowPitchAlignment = 0x00000080
residencyStandard2DBlockShape = false
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyNonResidentStrict = false
primitiveOverestimationSize = 0.00195312
conservativePointAndLineRasterization = false
maxCustomBorderColorSamplers = 4096
maxUpdateAfterBindDescriptorsInAllPools = 1048576
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 64
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 4294967295
maxPerStageDescriptorUpdateAfterBindInputAttachments = 64
maxDescriptorSetUpdateAfterBindUniformBuffers = 384
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindStorageBuffers = 4294967295
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindInputAttachments = 256
driverID = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
driverName = Intel open-source Mesa driver
driverInfo = Mesa 21.2.5
conformanceVersion = 1.2.0.0
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 0
renderMajor = 226
renderMinor = 128
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_NONE
shaderDenormPreserveFloat32 = true
shaderDenormPreserveFloat64 = true
shaderDenormFlushToZeroFloat32 = true
shaderDenormFlushToZeroFloat64 = true
shaderRoundingModeRTZFloat16 = true
deviceUUID = 9bc84c5d-a175-ef63-17bf-25bb1b291bb9
driverUUID = 23383389-6f8e-6afe-f5f7-05e75d964b9e
deviceNodeMask = 0
maxInlineUniformBlockSize = 4096
lineSubPixelPrecisionBits = 4
maxPerSetDescriptors = 1024
maxMemoryAllocationSize = 0x80000000
maxMultiDrawCount = 2048
maxMultiviewViewCount = 16
maxMultiviewInstanceIndex = 268435455
pciDomain = 0
pciBus = 0
pciDevice = 2
pciFunction = 0
transformFeedbackPreservesTriangleFanProvokingVertex = false
robustStorageBufferAccessSizeAlignment = 0x00000004
robustUniformBufferAccessSizeAlignment = 0x00000040
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
width = 1
height = 1
0
0.9375
subgroupSize = 32
supportedStages: count = 16
SHADER_STAGE_ALL
SHADER_STAGE_RAYGEN_BIT_KHR
SHADER_STAGE_ANY_HIT_BIT_KHR
SHADER_STAGE_CLOSEST_HIT_BIT_KHR
SHADER_STAGE_MISS_BIT_KHR
SHADER_STAGE_INTERSECTION_BIT_KHR
SHADER_STAGE_CALLABLE_BIT_KHR
SHADER_STAGE_TASK_BIT_NV
SHADER_STAGE_MESH_BIT_NV
supportedOperations: count = 8
minSubgroupSize = 8
maxComputeWorkgroupSubgroups = 56
requiredSubgroupSizeStages: count = 2
SHADER_STAGE_ALL
uniformTexelBufferOffsetAlignmentBytes = 0x00000001
uniformTexelBufferOffsetSingleTexelAlignment = false
maxTimelineSemaphoreValueDifference = 18446744073709551615
maxTransformFeedbackBufferSize = 0x100000000
maxTransformFeedbackStreamDataSize = 512
transformFeedbackRasterizationStreamSelect = false
maxVertexAttribDivisor = 268435455
deviceNodeMask = 0
subgroupSize = 32
subgroupSupportedStages: count = 16
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 8
framebufferIntegerColorSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
Device Extensions: count = 105
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 1
VK_EXT_shader_stencil_export : extension revision 1
VK_GOOGLE_decorate_string : extension revision 1
VK_GOOGLE_hlsl_functionality1 : extension revision 1
VK_GOOGLE_user_type : extension revision 1
VK_INTEL_shader_integer_functions2 : extension revision 1
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_incremental_present : extension revision 2
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
queueProperties[0]:
queueCount = 1
timestampValidBits = 36
memoryHeaps: count = 1
memoryHeaps[0]:
budget = 5436866560 (0x144100000) (5.06 GiB)
flags: count = 1
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x000f: count = 4
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
(non-sparse)
color images
(non-sparse)
dualSrcBlend = true
logicOp = true
depthClamp = true
depthBounds = false
wideLines = true
largePoints = true
alphaToOne = true
textureCompressionETC2 = true
textureCompressionASTC_LDR = true
shaderStorageImageMultisample = false
shaderStorageImageReadWithoutFormat = false
shaderInt64 = true
shaderInt16 = true
shaderResourceResidency = false
sparseBinding = false
sparseResidencyBuffer = false
sparseResidencyImage2D = false
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = false
formatA4B4G4R4 = false
bufferDeviceAddressCaptureReplay = true
bufferDeviceAddressMultiDevice = false
shaderInputAttachmentArrayDynamicIndexing = false
shaderInputAttachmentArrayNonUniformIndexing = false
descriptorBindingUniformBufferUpdateAfterBind = true
extendedDynamicState2PatchControlPoints = false
fragmentShaderShadingRateInterlock = false
smoothLines = true
stippledRectangularLines = false
stippledSmoothLines = false
multiDraw = true
multiview = true
privateData = true
shaderBufferFloat32AtomicAdd = false
shaderBufferFloat64Atomics = false
shaderBufferFloat64AtomicAdd = false
shaderSharedFloat32AtomicAdd = false
shaderSharedFloat64Atomics = false
shaderSharedFloat64AtomicAdd = false
shaderImageFloat32AtomicAdd = false
sparseImageFloat32Atomics = false
sparseImageFloat32AtomicAdd = false
shaderSharedInt64Atomics = false
shaderDeviceClock = false
shaderFloat16 = true
shaderInt8 = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
multiview = true
shaderInt8 = true
system
Closed
3
