Does this motherboard have drivers on manjaro?
So I am looking of buying a computer in one day I have picked all the parts and everything is ready to go, I just need to make sure that the motherboard drivers will work on manjaro the motherboard is " GIGABYTE B450 AORUS PRO WIFI (rev. 1.0) AM4 AMD B450 SATA 6Gb/s ATX AMD Motherboard" it is a pretty good deal.
if you want to use a 5000 series , see for B550 series V2 ( aorus pro wifi )
( be careful for recent B550 series , see No Ethernet with RTL8125 )
or x570 aorus pro wifi
Search my friend and draw your own conclusions …
If you wanna be sure - look for Manjaro supported hardware using the link on the web site. Hardware
I am looking with one that comes with wifi or a wifi card I can use with the B550 aka cheaper one
see this
this info
and this one
@linus-arrhus
i think i have better links this time again search engine
