I am looking to buy this monitor, but I am concerned if the native SDQHD (2560 × 2880) resolution would work with my ThinkPad X1 Yoga (second gen) running Manjaro Linux.
inxi --full --verbosity=7 --filter --no-host
Kernel: 5.19.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 20JES01U2C v: ThinkPad X1 Yoga 2nd
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: LENOVO model: 20JES01U2C v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1NET54W (1.41 )
date: 08/17/2021
ID-1: BAT0 charge: 16.6 Wh (33.2%) condition: 50.0/56.0 Wh (89.3%)
volts: 14.6 min: 15.3 model: SMP 01AV441 type: Li-poly serial: <filter>
status: discharging cycles: 533
Device-1: wacom_battery_0 model: Wacom Pen and multitouch sensor
serial: N/A charge: 0% rechargeable: yes status: N/A
RAM: total: 15.37 GiB used: 8.2 GiB (53.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: dual core model: Intel Core i7-7600U bits: 64 type: MT MCP
smt: enabled arch: Amber/Kaby Lake note: check rev: 9 cache: L1: 128 KiB
L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 1250 high: 2900 min/max: 400/3900 cores: 1: 700 2: 700
3: 2900 4: 700 bogomips: 23209
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b5ce class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: eDP-1 model: Lenovo 0x4140 res: 2560x1440 hz: 60 dpi: 210
size: 310x175mm (12.2x6.89") diag: 356mm (14") modes: 2560x1440
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound API: ALSA v: k5.19.17-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
bus-ID: 1-7:9 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 150.94 GiB (15.8%)
ID-1: /dev/sda vendor: SanDisk model: SD9SN8W-1T00-1006 size: 953.87 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4006 scheme: GPT
ID-1: / size: 920.87 GiB used: 145.19 GiB (15.8%) fs: ext4 dev: /dev/sda2
label: N/A uuid: 2c6dd6cd-0652-407b-a5ad-bca998619889
ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat
dev: /dev/sda1 label: NO_LABEL uuid: D685-454B
ID-1: swap-1 type: partition size: 16.92 GiB used: 5.75 GiB (34.0%)
priority: -2 dev: /dev/sda3 label: swap
uuid: 9bf47d72-3a49-42a5-b9b2-f3d0841ee34e
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-7:9 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-8:3 info: Chicony Integrated Camera type: Video
Device-3: 1-9:10 info: Validity Sensors type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 138a:0097 class-ID: ff00 serial: <filter>
Device-4: 1-10:5 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 056a:5087 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C pch: 38.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 246 Uptime: 3d 10h 4m wakeups: 13 Init: systemd v: 251
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1582
pm: pacman pkgs: 1566 pm: flatpak pkgs: 9 pm: snap pkgs: 7 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.23
