Does package installation trigger an update?
I am on Stable Branch and have not run the latest update, which is to say that I
  • have run the 2023-05-07 update but
  • have not run the 2023-06-04 update.
Or had not as of 10 minutes ago.
I then wanted to install qbittorrent and so ran these two commands
sudo pacman -Sy
pamac install qbittorrent
Terminal is telling me that it is downloading 1.2 GB of stuff. The output is at the bottom of this post, with [LINES OMITTED FROM QUOTING] where I do that (otherwise too long).
QUESTIONS
  1. Did I just update per 2023-06-04?
  2. Why did that I happen? I thought my only command was to install qbittorrent? Is it normal behavior that, if you are no up-to-date and install any package, then you first get updated? (Now that would be harsh. There were some preparatory commands I would have wanted to run before updating.)
  3. There were several lines of Error while configuring manjaro-keyring, should I worry about that? Thanks.
[luna@jar ~]$ sudo pacman -Sy
[sudo] password for luna:
 core                  144.9 KiB  90.7 KiB/s 00:02 [######################] 100%
 extra                1642.9 KiB  2.28 MiB/s 00:01 [######################] 100%
 community               7.0 MiB  6.73 MiB/s 00:01 [######################] 100%
 multilib              145.5 KiB   927 KiB/s 00:00 [######################] 100%
[luna@jar ~]$ pamac install qbittorrent
Preparing...
Authenticating as: Luna (luna)
Password:
Warning: manjaro-hello: local (0.7.0-6) is newer than extra (0.7.0-5)
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Warning: libcamera-ipa will be installed before its libcamera dependency
To upgrade (317):
  linux-api-headers              6.3-1                         (6.1.9-1)                       core       1.3 MB
  tzdata                         2023c-2                       (2023c-1)                       core       395.0 kB
  qt6-svg                        6.5.0-1                       (Required By: qbittorrent)      extra      184.5 kB
  qbittorrent                    4.5.2-1                                                       community  7.1 MB
Total download size: 1.2 GB
Total installed size: 480.6 MB
Apply transaction ? [y/N] y
Download of archlinux-keyring (20230504-1) started
Download of manjaro-keyring (20230616-3) started
Download of manjaro-keyring (20230616-3) finished
Download of archlinux-keyring (20230504-1) finished
Checking keyring...                                                        [2/2]
Configuring manjaro-keyring...                                             [2/2]
==> Appending keys from manjaro.gpg...
gpg: error reading key: No public key
==> Locally signing trusted keys in keyring...
  -> Locally signed 3 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
==> Disabling revoked keys in keyring...
  -> Disabled 8 keys.
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  21  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  21  signed:  95  trust: 0-, 0q, 0n, 21m, 0f, 0u
gpg: depth: 2  valid:  72  signed:  27  trust: 72-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-07-07
Reloading system manager configuration...                                  [1/2]
Arming ConditionNeedsUpdate...                                             [2/2]
Download of linux-api-headers (6.3-1) started
Download of tzdata (2023c-2) started
Download of tzdata (2023c-2) finished
Generation complete.
Upgrading a52dec (0.7.4-12 -> 0.8.0-1)...                                [4/343]
Upgrading adwaita-cursors (43-2 -> 44.0-1)...                            [5/343]
Updating X fontdir indices...                                            [35/35]
A restart is required for the changes to take effect.
[luna@jar ~]$
While you are free to combine the pacman options as you see fit - there is combinations that puts your system in an unsupported state.
Never use a database only update when syncing a new package
pacman -Sy pkgname
If you know your system is up-to-date - that is a current pacman -Syu then it is ok to use
pacman -S <pkgname>
Otherwise it is not.
Pamac package manager will default to updating the system when you sync a new package - this is best practise.
But it is your system - you can use whichever practise you see fit - also ignoring best practise - your choice.
But if you get weird system errors as a result - you shouldn’t ask for help here - first run a full system sync using a current mirror - then seek help.
No, but 2 things… First - you should, otherwise you can create a partial upgrade situation. Second - by default pamac does act as you describe, though other tools like pacman do not.
:scream: Dont do this.
I guess so
See above. Pamac by default holds your hand and makes sure to sync and update before installing new packages.
Yes probably … well, maybe not worry. But consult one of the many guides on key issues. ex:
Thanks. Let me make sure I understood correctly.
So the principle is to make sure that the system is up-to-date before installing any package.
To that end, I could do one of these two things.
  1. Use
  1. Update the system (I do this per your own how-to at [root tip] [How To] Update Manjaro the smart way) and then use
pacman -S qbittorrent
Would that sum it up?
Frankly - I have not tested the commandline version if it default to update as part of install.
I know the GUI default to update - but some settings only applies to the GUI - giving the CLI more leeway.
I think pamac CLI behaves like pacman - it just does what you tell it to.
So the correct appraoch (if system is not up-to-date)
pamac update && pamac install
sudo pacman -Syu <pkgname>
If the system is up-to-date - then your summary is correct and the install command will update the system
pamac install <pkgname>
Because Manjaro is rolling - applying the at any time latest set of packages will make your system current whether this is due syncing a new package or a deliberate update session.
Understood.
These are two ways to make sure the system is up-to-date before installing a new package.
But I would prefer to make it two-step by first updating per your tutorial and then separately installing the new package.
Your tutorial has these extra commands, which otherwise I would be leaving out.
sudo journalctl --vacuum-size=50M
sudo paccache -ruk0
In /etc/pamac.conf there is the option:
## When installing packages, do not check for updates:
#SimpleInstall
It is disabled by default: data/config/pamac.conf · master · Applications / libpamac · GitLab
So, it will always install updates along your target package.
Yes - this is default behavior in GUI.
E.g. building aur packages - this is possible using CLI even though AUR is not enabled in the config.
EDIT:
I just checked on a test system - running
will update the system to match the primary mirrors package set.
Yes, but you must have AUR enabled to be able to use pamac install. Without explicit enabling, you have to use pamac build.
Thanks. I read the “Errors about Keys” section you linked and understood something of only the introductory paragraph.
PLEASE IGNORE WHAT IS BELOW. I ONLY LEAVE THEM AS THEY ARE CONTEXT FOR SUBSEQUENT COMMENTS.
Practically speaking, what should I do?
  1. Run the first sequence of commands, i.e. 1 through 6.
  2. Run the second sequence, i.e. 1 through 7 (which are said to be the “improved version”).
  3. Since the errors don’t seem to be producing any ill effect, just let them be for now.
I suspect you are looking at a cached or translated version - there is no longer an “improved version”
Thank you. Looking at the commands again, they don’t look like something I could just cut, paste, and run.
Also I found this post, where people report trying various things in vain: Update of manjaro-keyring gave errors - #22 by shadowsofnoxus
I believe I will first roll back my Manjaro VM to the last snapshot and see whether that fixes anything.
Is there any command that will check the keyrings and produce a status report (e.g.what is wrong)?
System maintenance should never be exercised with cut, paste and run.
One should make an effort to understand what and why.
In this case, the effort would indeed have to be massive as there are two many terms I do not know the meaning of.
Anyway I found a post that seems to counsel letting it alone. That’s what I am going to do
I made an error in when I said I had not been up-to-date when using pamac
I went through my logs and the facts are as follows.
  • On June 4, as soon as the 2023-06-04 update came out for the Stable Branch, I applied it to my Manjaro.
  • I see no later update on this announcements page:
    Stable Updates - Manjaro Linux Forum
How could I have got updated when I was already up-to-date? (If I had applied the latest update, was I not up-to-date?)
Terminal output from the two commands.
Preparing...
Password:
To upgrade (317):
  glibc                          2.37-3                        (2.37-2)                        core       10.4 MB
  a52dec                         0.8.0-1                       (0.7.4-12)                      extra      47.5 kB
  adwaita-cursors                44.0-1                        (43-2)                          extra      621.5 kB
  util-linux-libs                2.38.1-4                      (2.38.1-3)                      core       419.6 kB
  gcc-libs                       13.1.1-1                      (12.2.1-2)                      core       36.9 MB
  glib2                          2.76.2-1                      (2.76.1-1)                      core       4.0 MB
  xz                             5.4.3-1                       (5.4.2-1)                       core       625.3 kB
  libxml2                        2.10.4-4                      (2.10.4-2)                      core       866.5 kB
  brotli                         1.0.9-12                      (1.0.9-10)                      core       484.1 kB
  harfbuzz                       7.3.0-1                       (7.1.0-1)                       extra      958.0 kB
  xcb-proto                      1.15.2-3                      (1.15.2-2)                      extra      130.2 kB
  gtk-update-icon-cache          1:4.10.3-2                    (1:4.10.3-1)                    extra      17.0 kB
  adwaita-icon-theme             44.0-1                        (43-2)                          extra      617.3 kB
  alsa-ucm-conf                  1.2.9-1                       (1.2.8-1)                       extra      78.2 kB
  alsa-lib                       1.2.9-1                       (1.2.8-1)                       extra      496.9 kB
  hwdata                         0.370-1                       (0.369-1)                       core       1.6 MB
  pciutils                       3.10.0-1                      (3.9.0-2)                       core       119.8 kB
  alsa-utils                     1.2.9-1                       (1.2.8-1)                       extra      1.2 MB
  protobuf                       21.12-2                       (21.12-1)                       extra      2.1 MB
  libcap-ng                      0.8.3-2                       (0.8.3-1)                       core       42.7 kB
  keyutils                       1.6.3-2                       (1.6.3-1)                       core       104.2 kB
  audit                          3.1.1-1                       (3.1-1)                         core       398.1 kB
  pam                            1.5.3-1                       (1.5.2-2)                       core       484.7 kB
  argon2                         20190702-5                    (20190702-4)                    core       33.6 kB
  libcap                         2.69-1                        (2.68-1)                        core       718.6 kB
  systemd-libs                   253.4-1                       (252.10-2)                      core       1.2 MB
  cryptsetup                     2.6.1-3.4                     (2.6.1-3.3)                     core       870.1 kB
  kbd                            2.5.1-2                       (2.5.1-1)                       core       1.3 MB
  libseccomp                     2.5.4-2                       (2.5.4-1)                       core       90.4 kB
  util-linux                     2.38.1-4                      (2.38.1-3)                      core       2.5 MB
  libnghttp2                     1.53.0-1                      (1.52.0-2)                      core       97.9 kB
  ca-certificates-mozilla        3.89.1-1                      (3.89-1)                        core       367.0 kB
  curl                           8.1.2-1                       (8.0.1-1)                       core       1.2 MB
  systemd                        253.4-1                       (252.10-2)                      core       9.2 MB
  android-tools                  34.0.1-1                      (33.0.3-3)                      community  1.9 MB
  aom                            3.6.1-1                       (3.6.0-1)                       extra      2.9 MB
  python                         3.11.3-1                      (3.10.10-1)                     core       14.5 MB
  apparmor                       3.1.3-2                       (3.1.3-1)                       extra      1.5 MB
  appstream                      0.16.2-1                      (0.16.1-2)                      extra      2.4 MB
  mpfr                           4.2.0.p7-2                    (4.2.0-3)                       core       437.7 kB
  gawk                           5.2.2-1                       (5.2.1-2)                       core       1.3 MB
  sqlite                         3.42.0-1                      (3.41.2-1)                      core       1.7 MB
  nettle                         3.9-1                         (3.8.1-1)                       core       467.3 kB
  lib32-glibc                    2.37-3                        (2.37-2)                        core       3.5 MB
  lib32-gcc-libs                 13.1.1-1                      (12.2.1-2)                      core       32.7 MB
  tpm2-tss                       4.0.1-1                       (3.2.0-3)                       core       987.6 kB
  gpgme                          1.20.0-3                      (1.20.0-1)                      core       491.8 kB
  grep                           3.11-1                        (3.10-1)                        core       239.2 kB
  python-npyscreen               4.10.5-8                      (4.10.5-7)                      community  308.9 kB
  python-idna                    3.4-3                         (3.4-1)                         extra      95.3 kB
  python-urllib3                 1.26.15-1                     (1.26.13-1)                     extra      245.9 kB
  python-chardet                 5.1.0-3                       (5.1.0-1)                       extra      263.4 kB
  python-requests                2.28.2-4                      (2.28.2-1)                      extra      122.3 kB
  python-certifi                 2022.12.07-3                  (2022.12.07-1)                  community  9.5 kB
  pacman-mirrors                 4.23.2+3+g4148c3d-1           (4.23.2+2+g2f58b3c-3)           core       202.7 kB
  perl                           5.36.1-1                      (5.36.0-3)                      core       16.3 MB
  archlinux-keyring              20230504-1                    (20230320-1)                    core       1.2 MB
  libxi                          1.8.1-1                       (1.8-3)                         extra      154.6 kB
  at-spi2-core                   2.48.2-1                      (2.48.0-2)                      extra      579.6 kB
  avahi                          0.8+22+gfd482a7-4             (0.8+22+gfd482a7-3)             extra      438.9 kB
  libcups                        1:2.4.2-7                     (1:2.4.2-6)                     extra      282.0 kB
  double-conversion              3.3.0-1                       (3.2.1-1)                       extra      58.0 kB
  llvm-libs                      15.0.7-3                      (15.0.7-2)                      extra      30.7 MB
  mesa                           23.0.4-1                      (23.0.3-1)                      extra      29.8 MB
  libproxy                       0.4.18-3                      (0.4.18-2)                      extra      88.7 kB
  libevdev                       1.13.1-1                      (1.13.0-1)                      extra      64.4 kB
  libwacom                       2.7.0-1                       (2.6.0-2)                       extra      115.6 kB
  qt5-svg                        5.15.9+kde+r8-1               (5.15.9+kde+r7-1)               extra      152.2 kB
  dav1d                          1.2.0-1                       (1.1.0-1)                       extra      639.4 kB
  libopenmpt                     0.7.1-1                       (0.6.10-1)                      extra      807.0 kB
  libssh                         0.10.5-1                      (0.10.4-3)                      extra      201.5 kB
  sdl2                           2.26.5-2                      (2.26.5-1)                      extra      1.0 MB
  svt-av1                        1.5.0-1                       (1.4.1-1)                       extra      2.1 MB
  imath                          3.1.7-2                       (3.1.7-1)                       extra      4.1 MB
  ffmpeg                         2:6.0-6                       (2:6.0-5)                       extra      12.0 MB
  libftdi                        1.5-5                         (1.5-4)                         community  129.0 kB
  lirc                           1:0.10.2-3                    (1:0.10.2-2)                    extra      1.2 MB
  libpipewire                    1:0.3.70-2                    (1:0.3.70-1)                    extra      380.5 kB
  audacious-plugins              4.3.1-1                       (4.2-4)                         extra      1.5 MB
  audacious                      4.3.1-1                       (4.2-3)                         extra      589.8 kB
  binutils                       2.40-5                        (2.40-4)                        core       7.8 MB
  python-cairo                   1.23.0-4                      (1.23.0-3)                      extra      96.6 kB
  libgirepository                1.76.1-3                      (1.76.1-1)                      extra      151.9 kB
  gobject-introspection-runtime  1.76.1-3                      (1.76.1-1)                      extra      176.3 kB
  python-gobject                 3.44.1-3                      (3.44.1-1)                      extra      309.7 kB
  iso-codes                      4.15.0-1                      (4.13.0-1)                      extra      3.4 MB
  libsoup3                       3.4.2-1                       (3.4.1-1)                       extra      403.5 kB
  tracker3                       3.5.2-1                       (3.5.0-1)                       extra      746.5 kB
  nss                            3.89.1-1                      (3.89-1)                        core       1.6 MB
  blueman                        2.3.5-2                       (2.3.5-1)                       community  1.5 MB
  boost-libs                     1.81.0-6                      (1.81.0-3)                      extra      2.3 MB
  botan                          3.0.0-1                       (2.19.3-1)                      extra      2.5 MB
  btrfs-progs                    6.3-2                         (6.2.2-1)                       core       1.0 MB
  dbus-python                    1.2.18-5                      (1.2.18-4)                      extra      2.8 MB
  python-ptyprocess              0.7.0-5                       (0.7.0-4)                       community  29.2 kB
  python-pexpect                 4.8.0-7                       (4.8.0-6)                       community  97.8 kB
  catfish                        4.16.4-2                      (4.16.4-1)                      community  372.5 kB
  gcc                            13.1.1-1                      (12.2.1-2)                      core       49.0 MB
  compiler-rt                    15.0.7-2                      (15.0.7-1)                      extra      3.4 MB
  clang                          15.0.7-9                      (15.0.7-2)                      extra      41.4 MB
  poppler                        23.05.0-1                     (23.03.0-1)                     extra      1.6 MB
  cups-filters                   1.28.17-3                     (1.28.17-2)                     extra      876.6 kB
  cups                           1:2.4.2-7                     (1:2.4.2-6)                     extra      5.4 MB
  libbpf                         1.2.0-1                       (1.1.0-1)                       core       244.8 kB
  iproute2                       6.3.0-2                       (6.2.0-2)                       core       1.2 MB
  dhclient                       4.4.3.P1-2                    (4.4.3.P1-1)                    extra      1.2 MB
  dhcpcd                         10.0.1-1                      (9.4.1-1)                       core       211.9 kB
  elementary-icon-theme          7.3.0-1                       (7.2.0-1)                       community  2.7 MB
  less                           1:633-1                       (1:608-2)                       core       133.2 kB
  engrampa                       1.26.1-1                      (1.26.0-1)                      community  1.3 MB
  gnome-desktop-common           1:44.0-1                      (1:43.2-1)                      extra      491.8 kB
  gnome-desktop                  1:44.0-1                      (1:43.2-1)                      extra      117.0 kB
  gspell                         1.12.1-1                      (1.12.0-2)                      extra      125.2 kB
  gstreamer                      1.22.2-1                      (1.22.1-2)                      extra      1.9 MB
  gst-plugins-base-libs          1.22.2-1                      (1.22.1-2)                      extra      2.3 MB
  gcr                            3.41.1-4                      (3.41.1-3)                      extra      762.9 kB
  libbytesize                    2.7-2                         (2.7-1)                         extra      25.3 kB
  volume_key                     0.3.12-8                      (0.3.12-7)                      extra      134.8 kB
  thin-provisioning-tools        1.0.4-1                       (1.0.3-1)                       core       1.0 MB
  libblockdev                    2.28-2                        (2.28-1)                        extra      233.5 kB
  gvfs                           1.50.4-3                      (1.50.4-1)                      extra      1.0 MB
  poppler-glib                   23.05.0-1                     (23.03.0-1)                     extra      297.6 kB
  evince                         44.1-1                        (43.1-2)                        extra      1.8 MB
  exfatprogs                     1.2.1-1                       (1.2.0-1)                       community  61.3 kB
  noto-fonts                     20230501-1                    (20230401-1)                    extra      28.2 MB
  firefox                        114.0.1-1                     (113.0-0.1)                     extra      68.2 MB
  python-more-itertools          9.1.1-4                       (9.1.1-1)                       community  97.5 kB
  python-jaraco.classes          3.2.3-3                       (3.2.3-1)                       community  11.8 kB
  python-jeepney                 0.8.0-2                       (0.8.0-1)                       community  109.0 kB
  python-ply                     3.11-12                       (3.11-10)                       extra      109.5 kB
  python-pycparser               2.21-5                        (2.21-3)                        extra      235.8 kB
  python-cffi                    1.15.1-3                      (1.15.1-1)                      extra      282.4 kB
  python-cryptography            40.0.2-1                      (40.0.1-1)                      extra      990.4 kB
  python-secretstorage           3.3.3-2                       (3.3.3-1)                       community  29.1 kB
  python-zipp                    3.15.0-2                      (3.15.0-1)                      community  15.8 kB
  python-importlib-metadata      5.0.0-5                       (5.0.0-3)                       community  43.2 kB
  python-keyring                 23.13.1-1                     (23.11.0-1)                     community  74.9 kB
  python-precis_i18n             1.0.5-1                       (1.0.4-1)                       community  41.8 kB
  python-nbxmpp                  4.2.2-2                       (4.2.1-1)                       community  411.1 kB
  python-css-parser              1.0.9-1                       (1.0.8-1)                       community  345.2 kB
  python-distro                  1.8.0-3                       (1.8.0-2)                       community  37.9 kB
  python-pillow                  9.5.0-2                       (9.4.0-2)                       community  821.3 kB
  python-decorator               5.1.1-3                       (5.1.1-2)                       community  20.0 kB
  python-gssapi                  1.8.2-2                       (1.8.2-1)                       community  488.5 kB
  python-netifaces               0.11.0-4                      (0.11.0-3)                      community  13.3 kB
  python-packaging               23.1-1                        (23.0-1)                        extra      95.5 kB
  gajim                          1.7.3-2                       (1.7.1-2)                       community  3.6 MB
  gcr-4                          4.1.0-1                       (4.0.0-1)                       extra      566.5 kB
  libpeas                        1.36.0-2                      (1.34.0-1)                      extra      143.3 kB
  gedit                          44.2-2                        (44.2-1)                        community  1.9 MB
  glslang                        12.1.0-2                      (12.1.0-1)                      extra      3.2 MB
  gst-plugins-bad-libs           1.22.2-1                      (1.22.1-2)                      extra      2.5 MB
  gtk4                           1:4.10.3-2                    (1:4.10.3-1)                    extra      6.3 MB
  gnome-desktop-4                1:44.0-1                      (1:43.2-1)                      extra      119.6 kB
  gpm                            1.20.7.r38.ge82d1a6-5         (1.20.7.r38.ge82d1a6-4)         core       143.2 kB
  libtool                        2.4.7+4+g1ec8fa28-3           (2.4.7+4+g1ec8fa28-2)           core       422.3 kB
  libheif                        1.16.1-2                      (1.15.2-1)                      extra      330.5 kB
  graphviz                       8.0.5-2                       (8.0.3-1)                       extra      4.1 MB
  gst-libav                      1.22.2-1                      (1.22.1-2)                      extra      96.9 kB
  lilv                           0.24.20-2                     (0.24.20-1)                     community  87.0 kB
  imagemagick                    7.1.1.9-1                     (7.1.1.8-1)                     extra      8.7 MB
  zbar                           0.23.90-2                     (0.23.90-1)                     extra      255.8 kB
  libxslt                        1.1.37-3                      (1.1.37-2)                      extra      217.3 kB
  gst-plugins-bad                1.22.2-1                      (1.22.1-2)                      extra      1.1 MB
  gst-plugins-base               1.22.2-1                      (1.22.1-2)                      extra      324.6 kB
  imlib2                         1.11.1-1                      (1.11.0-1)                      extra      581.9 kB
  gst-plugins-good               1.22.2-1                      (1.22.1-2)                      extra      2.2 MB
  gst-plugins-ugly               1.22.2-1                      (1.22.1-2)                      extra      220.2 kB
  ufw                            0.36.2-1                      (0.36.1-3)                      community  231.3 kB
  harfbuzz-icu                   7.3.0-1                       (7.1.0-1)                       extra      8.1 kB
  webkit2gtk                     2.40.1-2                      (2.40.1-1)                      extra      28.0 MB
  gufw                           22.04-2                       (22.04-1)                       community  1.0 MB
  libplist                       2.3.0-1                       (2.2.0-6)                       extra      144.5 kB
  libusbmuxd                     2.0.2-2                       (2.0.2-1)                       extra      32.6 kB
  libimobiledevice               1.3.0-8                       (1.3.0-6)                       extra      354.0 kB
  usbmuxd                        1.1.1-3                       (1.1.1-2)                       extra      36.6 kB
  gvfs-afc                       1.50.4-3                      (1.50.4-1)                      extra      42.8 kB
  gvfs-gphoto2                   1.50.4-3                      (1.50.4-1)                      extra      47.0 kB
  gvfs-mtp                       1.50.4-3                      (1.50.4-1)                      extra      47.3 kB
  gvfs-nfs                       1.50.4-3                      (1.50.4-1)                      extra      20.2 kB
  tdb                            1.4.8-2                       (1.4.8-1)                       extra      73.4 kB
  talloc                         2.4.0-3                       (2.4.0-2)                       extra      48.4 kB
  tevent                         1:0.14.1-2                    (1:0.14.1-1)                    extra      55.2 kB
  ldb                            2:2.7.2-2                     (2:2.7.2-1)                     extra      220.0 kB
  libwbclient                    4.18.2-2                      (4.18.2-1)                      extra      36.7 kB
  smbclient                      4.18.2-2                      (4.18.2-1)                      extra      7.1 MB
  gvfs-smb                       1.50.4-3                      (1.50.4-1)                      extra      29.7 kB
  hexchat                        2.16.1-4                      (2.16.1-3)                      community  1.3 MB
  libibus                        1.5.28-4                      (1.5.28-3)                      community  11.7 MB
  ibus                           1.5.28-4                      (1.5.28-3)                      community  859.2 kB
  ibus-hangul                    1.5.4-5                       (1.5.4-3)                       community  54.5 kB
  intel-ucode                    20230516-1                    (20230214-1)                    extra      6.1 MB
  iw                             5.19-2                        (5.19-1)                        core       106.0 kB
  kcoreaddons                    5.106.0-1                     (5.105.0-1)                     extra      1.4 MB
  kauth                          5.106.0-1                     (5.105.0-1)                     extra      332.6 kB
  kitemmodels                    5.106.0-1                     (5.105.0-1)                     extra      608.3 kB
  kwindowsystem                  5.106.0-1                     (5.105.0-1)                     extra      857.5 kB
  lensfun                        1:0.3.3-2                     (1:0.3.3-1)                     extra      356.5 kB
  lib32-curl                     8.1.0-1                       (8.0.1-1)                       multilib   309.8 kB
  lib32-libxfixes                6.0.1-1                       (6.0.0-2)                       multilib   10.5 kB
  lib32-xz                       5.4.3-1                       (5.4.2-1)                       multilib   108.7 kB
  lib32-libxml2                  2.10.4-4                      (2.10.4-2)                      multilib   589.5 kB
  lib32-mesa                     23.0.4-1                      (23.0.3-1)                      multilib   25.7 MB
  lib32-libva                    2.18.0-1                      (2.17.0-1)                      multilib   88.4 kB
  lib32-libva-mesa-driver        23.0.4-1                      (23.0.3-1)                      multilib   4.3 MB
  lib32-libxi                    1.8.1-1                       (1.8-2)                         multilib   31.6 kB
  lib32-libxt                    1.3.0-1                       (1.2.1-1)                       multilib   173.1 kB
  lib32-mesa-demos               9.0.0-1                       (8.5.0-1)                       multilib   2.0 MB
  libcamera-ipa                  0.0.5-1                       (0.0.4-4)                       extra      81.4 kB
  libcamera                      0.0.5-1                       (0.0.4-4)                       extra      493.6 kB
  libgexiv2                      0.14.0-4                      (0.14.0-3)                      community  129.1 kB
  libixion                       0.17.0-5                      (0.17.0-4)                      extra      347.6 kB
  libmalcontent                  0.11.1-2                      (0.11.1-1)                      extra      40.7 kB
  libmwaw                        0.3.22-1                      (0.3.21-3)                      extra      2.6 MB
  libnewt                        0.52.23-2                     (0.52.23-1)                     community  97.1 kB
  libnma-common                  1.10.6-2                      (1.10.6-1)                      extra      196.7 kB
  libnma                         1.10.6-2                      (1.10.6-1)                      extra      110.4 kB
  libopenraw                     0.3.5-1                       (0.3.4-1)                       community  1.2 MB
  liborcus                       0.17.2-5                      (0.17.2-4)                      extra      774.8 kB
  libpamac                       11.5.4-1                      (11.5.3-1)                      extra      699.3 kB
  pipewire                       1:0.3.70-2                    (1:0.3.70-1)                    extra      646.2 kB
  xdg-desktop-portal-gnome       44.1-2                        (43.1-1)                        extra      159.6 kB
  xdg-desktop-portal             1.16.0-3                      (1.16.0-1)                      extra      376.1 kB
  libpamac-flatpak-plugin        11.5.4-1                      (11.5.3-1)                      extra      28.5 kB
  snapd                          2.59.4-1                      (2.59.1-1)                      extra      26.3 MB
  qt5-declarative                5.15.9+kde+r25-1              (5.15.9+kde+r24-1)              extra      5.1 MB
  libpamac-snap-plugin           11.5.4-1                      (11.5.3-1)                      extra      25.5 kB
  libwps                         0.4.14-1                      (0.4.13-1)                      extra      1.7 MB
  libwpg                         0.3.4-1                       (0.3.3-4)                       extra      142.3 kB
  libreoffice-still              7.4.7-2                       (7.4.6-1)                       extra      152.2 MB
  libteam                        1.31-8                        (1.31-7)                        extra      113.0 kB
  libupnp                        1.14.17-1                     (1.14.16-1)                     extra      236.8 kB
  libva-mesa-driver              23.0.4-1                      (23.0.3-1)                      extra      4.5 MB
  libwmf                         0.2.13-1                      (0.2.12-3)                      extra      1.9 MB
  xorg-setxkbmap                 1.3.4-1                       (1.3.3-2)                       extra      14.3 kB
  lightdm-gtk-greeter-settings   1.2.2-8                       (1.2.2-7)                       community  192.1 kB
  linux61                        6.1.31-2                      (6.1.31-1)                      core       145.2 MB
  llvm                           15.0.7-3                      (15.0.7-2)                      extra      17.8 MB
  luajit                         2.1.0.beta3.r471.g224129a8-1  (2.1.0.beta3.r471.g505e2c03-1)  community  328.9 kB
  pamac-cli                      10.5.1-2                      (10.5.1-1)                      extra      79.8 kB
  pamac-gtk                      10.5.1-2                      (10.5.1-1)                      extra      197.9 kB
  manjaro-application-utility    1.3.3-9                       (1.3.3-7)                       community  63.0 kB
  manjaro-keyring                20230616-3                    (20230318-1)                    core       579.0 kB
  manjaro-release                23.0.0pre-1                   (22.1.3-1)                      core       16.0 kB
  matcha-gtk-theme               20230403-2                    (20230403-1)                    community  6.6 MB
  meld                           3.22.0-2                      (3.22.0-1)                      extra      896.8 kB
  memtest86+                     6.20-1                        (6.10-1)                        extra      65.3 kB
  memtest86+-efi                 6.20-1                        (6.10-1)                        extra      65.2 kB
  python-psutil                  5.9.5-1                       (5.9.4-1)                       community  491.3 kB
  python-pyxdg                   0.28-2                        (0.28-1)                        extra      106.7 kB
  menulibre                      2.2.3-5                       (2.2.3-3)                       community  346.8 kB
  mousepad                       0.6.1-2                       (0.6.0-1)                       extra      447.6 kB
  mugshot                        0.4.3-5                       (0.4.3-3)                       community  2.5 MB
  nm-connection-editor           1.32.0-2                      (1.32.0-1)                      extra      810.5 kB
  network-manager-applet         1.32.0-2                      (1.32.0-1)                      extra      172.4 kB
  nftables                       1:1.0.7-2                     (1:1.0.7-1)                     extra      406.8 kB
  open-vm-tools                  6:12.2.0-2                    (6:12.2.0-1)                    community  908.6 kB
  openconnect                    1:9.10-1                      (1:9.01-2)                      extra      891.8 kB
  openresolv                     3.13.1-1                      (3.13.0-1)                      core       23.8 kB
  openvpn                        2.6.4-1                       (2.6.3-1)                       extra      633.9 kB
  python-lxml                    4.9.2-3                       (4.9.2-1)                       extra      1.3 MB
  python-deprecation             2.1.0-8                       (2.1.0-6)                       community  12.8 kB
  python-typing_extensions       4.5.0-4                       (4.5.0-1)                       community  54.8 kB
  python-pikepdf                 7.2.0-2                       (7.2.0-1)                       community  561.1 kB
  python-six                     1.16.0-8                      (1.16.0-6)                      extra      29.1 kB
  python-dateutil                2.8.2-5                       (2.8.2-4)                       community  332.9 kB
  python-jaraco.functools        3.6.0-3                       (3.6.0-1)                       community  16.0 kB
  python-jaraco.context          4.3.0-3                       (4.3.0-1)                       community  11.7 kB
  python-autocommand             2.2.2-4                       (2.2.2-1)                       community  22.9 kB
  python-pydantic                1.10.7-4                      (1.10.7-2)                      community  2.0 MB
  python-inflect                 6.0.4-2                       (6.0.4-1)                       community  77.5 kB
  python-jaraco.text             3.11.1-3                      (3.11.1-1)                      community  21.0 kB
  python-ordered-set             4.1.0-4                       (4.1.0-1)                       extra      16.2 kB
  python-platformdirs            3.5.1-1                       (3.2.0-1)                       extra      29.6 kB
  python-tomli                   2.0.1-3                       (2.0.1-1)                       extra      28.2 kB
  python-fastjsonschema          2.16.3-4                      (2.16.3-1)                      community  51.3 kB
  python-trove-classifiers       2023.4.25-1                   (2023.4.18-1)                   extra      15.1 kB
  python-validate-pyproject      0.12.2-4                      (0.12.2-1)                      extra      73.4 kB
  python-setuptools              1:67.7.0-1                    (1:67.6.1-1)                    extra      789.6 kB
  pdfarranger                    1.9.2-2                       (1.9.2-1)                       community  237.4 kB
  perl-uri                       5.18-1                        (5.17-1)                        extra      82.1 kB
  vulkan-headers                 1:1.3.248-1                   (1:1.3.246-1)                   extra      1.1 MB
  shiboken6                      6.5.0-2                       (6.5.0-1)                       extra      1.1 MB
  pyside6                        6.5.0-2                       (6.5.0-1)                       extra      9.1 MB
  python-protobuf                21.12-2                       (21.12-1)                       extra      373.6 kB
  python-axolotl-curve25519      0.4.1.2-9                     (0.4.1.2-8)                     community  66.9 kB
  python-axolotl                 0.2.3-6                       (0.2.3-5)                       community  126.7 kB
  python-docopt                  0.6.2-12                      (0.6.2-11)                      community  28.6 kB
  python-keyutils                0.6-9                         (0.6-8)                         community  24.1 kB
  python-systemd                 235-2                         (235-1)                         extra      68.3 kB
  python-manjaro-sdk             0.9-2                         (0.9-1)                         community  32.4 kB
  python-yaml                    6.0-3                         (6.0-1)                         community  194.2 kB
  qmmp                           2.1.3-1                       (2.1.2-2)                       community  2.5 MB
  samba                          4.18.2-2                      (4.18.2-1)                      extra      8.6 MB
  sof-firmware                   2.2.5-1                       (2.2.4-1)                       extra      660.9 kB
  systemd-sysvcompat             253.4-1                       (252.10-2)                      core       6.6 kB
  thunar                         4.18.6-1                      (4.18.4-1)                      extra      1.5 MB
  thunarx-python                 0.5.2-4                       (0.5.2-3)                       community  39.0 kB
  thunderbird                    102.12.0-1                    (102.11.0-0.1)                  extra      54.2 MB
  ttf-noto-nerd                  3.0.1-1                       (2.3.3-2)                       community  68.5 MB
  udiskie                        2.4.2-2                       (2.4.2-1)                       community  152.6 kB
  unrar                          1:6.2.7-1                     (1:6.2.6-1)                     extra      144.3 kB
  upower                         1.90.0-4                      (1.90.0-3)                      extra      147.9 kB
  virtualbox-guest-utils         7.0.8-2                       (7.0.8-1)                       community  755.8 kB
  webkit2gtk-4.1                 2.40.1-2                      (2.40.1-1)                      extra      28.0 MB
  wireless-regdb                 2023.05.03-1                  (2023.02.13-1)                  core       11.2 kB
  xapp                           2.4.3-2                       (2.4.3-1)                       community  203.8 kB
  xcursor-breeze                 5.27.5-1                      (5.27.3-1)                      community  483.0 kB
  xfce4-mpc-plugin               0.5.3-1                       (0.5.2-2)                       extra      44.3 kB
  xfce4-netload-plugin           1.4.1-1                       (1.4.0-1)                       extra      59.1 kB
  xfce4-screenshooter            1.10.4-1                      (1.10.3-1)                      extra      190.8 kB
  xorg-xdpyinfo                  1.3.4-1                       (1.3.3-4)                       extra      16.5 kB
  yelp                           42.2-2                        (42.2-1)                        extra      836.0 kB
  yt-dlp                         2023.03.04-2                  (2023.03.04-1)                  community  4.6 MB
  zsh-theme-powerlevel10k        1.18.0-1                      (1.17.0+23+g1cff2249-1)         community  1.0 MB
To install (28):
  lib32-libtirpc                 1.3.3-2                                                       multilib   82.1 kB
  lib32-pam                      1.5.3-1                                                       multilib   170.0 kB
  lib32-libcap                   2.69-1                                                        multilib   30.1 kB
  opusfile                       0.12-3                                                        community  65.6 kB
  lib32-pcre2                    10.42-1                                                       multilib   472.3 kB
  lib32-glib2                    2.76.2-1                                                      multilib   1.3 MB
  lib32-harfbuzz                 7.3.0-1                                                       multilib   797.8 kB
  lib32-libpng                   1.6.39-1                                                      multilib   132.4 kB
  lib32-freetype2                2.13.0-1                                                      multilib   395.5 kB
  lib32-fontconfig               2:2.14.2-1                                                    multilib   152.0 kB
  lib32-pixman                   0.42.2-1                                                      multilib   267.4 kB
  lib32-cairo                    1.17.8-2                                                      multilib   652.8 kB
  lib32-fribidi                  1.0.12-1                                                      multilib   22.8 kB
  lib32-libdatrie                0.2.13-2                                                      multilib   15.1 kB
  lib32-libthai                  0.1.29-2                                                      multilib   17.7 kB
  lib32-libxft                   2.3.8-1                                                       multilib   44.8 kB
  lib32-pango                    1:1.50.14-1                                                   multilib   236.1 kB
  lib32-libgpg-error             1.47-1                                                        multilib   66.7 kB
  lib32-libgcrypt                1.10.2-1                                                      multilib   451.7 kB
  lib32-systemd                  253.4-1                                                       multilib   872.2 kB
  lib32-dbus                     1.14.6-2                                                      multilib   148.8 kB
  lib32-libdecor                 0.1.1-1                                                       multilib   31.5 kB
  lib32-libxkbcommon             1.5.0-1                                                       multilib   134.0 kB
  lib32-libxkbcommon-x11         1.5.0-1                                                       multilib   17.1 kB
  botan2                         2.19.3-1                                                      extra      2.2 MB
  libtorrent-rasterbar           1:2.0.8-4                     (Required By: qbittorrent)      extra      2.6 MB
Checking integrity...                                                      [2/2]
Loading packages files...                                                  [2/2]
Checking file conflicts...                                                 [2/2]
Checking available disk space...                                           [2/2]
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade...                              [1/1]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Upgrading archlinux-keyring (20230320-1 -> 20230504-1)...                  [1/2]
==> Appending keys from archlinux.gpg...
==> Delete expired Key by Jonas Strassel
gpg: depth: 0  valid:   1  signed:  20  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  20  signed:  95  trust: 0-, 0q, 0n, 20m, 0f, 0u
gpg: next trustdb check due at 2023-08-02
  -> Disabled 8 keys.
Download of glibc (2.37-3) started
Download of linux-api-headers (6.3-1) finished
Download of a52dec (0.8.0-1) started
Download of a52dec (0.8.0-1) finished
Download of adwaita-cursors (44.0-1) started
Download of adwaita-cursors (44.0-1) finished
Download of util-linux-libs (2.38.1-4) started
Download of util-linux-libs (2.38.1-4) finished
Download of glibc (2.37-3) finished
Download of gcc-libs (13.1.1-1) started
Download of xz (5.4.3-1) started
Download of xz (5.4.3-1) finished
Download of libxml2 (2.10.4-4) started
Download of libxml2 (2.10.4-4) finished
Download of glib2 (2.76.2-1) started
Download of glib2 (2.76.2-1) finished
Download of harfbuzz (7.3.0-1) started
Download of harfbuzz (7.3.0-1) finished
Download of gcc-libs (13.1.1-1) finished
Download of brotli (1.0.9-12) started
Download of xcb-proto (1.15.2-3) started
Download of xcb-proto (1.15.2-3) finished
Download of brotli (1.0.9-12) finished
Download of gtk-update-icon-cache (1:4.10.3-2) started
Download of gtk-update-icon-cache (1:4.10.3-2) finished
Download of adwaita-icon-theme (44.0-1) started
Download of alsa-lib (1.2.9-1) started
Download of adwaita-icon-theme (44.0-1) finished
Download of alsa-lib (1.2.9-1) finished
Download of alsa-ucm-conf (1.2.9-1) started
Download of alsa-ucm-conf (1.2.9-1) finished
Download of alsa-utils (1.2.9-1) started
Download of alsa-utils (1.2.9-1) finished
Download of pciutils (3.10.0-1) started
Download of hwdata (0.370-1) started
Download of pciutils (3.10.0-1) finished
Download of protobuf (21.12-2) started
Download of protobuf (21.12-2) finished
Download of hwdata (0.370-1) finished
Download of libcap-ng (0.8.3-2) started
Download of libcap-ng (0.8.3-2) finished
Download of keyutils (1.6.3-2) started
Download of keyutils (1.6.3-2) finished
Download of audit (3.1.1-1) started
Download of pam (1.5.3-1) started
Download of audit (3.1.1-1) finished
Download of argon2 (20190702-5) started
Download of pam (1.5.3-1) finished
Download of argon2 (20190702-5) finished
Download of systemd-libs (253.4-1) started
Download of libcap (2.69-1) started
Download of systemd-libs (253.4-1) finished
Download of cryptsetup (2.6.1-3.4) started
Download of libcap (2.69-1) finished
Download of cryptsetup (2.6.1-3.4) finished
Download of kbd (2.5.1-2) started
Download of libseccomp (2.5.4-2) started
Download of libseccomp (2.5.4-2) finished
Download of kbd (2.5.1-2) finished
Download of util-linux (2.38.1-4) started
Download of ca-certificates-mozilla (3.89.1-1) started
Download of ca-certificates-mozilla (3.89.1-1) finished
Download of util-linux (2.38.1-4) finished
Download of libnghttp2 (1.53.0-1) started
Download of libnghttp2 (1.53.0-1) finished
Download of curl (8.1.2-1) started
Download of curl (8.1.2-1) finished
Download of systemd (253.4-1) started
Download of android-tools (34.0.1-1) started
Download of android-tools (34.0.1-1) finished
Download of systemd (253.4-1) finished
Download of python (3.11.3-1) started
Download of apparmor (3.1.3-2) started
Download of apparmor (3.1.3-2) finished
Download of aom (3.6.1-1) started
Download of aom (3.6.1-1) finished
Download of appstream (0.16.2-1) started
Download of python (3.11.3-1) finished
Download of appstream (0.16.2-1) finished
Download of libxi (1.8.1-1) started
Download of libxi (1.8.1-1) finished
Download of at-spi2-core (2.48.2-1) started
Download of sqlite (3.42.0-1) started
Download of at-spi2-core (2.48.2-1) finished
Download of sqlite (3.42.0-1) finished
Download of nettle (3.9-1) started
Download of avahi (0.8+22+gfd482a7-4) started
Download of nettle (3.9-1) finished
Download of avahi (0.8+22+gfd482a7-4) finished
Download of libcups (1:2.4.2-7) started
Download of libcups (1:2.4.2-7) finished
Download of double-conversion (3.3.0-1) started
Download of double-conversion (3.3.0-1) finished
Download of mesa (23.0.4-1) started
Download of llvm-libs (15.0.7-3) started
Download of mesa (23.0.4-1) finished
Download of libproxy (0.4.18-3) started
Download of llvm-libs (15.0.7-3) finished
Download of libproxy (0.4.18-3) finished
Download of libwacom (2.7.0-1) started
Download of libwacom (2.7.0-1) finished
Download of dav1d (1.2.0-1) started
Download of qt5-svg (5.15.9+kde+r8-1) started
Download of dav1d (1.2.0-1) finished
Download of qt5-svg (5.15.9+kde+r8-1) finished
Download of libevdev (1.13.1-1) started
Download of libevdev (1.13.1-1) finished
Download of libopenmpt (0.7.1-1) started
Download of libopenmpt (0.7.1-1) finished
Download of sdl2 (2.26.5-2) started
Download of libssh (0.10.5-1) started
Download of libssh (0.10.5-1) finished
Download of sdl2 (2.26.5-2) finished
Download of svt-av1 (1.5.0-1) started
Download of imath (3.1.7-2) started
Download of svt-av1 (1.5.0-1) finished
Download of perl (5.36.1-1) started
Download of imath (3.1.7-2) finished
Download of lib32-glibc (2.37-3) started
Download of lib32-glibc (2.37-3) finished
Download of ffmpeg (2:6.0-6) started
Download of perl (5.36.1-1) finished
Download of lirc (1:0.10.2-3) started
Download of lirc (1:0.10.2-3) finished
Download of libftdi (1.5-5) started
Download of libftdi (1.5-5) finished
Download of ffmpeg (2:6.0-6) finished
Download of opusfile (0.12-3) started
Download of opusfile (0.12-3) finished
Download of libpipewire (1:0.3.70-2) started
Download of libpipewire (1:0.3.70-2) finished
Download of audacious-plugins (4.3.1-1) started
Download of audacious (4.3.1-1) started
Download of audacious-plugins (4.3.1-1) finished
Download of audacious (4.3.1-1) finished
Download of binutils (2.40-5) started
Download of python-cairo (1.23.0-4) started
Download of python-cairo (1.23.0-4) finished
Download of binutils (2.40-5) finished
Download of libgirepository (1.76.1-3) started
Download of libgirepository (1.76.1-3) finished
Download of gobject-introspection-runtime (1.76.1-3) started
Download of python-gobject (3.44.1-3) started
Download of gobject-introspection-runtime (1.76.1-3) finished
Download of python-gobject (3.44.1-3) finished
Download of libsoup3 (3.4.2-1) started
Download of libsoup3 (3.4.2-1) finished
Download of iso-codes (4.15.0-1) started
Download of tracker3 (3.5.2-1) started
Download of tracker3 (3.5.2-1) finished
Download of iso-codes (4.15.0-1) finished
Download of nss (3.89.1-1) started
Download of nss (3.89.1-1) finished
Download of blueman (2.3.5-2) started
Download of boost-libs (1.81.0-6) started
Download of blueman (2.3.5-2) finished
Download of botan (3.0.0-1) started
Download of botan (3.0.0-1) finished
Download of boost-libs (1.81.0-6) finished
Download of dbus-python (1.2.18-5) started
Download of btrfs-progs (6.3-2) started
Download of dbus-python (1.2.18-5) finished
Download of btrfs-progs (6.3-2) finished
Download of python-ptyprocess (0.7.0-5) started
Download of python-ptyprocess (0.7.0-5) finished
Download of python-pexpect (4.8.0-7) started
Download of python-pexpect (4.8.0-7) finished
Download of mpfr (4.2.0.p7-2) started
Download of gcc (13.1.1-1) started
Download of mpfr (4.2.0.p7-2) finished
Download of catfish (4.16.4-2) started
Download of catfish (4.16.4-2) finished
Download of compiler-rt (15.0.7-2) started
Download of gcc (13.1.1-1) finished
Download of compiler-rt (15.0.7-2) finished
Download of clang (15.0.7-9) started
Download of poppler (23.05.0-1) started
Download of poppler (23.05.0-1) finished
Download of cups-filters (1.28.17-3) started
Download of cups-filters (1.28.17-3) finished
Download of cups (1:2.4.2-7) started
Download of clang (15.0.7-9) finished
Download of iproute2 (6.3.0-2) started
Download of cups (1:2.4.2-7) finished
Download of iproute2 (6.3.0-2) finished
Download of libbpf (1.2.0-1) started
Download of libbpf (1.2.0-1) finished
Download of dhcpcd (10.0.1-1) started
Download of dhcpcd (10.0.1-1) finished
Download of less (1:633-1) started
Download of elementary-icon-theme (7.3.0-1) started
Download of less (1:633-1) finished
Download of elementary-icon-theme (7.3.0-1) finished
Download of dhclient (4.4.3.P1-2) started
Download of engrampa (1.26.1-1) started
Download of engrampa (1.26.1-1) finished
Download of gnome-desktop-common (1:44.0-1) started
Download of gnome-desktop-common (1:44.0-1) finished
Download of dhclient (4.4.3.P1-2) finished
Download of gspell (1.12.1-1) started
Download of gspell (1.12.1-1) finished
Download of gnome-desktop (1:44.0-1) started
Download of gnome-desktop (1:44.0-1) finished
Download of gstreamer (1.22.2-1) started
Download of gstreamer (1.22.2-1) finished
Download of gst-plugins-base-libs (1.22.2-1) started
Download of gcr (3.41.1-4) started
Download of gst-plugins-base-libs (1.22.2-1) finished
Download of libbytesize (2.7-2) started
Download of libbytesize (2.7-2) finished
Download of gcr (3.41.1-4) finished
Download of lib32-gcc-libs (13.1.1-1) started
Download of tpm2-tss (4.0.1-1) started
Download of tpm2-tss (4.0.1-1) finished
Download of lib32-pam (1.5.3-1) started
Download of lib32-pam (1.5.3-1) finished
Download of lib32-libtirpc (1.3.3-2) started
Download of lib32-libtirpc (1.3.3-2) finished
Download of lib32-libcap (2.69-1) started
Download of lib32-libcap (2.69-1) finished
Download of gpgme (1.20.0-3) started
Download of lib32-gcc-libs (13.1.1-1) finished
Download of volume_key (0.3.12-8) started
Download of volume_key (0.3.12-8) finished
Download of gpgme (1.20.0-3) finished
Download of thin-provisioning-tools (1.0.4-1) started
Download of libblockdev (2.28-2) started
Download of thin-provisioning-tools (1.0.4-1) finished
Download of libblockdev (2.28-2) finished
Download of gvfs (1.50.4-3) started
Download of gvfs (1.50.4-3) finished
Download of poppler-glib (23.05.0-1) started
Download of poppler-glib (23.05.0-1) finished
Download of evince (44.1-1) started
Download of exfatprogs (1.2.1-1) started
Download of exfatprogs (1.2.1-1) finished
Download of evince (44.1-1) finished
Download of noto-fonts (20230501-1) started
Download of firefox (114.0.1-1) started
Download of noto-fonts (20230501-1) finished
Download of python-more-itertools (9.1.1-4) started
Download of python-more-itertools (9.1.1-4) finished
Download of python-jaraco.classes (3.2.3-3) started
Download of python-jaraco.classes (3.2.3-3) finished
Download of python-jeepney (0.8.0-2) started
Download of python-jeepney (0.8.0-2) finished
Download of python-ply (3.11-12) started
Download of python-ply (3.11-12) finished
Download of python-pycparser (2.21-5) started
Download of python-pycparser (2.21-5) finished
Download of firefox (114.0.1-1) finished
Download of python-cffi (1.15.1-3) started
Download of python-cffi (1.15.1-3) finished
Download of python-zipp (3.15.0-2) started
Download of python-zipp (3.15.0-2) finished
Download of python-secretstorage (3.3.3-2) started
Download of python-secretstorage (3.3.3-2) finished
Download of python-cryptography (40.0.2-1) started
Download of python-cryptography (40.0.2-1) finished
Download of python-importlib-metadata (5.0.0-5) started
Download of python-importlib-metadata (5.0.0-5) finished
Download of python-keyring (23.13.1-1) started
Download of python-keyring (23.13.1-1) finished
Download of python-idna (3.4-3) started
Download of python-idna (3.4-3) finished
Download of python-precis_i18n (1.0.5-1) started
Download of python-precis_i18n (1.0.5-1) finished
Download of python-nbxmpp (4.2.2-2) started
Download of python-nbxmpp (4.2.2-2) finished
Download of python-css-parser (1.0.9-1) started
Download of python-css-parser (1.0.9-1) finished
Download of python-distro (1.8.0-3) started
Download of python-distro (1.8.0-3) finished
Download of python-pillow (9.5.0-2) started
Download of python-pillow (9.5.0-2) finished
Download of python-decorator (5.1.1-3) started
Download of python-decorator (5.1.1-3) finished
Download of python-gssapi (1.8.2-2) started
Download of python-netifaces (0.11.0-4) started
Download of python-netifaces (0.11.0-4) finished
Download of python-gssapi (1.8.2-2) finished
Download of python-packaging (23.1-1) started
Download of python-packaging (23.1-1) finished
Download of gajim (1.7.3-2) started
Download of gawk (5.2.2-1) started
Download of gawk (5.2.2-1) finished
Download of gajim (1.7.3-2) finished
Download of gcr-4 (4.1.0-1) started
Download of gcr-4 (4.1.0-1) finished
Download of libpeas (1.36.0-2) started
Download of libpeas (1.36.0-2) finished
Download of gedit (44.2-2) started
Download of glslang (12.1.0-2) started
Download of gedit (44.2-2) finished
Download of glslang (12.1.0-2) finished
Download of gst-plugins-bad-libs (1.22.2-1) started
Download of gst-plugins-bad-libs (1.22.2-1) finished
Download of gtk4 (1:4.10.3-2) started
Download of gnome-desktop-4 (1:44.0-1) started
Download of gnome-desktop-4 (1:44.0-1) finished
Download of gtk4 (1:4.10.3-2) finished
Download of libtool (2.4.7+4+g1ec8fa28-3) started
Download of gpm (1.20.7.r38.ge82d1a6-5) started
Download of gpm (1.20.7.r38.ge82d1a6-5) finished
Download of libtool (2.4.7+4+g1ec8fa28-3) finished
Download of libheif (1.16.1-2) started
Download of graphviz (8.0.5-2) started
Download of libheif (1.16.1-2) finished
Download of graphviz (8.0.5-2) finished
Download of gst-libav (1.22.2-1) started
Download of grep (3.11-1) started
Download of gst-libav (1.22.2-1) finished
Download of grep (3.11-1) finished
Download of lilv (0.24.20-2) started
Download of lilv (0.24.20-2) finished
Download of zbar (0.23.90-2) started
Download of zbar (0.23.90-2) finished
Download of imagemagick (7.1.1.9-1) started
Download of libxslt (1.1.37-3) started
Download of libxslt (1.1.37-3) finished
Download of gst-plugins-bad (1.22.2-1) started
Download of imagemagick (7.1.1.9-1) finished
Download of gst-plugins-bad (1.22.2-1) finished
Download of imlib2 (1.11.1-1) started
Download of gst-plugins-base (1.22.2-1) started
Download of imlib2 (1.11.1-1) finished
Download of gst-plugins-base (1.22.2-1) finished
Download of gst-plugins-ugly (1.22.2-1) started
Download of gst-plugins-ugly (1.22.2-1) finished
Download of gst-plugins-good (1.22.2-1) started
Download of gst-plugins-good (1.22.2-1) finished
Download of ufw (0.36.2-1) started
Download of ufw (0.36.2-1) finished
Download of harfbuzz-icu (7.3.0-1) started
Download of harfbuzz-icu (7.3.0-1) finished
Download of webkit2gtk (2.40.1-2) started
Download of libplist (2.3.0-1) started
Download of libplist (2.3.0-1) finished
Download of libusbmuxd (2.0.2-2) started
Download of libusbmuxd (2.0.2-2) finished
Download of gufw (22.04-2) started
Download of gufw (22.04-2) finished
Download of libimobiledevice (1.3.0-8) started
Download of libimobiledevice (1.3.0-8) finished
Download of gvfs-afc (1.50.4-3) started
Download of gvfs-afc (1.50.4-3) finished
Download of webkit2gtk (2.40.1-2) finished
Download of gvfs-gphoto2 (1.50.4-3) started
Download of gvfs-gphoto2 (1.50.4-3) finished
Download of gvfs-nfs (1.50.4-3) started
Download of gvfs-nfs (1.50.4-3) finished
Download of usbmuxd (1.1.1-3) started
Download of usbmuxd (1.1.1-3) finished
Download of tdb (1.4.8-2) started
Download of tdb (1.4.8-2) finished
Download of gvfs-mtp (1.50.4-3) started
Download of gvfs-mtp (1.50.4-3) finished
Download of talloc (2.4.0-3) started
Download of talloc (2.4.0-3) finished
Download of tevent (1:0.14.1-2) started
Download of tevent (1:0.14.1-2) finished
Download of libwbclient (4.18.2-2) started
Download of libwbclient (4.18.2-2) finished
Download of smbclient (4.18.2-2) started
Download of ldb (2:2.7.2-2) started
Download of ldb (2:2.7.2-2) finished
Download of smbclient (4.18.2-2) finished
Download of hexchat (2.16.1-4) started
Download of gvfs-smb (1.50.4-3) started
Download of gvfs-smb (1.50.4-3) finished
Download of ibus (1.5.28-4) started
Download of ibus (1.5.28-4) finished
Download of ibus-hangul (1.5.4-5) started
Download of ibus-hangul (1.5.4-5) finished
Download of hexchat (2.16.1-4) finished
Download of libibus (1.5.28-4) started
Download of intel-ucode (20230516-1) started
Download of libibus (1.5.28-4) finished
Download of kcoreaddons (5.106.0-1) started
Download of kcoreaddons (5.106.0-1) finished
Download of intel-ucode (20230516-1) finished
Download of kauth (5.106.0-1) started
Download of kauth (5.106.0-1) finished
Download of iw (5.19-2) started
Download of iw (5.19-2) finished
Download of kitemmodels (5.106.0-1) started
Download of kwindowsystem (5.106.0-1) started
Download of kitemmodels (5.106.0-1) finished
Download of kwindowsystem (5.106.0-1) finished
Download of lensfun (1:0.3.3-2) started
Download of lensfun (1:0.3.3-2) finished
Download of lib32-curl (8.1.0-1) started
Download of lib32-libxfixes (6.0.1-1) started
Download of lib32-libxfixes (6.0.1-1) finished
Download of lib32-curl (8.1.0-1) finished
Download of lib32-xz (5.4.3-1) started
Download of lib32-xz (5.4.3-1) finished
Download of lib32-libxml2 (2.10.4-4) started
Download of lib32-mesa (23.0.4-1) started
Download of lib32-libxml2 (2.10.4-4) finished
Download of lib32-libva (2.18.0-1) started
Download of lib32-libva (2.18.0-1) finished
Download of lib32-libva-mesa-driver (23.0.4-1) started
Download of lib32-libva-mesa-driver (23.0.4-1) finished
Download of lib32-libxi (1.8.1-1) started
Download of lib32-libxi (1.8.1-1) finished
Download of lib32-libxt (1.3.0-1) started
Download of lib32-libxt (1.3.0-1) finished
Download of lib32-mesa (23.0.4-1) finished
Download of lib32-pcre2 (10.42-1) started
Download of lib32-pcre2 (10.42-1) finished
Download of lib32-glib2 (2.76.2-1) started
Download of lib32-glib2 (2.76.2-1) finished
Download of lib32-harfbuzz (7.3.0-1) started
Download of lib32-harfbuzz (7.3.0-1) finished
Download of lib32-libpng (1.6.39-1) started
Download of lib32-libpng (1.6.39-1) finished
Download of lib32-freetype2 (2.13.0-1) started
Download of lib32-freetype2 (2.13.0-1) finished
Download of lib32-cairo (1.17.8-2) started
Download of lib32-pixman (0.42.2-1) started
Download of lib32-cairo (1.17.8-2) finished
Download of lib32-fribidi (1.0.12-1) started
Download of lib32-fribidi (1.0.12-1) finished
Download of lib32-pixman (0.42.2-1) finished
Download of lib32-fontconfig (2:2.14.2-1) started
Download of lib32-libdatrie (0.2.13-2) started
Download of lib32-libdatrie (0.2.13-2) finished
Download of lib32-libthai (0.1.29-2) started
Download of lib32-libthai (0.1.29-2) finished
Download of lib32-libxft (2.3.8-1) started
Download of lib32-libxft (2.3.8-1) finished
Download of lib32-pango (1:1.50.14-1) started
Download of lib32-fontconfig (2:2.14.2-1) finished
Download of lib32-pango (1:1.50.14-1) finished
Download of lib32-libgcrypt (1.10.2-1) started
Download of lib32-libgpg-error (1.47-1) started
Download of lib32-libgcrypt (1.10.2-1) finished
Download of lib32-libgpg-error (1.47-1) finished
Download of lib32-systemd (253.4-1) started
Download of lib32-systemd (253.4-1) finished
Download of lib32-dbus (1.14.6-2) started
Download of lib32-dbus (1.14.6-2) finished
Download of lib32-libxkbcommon (1.5.0-1) started
Download of lib32-libxkbcommon-x11 (1.5.0-1) started
Download of lib32-libxkbcommon-x11 (1.5.0-1) finished
Download of lib32-libdecor (0.1.1-1) started
Download of lib32-libdecor (0.1.1-1) finished
Download of lib32-libxkbcommon (1.5.0-1) finished
Download of lib32-mesa-demos (9.0.0-1) started
Download of libcamera-ipa (0.0.5-1) started
Download of libcamera-ipa (0.0.5-1) finished
Download of libgexiv2 (0.14.0-4) started
Download of libgexiv2 (0.14.0-4) finished
Download of lib32-mesa-demos (9.0.0-1) finished
Download of libmalcontent (0.11.1-2) started
Download of libixion (0.17.0-5) started
Download of libmalcontent (0.11.1-2) finished
Download of libixion (0.17.0-5) finished
Download of libcamera (0.0.5-1) started
Download of libcamera (0.0.5-1) finished
Download of libmwaw (0.3.22-1) started
Download of libmwaw (0.3.22-1) finished
Download of libnma-common (1.10.6-2) started
Download of libnma (1.10.6-2) started
Download of libnma (1.10.6-2) finished
Download of libnma-common (1.10.6-2) finished
Download of libnewt (0.52.23-2) started
Download of libnewt (0.52.23-2) finished
Download of liborcus (0.17.2-5) started
Download of python-npyscreen (4.10.5-8) started
Download of python-npyscreen (4.10.5-8) finished
Download of libopenraw (0.3.5-1) started
Download of libopenraw (0.3.5-1) finished
Download of python-urllib3 (1.26.15-1) started
Download of liborcus (0.17.2-5) finished
Download of python-chardet (5.1.0-3) started
Download of python-urllib3 (1.26.15-1) finished
Download of python-chardet (5.1.0-3) finished
Download of python-requests (2.28.2-4) started
Download of python-requests (2.28.2-4) finished
Download of python-certifi (2022.12.07-3) started
Download of python-certifi (2022.12.07-3) finished
Download of pacman-mirrors (4.23.2+3+g4148c3d-1) started
Download of pacman-mirrors (4.23.2+3+g4148c3d-1) finished
Download of pipewire (1:0.3.70-2) started
Download of libpamac (11.5.4-1) started
Download of pipewire (1:0.3.70-2) finished
Download of xdg-desktop-portal-gnome (44.1-2) started
Download of libpamac (11.5.4-1) finished
Download of xdg-desktop-portal-gnome (44.1-2) finished
Download of libpamac-flatpak-plugin (11.5.4-1) started
Download of libpamac-flatpak-plugin (11.5.4-1) finished
Download of snapd (2.59.4-1) started
Download of xdg-desktop-portal (1.16.0-3) started
Download of xdg-desktop-portal (1.16.0-3) finished
Download of qt5-declarative (5.15.9+kde+r25-1) started
Download of qt5-declarative (5.15.9+kde+r25-1) finished
Download of libwps (0.4.14-1) started
Download of libwps (0.4.14-1) finished
Download of libwpg (0.3.4-1) started
Download of libwpg (0.3.4-1) finished
Download of snapd (2.59.4-1) finished
Download of libreoffice-still (7.4.7-2) started
Download of libpamac-snap-plugin (11.5.4-1) started
Download of libpamac-snap-plugin (11.5.4-1) finished
Download of libupnp (1.14.17-1) started
Download of libupnp (1.14.17-1) finished
Download of libteam (1.31-8) started
Download of libteam (1.31-8) finished
Download of libva-mesa-driver (23.0.4-1) started
Download of libva-mesa-driver (23.0.4-1) finished
Download of libwmf (0.2.13-1) started
Download of libwmf (0.2.13-1) finished
Download of lightdm-gtk-greeter-settings (1.2.2-8) started
Download of lightdm-gtk-greeter-settings (1.2.2-8) finished
Download of linux61 (6.1.31-2) started
Download of libreoffice-still (7.4.7-2) finished
Download of llvm (15.0.7-3) started
Download of llvm (15.0.7-3) finished
Download of xorg-setxkbmap (1.3.4-1) started
Download of xorg-setxkbmap (1.3.4-1) finished
Download of luajit (2.1.0.beta3.r471.g224129a8-1) started
Download of luajit (2.1.0.beta3.r471.g224129a8-1) finished
Download of pamac-cli (10.5.1-2) started
Download of pamac-cli (10.5.1-2) finished
Download of manjaro-application-utility (1.3.3-9) started
Download of manjaro-application-utility (1.3.3-9) finished
Download of manjaro-release (23.0.0pre-1) started
Download of manjaro-release (23.0.0pre-1) finished
Download of pamac-gtk (10.5.1-2) started
Download of pamac-gtk (10.5.1-2) finished
Download of matcha-gtk-theme (20230403-2) started
Download of matcha-gtk-theme (20230403-2) finished
Download of meld (3.22.0-2) started
Download of meld (3.22.0-2) finished
Download of python-psutil (5.9.5-1) started
Download of python-psutil (5.9.5-1) finished
Download of memtest86+-efi (6.20-1) started
Download of memtest86+-efi (6.20-1) finished
Download of memtest86+ (6.20-1) started
Download of memtest86+ (6.20-1) finished
Download of python-pyxdg (0.28-2) started
Download of python-pyxdg (0.28-2) finished
Download of mousepad (0.6.1-2) started
Download of mousepad (0.6.1-2) finished
Download of mugshot (0.4.3-5) started
Download of mugshot (0.4.3-5) finished
Download of menulibre (2.2.3-5) started
Download of menulibre (2.2.3-5) finished
Download of network-manager-applet (1.32.0-2) started
Download of network-manager-applet (1.32.0-2) finished
Download of nm-connection-editor (1.32.0-2) started
Download of nm-connection-editor (1.32.0-2) finished
Download of nftables (1:1.0.7-2) started
Download of nftables (1:1.0.7-2) finished
Download of openconnect (1:9.10-1) started
Download of openconnect (1:9.10-1) finished
Download of open-vm-tools (6:12.2.0-2) started
Download of open-vm-tools (6:12.2.0-2) finished
Download of linux61 (6.1.31-2) finished
Download of openvpn (2.6.4-1) started
Download of openresolv (3.13.1-1) started
Download of openresolv (3.13.1-1) finished
Download of openvpn (2.6.4-1) finished
Download of python-typing_extensions (4.5.0-4) started
Download of python-typing_extensions (4.5.0-4) finished
Download of python-lxml (4.9.2-3) started
Download of python-lxml (4.9.2-3) finished
Download of python-deprecation (2.1.0-8) started
Download of python-deprecation (2.1.0-8) finished
Download of python-pikepdf (7.2.0-2) started
Download of python-six (1.16.0-8) started
Download of python-six (1.16.0-8) finished
Download of python-pikepdf (7.2.0-2) finished
Download of python-dateutil (2.8.2-5) started
Download of python-dateutil (2.8.2-5) finished
Download of python-jaraco.functools (3.6.0-3) started
Download of python-jaraco.functools (3.6.0-3) finished
Download of python-jaraco.context (4.3.0-3) started
Download of python-jaraco.context (4.3.0-3) finished
Download of python-autocommand (2.2.2-4) started
Download of python-autocommand (2.2.2-4) finished
Download of python-jaraco.text (3.11.1-3) started
Download of python-jaraco.text (3.11.1-3) finished
Download of python-inflect (6.0.4-2) started
Download of python-ordered-set (4.1.0-4) started
Download of python-ordered-set (4.1.0-4) finished
Download of python-inflect (6.0.4-2) finished
Download of python-pydantic (1.10.7-4) started
Download of python-pydantic (1.10.7-4) finished
Download of python-tomli (2.0.1-3) started
Download of python-tomli (2.0.1-3) finished
Download of python-fastjsonschema (2.16.3-4) started
Download of python-fastjsonschema (2.16.3-4) finished
Download of python-platformdirs (3.5.1-1) started
Download of python-platformdirs (3.5.1-1) finished
Download of python-trove-classifiers (2023.4.25-1) started
Download of python-trove-classifiers (2023.4.25-1) finished
Download of python-setuptools (1:67.7.0-1) started
Download of python-setuptools (1:67.7.0-1) finished
Download of pdfarranger (1.9.2-2) started
Download of python-validate-pyproject (0.12.2-4) started
Download of python-validate-pyproject (0.12.2-4) finished
Download of pdfarranger (1.9.2-2) finished
Download of shiboken6 (6.5.0-2) started
Download of vulkan-headers (1:1.3.248-1) started
Download of vulkan-headers (1:1.3.248-1) finished
Download of shiboken6 (6.5.0-2) finished
Download of perl-uri (5.18-1) started
Download of perl-uri (5.18-1) finished
Download of pyside6 (6.5.0-2) started
Download of python-protobuf (21.12-2) started
Download of python-protobuf (21.12-2) finished
Download of python-axolotl-curve25519 (0.4.1.2-9) started
Download of python-axolotl-curve25519 (0.4.1.2-9) finished
Download of pyside6 (6.5.0-2) finished
Download of python-axolotl (0.2.3-6) started
Download of python-axolotl (0.2.3-6) finished
Download of python-docopt (0.6.2-12) started
Download of python-docopt (0.6.2-12) finished
Download of python-systemd (235-2) started
Download of python-systemd (235-2) finished
Download of python-keyutils (0.6-9) started
Download of python-keyutils (0.6-9) finished
Download of python-manjaro-sdk (0.9-2) started
Download of python-manjaro-sdk (0.9-2) finished
Download of qmmp (2.1.3-1) started
Download of samba (4.18.2-2) started
Download of qmmp (2.1.3-1) finished
Download of samba (4.18.2-2) finished
Download of sof-firmware (2.2.5-1) started
Download of python-yaml (6.0-3) started
Download of python-yaml (6.0-3) finished
Download of sof-firmware (2.2.5-1) finished
Download of systemd-sysvcompat (253.4-1) started
Download of systemd-sysvcompat (253.4-1) finished
Download of thunar (4.18.6-1) started
Download of thunarx-python (0.5.2-4) started
Download of thunarx-python (0.5.2-4) finished
Download of thunar (4.18.6-1) finished
Download of botan2 (2.19.3-1) started
Download of thunderbird (102.12.0-1) started
Download of botan2 (2.19.3-1) finished
Download of udiskie (2.4.2-2) started
Download of udiskie (2.4.2-2) finished
Download of ttf-noto-nerd (3.0.1-1) started
Download of ttf-noto-nerd (3.0.1-1) finished
Download of upower (1.90.0-4) started
Download of upower (1.90.0-4) finished
Download of unrar (1:6.2.7-1) started
Download of unrar (1:6.2.7-1) finished
Download of virtualbox-guest-utils (7.0.8-2) started
Download of virtualbox-guest-utils (7.0.8-2) finished
Download of webkit2gtk-4.1 (2.40.1-2) started
Download of thunderbird (102.12.0-1) finished
Download of wireless-regdb (2023.05.03-1) started
Download of wireless-regdb (2023.05.03-1) finished
Download of xcursor-breeze (5.27.5-1) started
Download of xcursor-breeze (5.27.5-1) finished
Download of xapp (2.4.3-2) started
Download of xapp (2.4.3-2) finished
Download of webkit2gtk-4.1 (2.40.1-2) finished
Download of xfce4-mpc-plugin (0.5.3-1) started
Download of xfce4-mpc-plugin (0.5.3-1) finished
Download of xfce4-netload-plugin (1.4.1-1) started
Download of xfce4-netload-plugin (1.4.1-1) finished
Download of xfce4-screenshooter (1.10.4-1) started
Download of xfce4-screenshooter (1.10.4-1) finished
Download of xorg-xdpyinfo (1.3.4-1) started
Download of xorg-xdpyinfo (1.3.4-1) finished
Download of yelp (42.2-2) started
Download of yelp (42.2-2) finished
Download of yt-dlp (2023.03.04-2) started
Download of zsh-theme-powerlevel10k (1.18.0-1) started
Download of zsh-theme-powerlevel10k (1.18.0-1) finished
Download of yt-dlp (2023.03.04-2) finished
Download of qt6-svg (6.5.0-1) started
Download of qt6-svg (6.5.0-1) finished
Download of libtorrent-rasterbar (1:2.0.8-4) started
Download of qbittorrent (4.5.2-1) started
Download of libtorrent-rasterbar (1:2.0.8-4) finished
Download of qbittorrent (4.5.2-1) finished
Checking keyring...                                                    [343/343]
Checking integrity...                                                  [343/343]
Loading packages files...                                              [343/343]
Checking file conflicts...                                             [343/343]
Checking available disk space...                                       [343/343]
Creating Timeshift snapshot before upgrade...                              [1/4]
Removing linux initcpios...                                                [2/4]
Remove Firefox Distribution Settings                                       [3/4]
Remove Thunderbird Distribution Settings                                   [4/4]
Upgrading linux-api-headers (6.1.9-1 -> 6.3-1)...                        [1/343]
Upgrading tzdata (2023c-1 -> 2023c-2)...                                 [2/343]
Upgrading glibc (2.37-2 -> 2.37-3)...                                    [3/343]
Generating locales...
  en_US.UTF-8... done
  ko_KR.UTF-8... done
  en_US.UTF-8... done
Upgrading util-linux-libs (2.38.1-3 -> 2.38.1-4)...                      [6/343]
Upgrading gcc-libs (12.2.1-2 -> 13.1.1-1)...                             [7/343]
Upgrading glib2 (2.76.1-1 -> 2.76.2-1)...                                [8/343]
Upgrading xz (5.4.2-1 -> 5.4.3-1)...                                     [9/343]
Upgrading libxml2 (2.10.4-2 -> 2.10.4-4)...                             [10/343]
Upgrading brotli (1.0.9-10 -> 1.0.9-12)...                              [11/343]
Upgrading harfbuzz (7.1.0-1 -> 7.3.0-1)...                              [12/343]
Upgrading xcb-proto (1.15.2-2 -> 1.15.2-3)...                           [13/343]
Upgrading gtk-update-icon-cache (1:4.10.3-1 -> 1:4.10.3-2)...           [14/343]
Upgrading adwaita-icon-theme (43-2 -> 44.0-1)...                        [15/343]
Upgrading alsa-ucm-conf (1.2.8-1 -> 1.2.9-1)...                         [16/343]
Upgrading alsa-lib (1.2.8-1 -> 1.2.9-1)...                              [17/343]
Upgrading hwdata (0.369-1 -> 0.370-1)...                                [18/343]
Upgrading pciutils (3.9.0-2 -> 3.10.0-1)...                             [19/343]
Upgrading alsa-utils (1.2.8-1 -> 1.2.9-1)...                            [20/343]
Upgrading protobuf (21.12-1 -> 21.12-2)...                              [21/343]
Upgrading libcap-ng (0.8.3-1 -> 0.8.3-2)...                             [22/343]
Upgrading keyutils (1.6.3-1 -> 1.6.3-2)...                              [23/343]
Upgrading audit (3.1-1 -> 3.1.1-1)...                                   [24/343]
Upgrading pam (1.5.2-2 -> 1.5.3-1)...                                   [25/343]
Upgrading argon2 (20190702-4 -> 20190702-5)...                          [26/343]
Upgrading libcap (2.68-1 -> 2.69-1)...                                  [27/343]
Upgrading systemd-libs (252.10-2 -> 253.4-1)...                         [28/343]
Upgrading cryptsetup (2.6.1-3.3 -> 2.6.1-3.4)...                        [29/343]
Upgrading kbd (2.5.1-1 -> 2.5.1-2)...                                   [30/343]
Upgrading libseccomp (2.5.4-1 -> 2.5.4-2)...                            [31/343]
Upgrading util-linux (2.38.1-3 -> 2.38.1-4)...                          [32/343]
Upgrading libnghttp2 (1.52.0-2 -> 1.53.0-1)...                          [33/343]
Upgrading ca-certificates-mozilla (3.89-1 -> 3.89.1-1)...               [34/343]
Upgrading curl (8.0.1-1 -> 8.1.2-1)...                                  [35/343]
Upgrading systemd (252.10-2 -> 253.4-1)...                              [36/343]
Upgrading android-tools (33.0.3-3 -> 34.0.1-1)...                       [37/343]
Upgrading aom (3.6.0-1 -> 3.6.1-1)...                                   [38/343]
Upgrading python (3.10.10-1 -> 3.11.3-1)...                             [39/343]
Upgrading apparmor (3.1.3-1 -> 3.1.3-2)...                              [40/343]
Upgrading appstream (0.16.1-2 -> 0.16.2-1)...                           [41/343]
Upgrading libxi (1.8-3 -> 1.8.1-1)...                                   [42/343]
Upgrading at-spi2-core (2.48.0-2 -> 2.48.2-1)...                        [43/343]
Upgrading sqlite (3.41.2-1 -> 3.42.0-1)...                              [44/343]
Upgrading avahi (0.8+22+gfd482a7-3 -> 0.8+22+gfd482a7-4)...             [45/343]
Upgrading nettle (3.8.1-1 -> 3.9-1)...                                  [46/343]
Upgrading libcups (1:2.4.2-6 -> 1:2.4.2-7)...                           [47/343]
Upgrading double-conversion (3.2.1-1 -> 3.3.0-1)...                     [48/343]
Upgrading llvm-libs (15.0.7-2 -> 15.0.7-3)...                           [49/343]
Upgrading mesa (23.0.3-1 -> 23.0.4-1)...                                [50/343]
Upgrading libproxy (0.4.18-2 -> 0.4.18-3)...                            [51/343]
Upgrading libevdev (1.13.0-1 -> 1.13.1-1)...                            [52/343]
Upgrading libwacom (2.6.0-2 -> 2.7.0-1)...                              [53/343]
Upgrading qt5-svg (5.15.9+kde+r7-1 -> 5.15.9+kde+r8-1)...               [54/343]
Upgrading dav1d (1.1.0-1 -> 1.2.0-1)...                                 [55/343]
Upgrading libopenmpt (0.6.10-1 -> 0.7.1-1)...                           [56/343]
Upgrading libssh (0.10.4-3 -> 0.10.5-1)...                              [57/343]
Upgrading sdl2 (2.26.5-1 -> 2.26.5-2)...                                [58/343]
Upgrading svt-av1 (1.4.1-1 -> 1.5.0-1)...                               [59/343]
Upgrading lib32-glibc (2.37-2 -> 2.37-3)...                             [60/343]
Upgrading imath (3.1.7-1 -> 3.1.7-2)...                                 [61/343]
Upgrading perl (5.36.0-3 -> 5.36.1-1)...                                [62/343]
Upgrading ffmpeg (2:6.0-5 -> 2:6.0-6)...                                [63/343]
Upgrading libftdi (1.5-4 -> 1.5-5)...                                   [64/343]
Upgrading lirc (1:0.10.2-2 -> 1:0.10.2-3)...                            [65/343]
Installing opusfile (0.12-3)...                                         [66/343]
Upgrading libpipewire (1:0.3.70-1 -> 1:0.3.70-2)...                     [67/343]
Upgrading audacious-plugins (4.2-4 -> 4.3.1-1)...                       [68/343]
Upgrading audacious (4.2-3 -> 4.3.1-1)...                               [69/343]
Upgrading binutils (2.40-4 -> 2.40-5)...                                [70/343]
Upgrading python-cairo (1.23.0-3 -> 1.23.0-4)...                        [71/343]
Upgrading libgirepository (1.76.1-1 -> 1.76.1-3)...                     [72/343]
Upgrading gobject-introspection-runtime (1.76.1-1 -> 1.76.1-3)...       [73/343]
Upgrading python-gobject (3.44.1-1 -> 3.44.1-3)...                      [74/343]
Upgrading iso-codes (4.13.0-1 -> 4.15.0-1)...                           [75/343]
Upgrading libsoup3 (3.4.1-1 -> 3.4.2-1)...                              [76/343]
Upgrading tracker3 (3.5.0-1 -> 3.5.2-1)...                              [77/343]
Upgrading nss (3.89-1 -> 3.89.1-1)...                                   [78/343]
Upgrading blueman (2.3.5-1 -> 2.3.5-2)...                               [79/343]
Upgrading boost-libs (1.81.0-3 -> 1.81.0-6)...                          [80/343]
Upgrading botan (2.19.3-1 -> 3.0.0-1)...                                [81/343]
Upgrading btrfs-progs (6.2.2-1 -> 6.3-2)...                             [82/343]
Upgrading dbus-python (1.2.18-4 -> 1.2.18-5)...                         [83/343]
Upgrading python-ptyprocess (0.7.0-4 -> 0.7.0-5)...                     [84/343]
Upgrading python-pexpect (4.8.0-6 -> 4.8.0-7)...                        [85/343]
Upgrading catfish (4.16.4-1 -> 4.16.4-2)...                             [86/343]
Upgrading mpfr (4.2.0-3 -> 4.2.0.p7-2)...                               [87/343]
Upgrading gcc (12.2.1-2 -> 13.1.1-1)...                                 [88/343]
Upgrading compiler-rt (15.0.7-1 -> 15.0.7-2)...                         [89/343]
Upgrading clang (15.0.7-2 -> 15.0.7-9)...                               [90/343]
Upgrading poppler (23.03.0-1 -> 23.05.0-1)...                           [91/343]
Upgrading cups-filters (1.28.17-2 -> 1.28.17-3)...                      [92/343]
Upgrading cups (1:2.4.2-6 -> 1:2.4.2-7)...                              [93/343]
Upgrading libbpf (1.1.0-1 -> 1.2.0-1)...                                [94/343]
Upgrading iproute2 (6.2.0-2 -> 6.3.0-2)...                              [95/343]
Upgrading dhclient (4.4.3.P1-1 -> 4.4.3.P1-2)...                        [96/343]
Upgrading dhcpcd (9.4.1-1 -> 10.0.1-1)...                               [97/343]
Upgrading elementary-icon-theme (7.2.0-1 -> 7.3.0-1)...                 [98/343]
Upgrading less (1:608-2 -> 1:633-1)...                                  [99/343]
Upgrading engrampa (1.26.0-1 -> 1.26.1-1)...                           [100/343]
Upgrading gnome-desktop-common (1:43.2-1 -> 1:44.0-1)...               [101/343]
Upgrading gnome-desktop (1:43.2-1 -> 1:44.0-1)...                      [102/343]
Upgrading gspell (1.12.0-2 -> 1.12.1-1)...                             [103/343]
Upgrading gstreamer (1.22.1-2 -> 1.22.2-1)...                          [104/343]
Upgrading gst-plugins-base-libs (1.22.1-2 -> 1.22.2-1)...              [105/343]
Upgrading tpm2-tss (3.2.0-3 -> 4.0.1-1)...                             [106/343]
Upgrading gcr (3.41.1-3 -> 3.41.1-4)...                                [107/343]
Upgrading libbytesize (2.7-1 -> 2.7-2)...                              [108/343]
Upgrading lib32-gcc-libs (12.2.1-2 -> 13.1.1-1)...                     [109/343]
Installing lib32-libtirpc (1.3.3-2)...                                 [110/343]
Installing lib32-pam (1.5.3-1)...                                      [111/343]
Installing lib32-libcap (2.69-1)...                                    [112/343]
Upgrading gpgme (1.20.0-1 -> 1.20.0-3)...                              [113/343]
Upgrading volume_key (0.3.12-7 -> 0.3.12-8)...                         [114/343]
Upgrading thin-provisioning-tools (1.0.3-1 -> 1.0.4-1)...              [115/343]
Upgrading libblockdev (2.28-1 -> 2.28-2)...                            [116/343]
Upgrading gvfs (1.50.4-1 -> 1.50.4-3)...                               [117/343]
Upgrading poppler-glib (23.03.0-1 -> 23.05.0-1)...                     [118/343]
Upgrading evince (43.1-2 -> 44.1-1)...                                 [119/343]
Upgrading exfatprogs (1.2.0-1 -> 1.2.1-1)...                           [120/343]
Upgrading noto-fonts (20230401-1 -> 20230501-1)...                     [121/343]
Upgrading firefox (113.0-0.1 -> 114.0.1-1)...                          [122/343]
Upgrading python-more-itertools (9.1.1-1 -> 9.1.1-4)...                [123/343]
Upgrading python-jaraco.classes (3.2.3-1 -> 3.2.3-3)...                [124/343]
Upgrading python-jeepney (0.8.0-1 -> 0.8.0-2)...                       [125/343]
Upgrading python-ply (3.11-10 -> 3.11-12)...                           [126/343]
Upgrading python-pycparser (2.21-3 -> 2.21-5)...                       [127/343]
Upgrading python-cffi (1.15.1-1 -> 1.15.1-3)...                        [128/343]
Upgrading python-cryptography (40.0.1-1 -> 40.0.2-1)...                [129/343]
Upgrading python-secretstorage (3.3.3-1 -> 3.3.3-2)...                 [130/343]
Upgrading python-zipp (3.15.0-1 -> 3.15.0-2)...                        [131/343]
Upgrading python-importlib-metadata (5.0.0-3 -> 5.0.0-5)...            [132/343]
Upgrading python-keyring (23.11.0-1 -> 23.13.1-1)...                   [133/343]
Upgrading python-idna (3.4-1 -> 3.4-3)...                              [134/343]
Upgrading python-precis_i18n (1.0.4-1 -> 1.0.5-1)...                   [135/343]
Upgrading python-nbxmpp (4.2.1-1 -> 4.2.2-2)...                        [136/343]
Upgrading python-css-parser (1.0.8-1 -> 1.0.9-1)...                    [137/343]
Upgrading python-distro (1.8.0-2 -> 1.8.0-3)...                        [138/343]
Upgrading python-pillow (9.4.0-2 -> 9.5.0-2)...                        [139/343]
Upgrading python-decorator (5.1.1-2 -> 5.1.1-3)...                     [140/343]
Upgrading python-gssapi (1.8.2-1 -> 1.8.2-2)...                        [141/343]
Upgrading python-netifaces (0.11.0-3 -> 0.11.0-4)...                   [142/343]
Upgrading python-packaging (23.0-1 -> 23.1-1)...                       [143/343]
Upgrading gajim (1.7.1-2 -> 1.7.3-2)...                                [144/343]
Upgrading gawk (5.2.1-2 -> 5.2.2-1)...                                 [145/343]
Upgrading gcr-4 (4.0.0-1 -> 4.1.0-1)...                                [146/343]
Upgrading libpeas (1.34.0-1 -> 1.36.0-2)...                            [147/343]
Upgrading gedit (44.2-1 -> 44.2-2)...                                  [148/343]
Upgrading glslang (12.1.0-1 -> 12.1.0-2)...                            [149/343]
Upgrading gst-plugins-bad-libs (1.22.1-2 -> 1.22.2-1)...               [150/343]
Upgrading gtk4 (1:4.10.3-1 -> 1:4.10.3-2)...                           [151/343]
Upgrading gnome-desktop-4 (1:43.2-1 -> 1:44.0-1)...                    [152/343]
Upgrading gpm (1.20.7.r38.ge82d1a6-4 -> 1.20.7.r38.ge82d1a6-5)...      [153/343]
Upgrading libtool (2.4.7+4+g1ec8fa28-2 -> 2.4.7+4+g1ec8fa28-3)...      [154/343]
Upgrading libheif (1.15.2-1 -> 1.16.1-2)...                            [155/343]
Upgrading graphviz (8.0.3-1 -> 8.0.5-2)...                             [156/343]
Upgrading grep (3.10-1 -> 3.11-1)...                                   [157/343]
Upgrading gst-libav (1.22.1-2 -> 1.22.2-1)...                          [158/343]
Upgrading lilv (0.24.20-1 -> 0.24.20-2)...                             [159/343]
Upgrading imagemagick (7.1.1.8-1 -> 7.1.1.9-1)...                      [160/343]
Upgrading zbar (0.23.90-1 -> 0.23.90-2)...                             [161/343]
Upgrading libxslt (1.1.37-2 -> 1.1.37-3)...                            [162/343]
Upgrading gst-plugins-bad (1.22.1-2 -> 1.22.2-1)...                    [163/343]
Upgrading gst-plugins-base (1.22.1-2 -> 1.22.2-1)...                   [164/343]
Upgrading imlib2 (1.11.0-1 -> 1.11.1-1)...                             [165/343]
Upgrading gst-plugins-good (1.22.1-2 -> 1.22.2-1)...                   [166/343]
Upgrading gst-plugins-ugly (1.22.1-2 -> 1.22.2-1)...                   [167/343]
Upgrading ufw (0.36.1-3 -> 0.36.2-1)...                                [168/343]
Upgrading harfbuzz-icu (7.1.0-1 -> 7.3.0-1)...                         [169/343]
Upgrading webkit2gtk (2.40.1-1 -> 2.40.1-2)...                         [170/343]
Upgrading gufw (22.04-1 -> 22.04-2)...                                 [171/343]
Upgrading libplist (2.2.0-6 -> 2.3.0-1)...                             [172/343]
Upgrading libusbmuxd (2.0.2-1 -> 2.0.2-2)...                           [173/343]
Upgrading libimobiledevice (1.3.0-6 -> 1.3.0-8)...                     [174/343]
Upgrading usbmuxd (1.1.1-2 -> 1.1.1-3)...                              [175/343]
Upgrading gvfs-afc (1.50.4-1 -> 1.50.4-3)...                           [176/343]
Upgrading gvfs-gphoto2 (1.50.4-1 -> 1.50.4-3)...                       [177/343]
Upgrading gvfs-mtp (1.50.4-1 -> 1.50.4-3)...                           [178/343]
Upgrading gvfs-nfs (1.50.4-1 -> 1.50.4-3)...                           [179/343]
Upgrading tdb (1.4.8-1 -> 1.4.8-2)...                                  [180/343]
Upgrading talloc (2.4.0-2 -> 2.4.0-3)...                               [181/343]
Upgrading tevent (1:0.14.1-1 -> 1:0.14.1-2)...                         [182/343]
Upgrading ldb (2:2.7.2-1 -> 2:2.7.2-2)...                              [183/343]
Upgrading libwbclient (4.18.2-1 -> 4.18.2-2)...                        [184/343]
Upgrading smbclient (4.18.2-1 -> 4.18.2-2)...                          [185/343]
Upgrading gvfs-smb (1.50.4-1 -> 1.50.4-3)...                           [186/343]
Upgrading hexchat (2.16.1-3 -> 2.16.1-4)...                            [187/343]
Upgrading libibus (1.5.28-3 -> 1.5.28-4)...                            [188/343]
Upgrading ibus (1.5.28-3 -> 1.5.28-4)...                               [189/343]
Upgrading ibus-hangul (1.5.4-3 -> 1.5.4-5)...                          [190/343]
Upgrading intel-ucode (20230214-1 -> 20230516-1)...                    [191/343]
Upgrading iw (5.19-1 -> 5.19-2)...                                     [192/343]
Upgrading kcoreaddons (5.105.0-1 -> 5.106.0-1)...                      [193/343]
Upgrading kauth (5.105.0-1 -> 5.106.0-1)...                            [194/343]
Upgrading kitemmodels (5.105.0-1 -> 5.106.0-1)...                      [195/343]
Upgrading kwindowsystem (5.105.0-1 -> 5.106.0-1)...                    [196/343]
Upgrading lensfun (1:0.3.3-1 -> 1:0.3.3-2)...                          [197/343]
Upgrading lib32-curl (8.0.1-1 -> 8.1.0-1)...                           [198/343]
Upgrading lib32-libxfixes (6.0.0-2 -> 6.0.1-1)...                      [199/343]
Upgrading lib32-xz (5.4.2-1 -> 5.4.3-1)...                             [200/343]
Upgrading lib32-libxml2 (2.10.4-2 -> 2.10.4-4)...                      [201/343]
Upgrading lib32-mesa (23.0.3-1 -> 23.0.4-1)...                         [202/343]
Upgrading lib32-libva (2.17.0-1 -> 2.18.0-1)...                        [203/343]
Upgrading lib32-libva-mesa-driver (23.0.3-1 -> 23.0.4-1)...            [204/343]
Upgrading lib32-libxi (1.8-2 -> 1.8.1-1)...                            [205/343]
Upgrading lib32-libxt (1.2.1-1 -> 1.3.0-1)...                          [206/343]
Installing lib32-pcre2 (10.42-1)...                                    [207/343]
Installing lib32-glib2 (2.76.2-1)...                                   [208/343]
Installing lib32-harfbuzz (7.3.0-1)...                                 [209/343]
Installing lib32-libpng (1.6.39-1)...                                  [210/343]
Installing lib32-freetype2 (2.13.0-1)...                               [211/343]
Installing lib32-fontconfig (2:2.14.2-1)...                            [212/343]
Rebuilding 32-bit fontconfig cache...
Installing lib32-pixman (0.42.2-1)...                                  [213/343]
Installing lib32-cairo (1.17.8-2)...                                   [214/343]
Installing lib32-fribidi (1.0.12-1)...                                 [215/343]
Installing lib32-libdatrie (0.2.13-2)...                               [216/343]
Installing lib32-libthai (0.1.29-2)...                                 [217/343]
Installing lib32-libxft (2.3.8-1)...                                   [218/343]
Installing lib32-pango (1:1.50.14-1)...                                [219/343]
Installing lib32-libgpg-error (1.47-1)...                              [220/343]
Installing lib32-libgcrypt (1.10.2-1)...                               [221/343]
Installing lib32-systemd (253.4-1)...                                  [222/343]
Installing lib32-dbus (1.14.6-2)...                                    [223/343]
Installing lib32-libdecor (0.1.1-1)...                                 [224/343]
Installing lib32-libxkbcommon (1.5.0-1)...                             [225/343]
Installing lib32-libxkbcommon-x11 (1.5.0-1)...                         [226/343]
Upgrading lib32-mesa-demos (8.5.0-1 -> 9.0.0-1)...                     [227/343]
Upgrading libcamera-ipa (0.0.4-4 -> 0.0.5-1)...                        [228/343]
Upgrading libcamera (0.0.4-4 -> 0.0.5-1)...                            [229/343]
Upgrading libgexiv2 (0.14.0-3 -> 0.14.0-4)...                          [230/343]
Upgrading libixion (0.17.0-4 -> 0.17.0-5)...                           [231/343]
Upgrading libmalcontent (0.11.1-1 -> 0.11.1-2)...                      [232/343]
Upgrading libmwaw (0.3.21-3 -> 0.3.22-1)...                            [233/343]
Upgrading libnewt (0.52.23-1 -> 0.52.23-2)...                          [234/343]
Upgrading libnma-common (1.10.6-1 -> 1.10.6-2)...                      [235/343]
Upgrading libnma (1.10.6-1 -> 1.10.6-2)...                             [236/343]
Upgrading libopenraw (0.3.4-1 -> 0.3.5-1)...                           [237/343]
Upgrading liborcus (0.17.2-4 -> 0.17.2-5)...                           [238/343]
Upgrading python-npyscreen (4.10.5-7 -> 4.10.5-8)...                   [239/343]
Upgrading python-urllib3 (1.26.13-1 -> 1.26.15-1)...                   [240/343]
Upgrading python-chardet (5.1.0-1 -> 5.1.0-3)...                       [241/343]
Upgrading python-requests (2.28.2-1 -> 2.28.2-4)...                    [242/343]
Upgrading python-certifi (2022.12.07-1 -> 2022.12.07-3)...             [243/343]
Upgrading pacman-mirrors (4.23.2+2+g2f58b3c-3 -> 4.23.2+3+g4148c3d-1)... [244/343]
Upgrading libpamac (11.5.3-1 -> 11.5.4-1)...                           [245/343]
Upgrading pipewire (1:0.3.70-1 -> 1:0.3.70-2)...                       [246/343]
Upgrading xdg-desktop-portal-gnome (43.1-1 -> 44.1-2)...               [247/343]
Upgrading xdg-desktop-portal (1.16.0-1 -> 1.16.0-3)...                 [248/343]
Upgrading libpamac-flatpak-plugin (11.5.3-1 -> 11.5.4-1)...            [249/343]
Upgrading snapd (2.59.1-1 -> 2.59.4-1)...                              [250/343]
Upgrading qt5-declarative (5.15.9+kde+r24-1 -> 5.15.9+kde+r25-1)...    [251/343]
Upgrading libpamac-snap-plugin (11.5.3-1 -> 11.5.4-1)...               [252/343]
Upgrading libwps (0.4.13-1 -> 0.4.14-1)...                             [253/343]
Upgrading libwpg (0.3.3-4 -> 0.3.4-1)...                               [254/343]
Upgrading libreoffice-still (7.4.6-1 -> 7.4.7-2)...                    [255/343]
Upgrading libteam (1.31-7 -> 1.31-8)...                                [256/343]
Upgrading libupnp (1.14.16-1 -> 1.14.17-1)...                          [257/343]
Upgrading libva-mesa-driver (23.0.3-1 -> 23.0.4-1)...                  [258/343]
Upgrading libwmf (0.2.12-3 -> 0.2.13-1)...                             [259/343]
Upgrading xorg-setxkbmap (1.3.3-2 -> 1.3.4-1)...                       [260/343]
Upgrading lightdm-gtk-greeter-settings (1.2.2-7 -> 1.2.2-8)...         [261/343]
Upgrading linux61 (6.1.31-1 -> 6.1.31-2)...                            [262/343]
Upgrading llvm (15.0.7-2 -> 15.0.7-3)...                               [263/343]
Upgrading luajit (2.1.0.beta3.r471.g505e2c03-1 -> 2.1.0.beta3.r471.g224129a8-1)... [264/343]
Upgrading pamac-cli (10.5.1-1 -> 10.5.1-2)...                          [265/343]
Upgrading pamac-gtk (10.5.1-1 -> 10.5.1-2)...                          [266/343]
Upgrading manjaro-application-utility (1.3.3-7 -> 1.3.3-9)...          [267/343]
Upgrading manjaro-release (22.1.3-1 -> 23.0.0pre-1)...                 [268/343]
Upgrading matcha-gtk-theme (20230403-1 -> 20230403-2)...               [269/343]
To force Libadwaita appliations to use the gtk-4.0 theme,
symlink the gtk-4.0 theme to config folder
(replace Matcha-dark-sea with chosen theme variant):
mkdir -p ~/.config/gtk-4.0/
ln -sf /usr/share/themes/Matcha-dark-sea/gtk-4.0/{assets,gtk.css,gtk-dark.css} ~/.config/gtk-4.0/
Upgrading meld (3.22.0-1 -> 3.22.0-2)...                               [270/343]
Upgrading memtest86+ (6.10-1 -> 6.20-1)...                             [271/343]
Upgrading memtest86+-efi (6.10-1 -> 6.20-1)...                         [272/343]
Upgrading python-psutil (5.9.4-1 -> 5.9.5-1)...                        [273/343]
Upgrading python-pyxdg (0.28-1 -> 0.28-2)...                           [274/343]
Upgrading menulibre (2.2.3-3 -> 2.2.3-5)...                            [275/343]
Upgrading mousepad (0.6.0-1 -> 0.6.1-2)...                             [276/343]
Upgrading mugshot (0.4.3-3 -> 0.4.3-5)...                              [277/343]
Upgrading nm-connection-editor (1.32.0-1 -> 1.32.0-2)...               [278/343]
Upgrading network-manager-applet (1.32.0-1 -> 1.32.0-2)...             [279/343]
Upgrading nftables (1:1.0.7-1 -> 1:1.0.7-2)...                         [280/343]
Upgrading open-vm-tools (6:12.2.0-1 -> 6:12.2.0-2)...                  [281/343]
/etc/pam.d/vmtoolsd installed as /etc/pam.d/vmtoolsd.pacnew.
Upgrading openconnect (1:9.01-2 -> 1:9.10-1)...                        [282/343]
Upgrading openresolv (3.13.0-1 -> 3.13.1-1)...                         [283/343]
Upgrading openvpn (2.6.3-1 -> 2.6.4-1)...                              [284/343]
Upgrading python-lxml (4.9.2-1 -> 4.9.2-3)...                          [285/343]
Upgrading python-deprecation (2.1.0-6 -> 2.1.0-8)...                   [286/343]
Upgrading python-typing_extensions (4.5.0-1 -> 4.5.0-4)...             [287/343]
Upgrading python-pikepdf (7.2.0-1 -> 7.2.0-2)...                       [288/343]
Upgrading python-six (1.16.0-6 -> 1.16.0-8)...                         [289/343]
Upgrading python-dateutil (2.8.2-4 -> 2.8.2-5)...                      [290/343]
Upgrading python-jaraco.functools (3.6.0-1 -> 3.6.0-3)...              [291/343]
Upgrading python-jaraco.context (4.3.0-1 -> 4.3.0-3)...                [292/343]
Upgrading python-autocommand (2.2.2-1 -> 2.2.2-4)...                   [293/343]
Upgrading python-pydantic (1.10.7-2 -> 1.10.7-4)...                    [294/343]
Upgrading python-inflect (6.0.4-1 -> 6.0.4-2)...                       [295/343]
Upgrading python-jaraco.text (3.11.1-1 -> 3.11.1-3)...                 [296/343]
Upgrading python-ordered-set (4.1.0-1 -> 4.1.0-4)...                   [297/343]
Upgrading python-platformdirs (3.2.0-1 -> 3.5.1-1)...                  [298/343]
Upgrading python-tomli (2.0.1-1 -> 2.0.1-3)...                         [299/343]
Upgrading python-fastjsonschema (2.16.3-1 -> 2.16.3-4)...              [300/343]
Upgrading python-trove-classifiers (2023.4.18-1 -> 2023.4.25-1)...     [301/343]
Upgrading python-validate-pyproject (0.12.2-1 -> 0.12.2-4)...          [302/343]
Upgrading python-setuptools (1:67.6.1-1 -> 1:67.7.0-1)...              [303/343]
Upgrading pdfarranger (1.9.2-1 -> 1.9.2-2)...                          [304/343]
Upgrading perl-uri (5.17-1 -> 5.18-1)...                               [305/343]
Upgrading vulkan-headers (1:1.3.246-1 -> 1:1.3.248-1)...               [306/343]
Upgrading shiboken6 (6.5.0-1 -> 6.5.0-2)...                            [307/343]
Upgrading pyside6 (6.5.0-1 -> 6.5.0-2)...                              [308/343]
Upgrading python-protobuf (21.12-1 -> 21.12-2)...                      [309/343]
Upgrading python-axolotl-curve25519 (0.4.1.2-8 -> 0.4.1.2-9)...        [310/343]
Upgrading python-axolotl (0.2.3-5 -> 0.2.3-6)...                       [311/343]
Upgrading python-docopt (0.6.2-11 -> 0.6.2-12)...                      [312/343]
Upgrading python-keyutils (0.6-8 -> 0.6-9)...                          [313/343]
Upgrading python-systemd (235-1 -> 235-2)...                           [314/343]
Upgrading python-manjaro-sdk (0.9-1 -> 0.9-2)...                       [315/343]
Upgrading python-yaml (6.0-1 -> 6.0-3)...                              [316/343]
Upgrading qmmp (2.1.2-2 -> 2.1.3-1)...                                 [317/343]
Upgrading samba (4.18.2-1 -> 4.18.2-2)...                              [318/343]
Upgrading sof-firmware (2.2.4-1 -> 2.2.5-1)...                         [319/343]
Upgrading systemd-sysvcompat (252.10-2 -> 253.4-1)...                  [320/343]
Upgrading thunar (4.18.4-1 -> 4.18.6-1)...                             [321/343]
Upgrading thunarx-python (0.5.2-3 -> 0.5.2-4)...                       [322/343]
Installing botan2 (2.19.3-1)...                                        [323/343]
Upgrading thunderbird (102.11.0-0.1 -> 102.12.0-1)...                  [324/343]
Upgrading ttf-noto-nerd (2.3.3-2 -> 3.0.1-1)...                        [325/343]
Upgrading udiskie (2.4.2-1 -> 2.4.2-2)...                              [326/343]
Upgrading unrar (1:6.2.6-1 -> 1:6.2.7-1)...                            [327/343]
Upgrading upower (1.90.0-3 -> 1.90.0-4)...                             [328/343]
Upgrading virtualbox-guest-utils (7.0.8-1 -> 7.0.8-2)...               [329/343]
Upgrading webkit2gtk-4.1 (2.40.1-1 -> 2.40.1-2)...                     [330/343]
Upgrading wireless-regdb (2023.02.13-1 -> 2023.05.03-1)...             [331/343]
Upgrading xapp (2.4.3-1 -> 2.4.3-2)...                                 [332/343]
Upgrading xcursor-breeze (5.27.3-1 -> 5.27.5-1)...                     [333/343]
Upgrading xfce4-mpc-plugin (0.5.2-2 -> 0.5.3-1)...                     [334/343]
Upgrading xfce4-netload-plugin (1.4.0-1 -> 1.4.1-1)...                 [335/343]
Upgrading xfce4-screenshooter (1.10.3-1 -> 1.10.4-1)...                [336/343]
Upgrading xorg-xdpyinfo (1.3.3-4 -> 1.3.4-1)...                        [337/343]
Upgrading yelp (42.2-1 -> 42.2-2)...                                   [338/343]
Upgrading yt-dlp (2023.03.04-1 -> 2023.03.04-2)...                     [339/343]
Upgrading zsh-theme-powerlevel10k (1.17.0+23+g1cff2249-1 -> 1.18.0-1)... [340/343]
Installing libtorrent-rasterbar (1:2.0.8-4)...                         [341/343]
Installing qt6-svg (6.5.0-1)...                                        [342/343]
Installing qbittorrent (4.5.2-1)...                                    [343/343]
Creating system user accounts...                                          [1/35]
Updating journal message catalog...                                       [2/35]
Reloading system manager configuration...                                 [3/35]
Updating udev hardware database...                                        [4/35]
Applying kernel sysctl settings...                                        [5/35]
Creating temporary files...                                               [6/35]
Reloading device manager configuration...                                 [7/35]
Arming ConditionNeedsUpdate...                                            [8/35]
Updating the MIME type database...                                        [9/35]
Rebuilding certificate stores...                                         [10/35]
Updating module dependencies...                                          [11/35]
Restarting cronie for libc upgrade...                                    [12/35]
Updating linux initcpios...                                              [13/35]
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
  -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.31-2-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
loadkeys: Unable to open file: ko: No such file or directory
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
  -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
Updating the appstream cache...                                          [14/35]
âś” Metadata cache was updated successfully.
Updating Grub-Bootmenu                                                   [15/35]
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Reloading system bus configuration...                                    [16/35]
Updating system dconf databases...                                       [17/35]
Warn about old perl modules                                              [18/35]
Copy Firefox Distribution Settings                                       [19/35]
Updating fontconfig cache...                                             [20/35]
Updating 32-bit fontconfig cache...                                      [21/35]
Probing GDK-Pixbuf loader modules...                                     [22/35]
Updating GIO module cache...                                             [23/35]
Compiling GSettings XML schema files...                                  [24/35]
Probing GTK2 input method modules...                                     [25/35]
Probing GTK3 input method modules...                                     [26/35]
Updating icon theme caches...                                            [27/35]
Updating GTK4 module cache...                                            [28/35]
Reloading GVFS config...                                                 [29/35]
Hiding redundant menu entries                                            [30/35]
Configuring pacman-mirrors ...                                           [31/35]
::INFO => Mirror status: https://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
Updating the info directory file...                                      [32/35]
Copy Thunderbird Distribution Settings                                   [33/35]
Updating the desktop file MIME type cache...                             [34/35]
Updating X fontdir indices...                                            [35/35]
A restart is required for the changes to take effect.
[luna@jar ~]$
What do you mean with you having no updates? There were clearly updates.
pacman -Sy only updates the databases, not any package. For this, you should run pacman -Syu.
Looking at the updates, most of them were not even patch but only build releases.
And I’m not sure if you actually updated on June 4th. For example, less was updated to 1:633-1 with this stable update. Still, your command shows that it was at the version before.
A cursory spot-check suggests that these updates are consistent with going from the 2023-05-07 to the 2023-06-04 snapshot.
Thanks. Maybe my understanding of updates is wrong. I thought package updates accumulated somewhere and were released in a batch every 2 to 6 weeks, each batching constituting a post to the “Announcement” board for the Stable Branch (i.e. Stable Updates - Manjaro Linux Forum). That is, I thought that, between one post and the next (e.g. between the May 7 and the June 4 posts), there were no updates I could get even if I wanted to. Is this just wrong?
If that is wrong (i.e. there are, or can be, some updates between two adjacent posts), then there may be no mystery to solve. I just got “in between” updates.
If what I understood is right, then it seems we have to accept the conclusion that my record was faulty and that I actually never updated per June 4. Also you (and Takakage) seem to be finding other evidence for this possibility. (Though I remember being excited about my first ever update after installing this, to me, new distro.) (First, that is, apart from the update I ran immediately after installing the system.)
Usually yes. However, sometimes, there are fasttracked updates mostly for security issues (browsers) or if something is broken and needs immediate fixing with a new version.
Maybe your mirror was not synced yet?
That doesn’t sound like the massive updates I got.
Possibly. Anyway I believe I have to accept I messed up somewhere. It’s all very new. Thanks very much.
