I need to record a screen with audio in real-time .
At first I used RecordMyDesktop. It’s simple, it works, but it’s inconvenient to use because it takes a very long time to write the output file.
Then I tried the complicated OBS Studio.
Version 29.0.2-1 was installed successfully, but an error occurs at startup:
$ obs
obs: error while loading shared libraries: libavcodec.so.59: cannot open shared object file: No such file or directory
How can I fix this error?
Or perhaps there are other, more successful and simpler applications?
This is part of ffmpeg. But at least on stable branch on desktop there is no such version (59).
read whogotit; sudo pacman -Fyx $whogotit
libavcodec.so
[sudo] password for teo:
core is up to date
extra is up to date
multilib is up to date
extra/ffmpeg 2:6.1.1-6 [installed]
usr/lib/libavcodec.so
usr/lib/libavcodec.so.60
usr/lib/libavcodec.so.60.31.102
extra/ffmpeg4.4 4.4.4-4 [installed]
usr/lib/ffmpeg4.4/libavcodec.so
usr/lib/libavcodec.so.58
usr/lib/libavcodec.so.58.134.100
On desktop (x64) i use VokoscreenNG and it works well.
How did you install that? Because the version in the official (stable) repository is 30.0.2-4.
Sorry, perhaps my Manjaro doesn’t want to be updated?
When I try to update Manjaro, it says it has already been updated.
He has been talking about this for a long time, more than one month, and it is suspicious
