Does manjaro support MT7927?
Hi I installed manjaro on my work PC but the blue tooth doesn’t work right.
So I’m thinking that may be it is the driver issue, I looked into it and found that the blue tooth is mediatek mt7927 bluetooth v5.4.
I haven’t found any method that I can install a proper driver for it…
There is no method, because as far as di know this device isn’t supported yet (if ever) in Linux. You can watch this repo, if you see any commits related to mt729 shortly after it should be available in Manjaro :wink:
