I wanted to install manjaro-iso-downloader today (KDE Plasma 5.27.11), but when I saw all the stuff that is installed as a dependency, I lost interest. What good does it do me, apart from an additional verification of the ISO, which I can also do manually?
sudo pacman -S manjaro-iso-downloader ✔
[sudo] Passwort für sandor:
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
Pakete (12) aria2-1.37.0-1 c-ares-1.27.0-1 enchant-2.6.5-1 gspell-1.12.2-2
gtksourceview3-1:3.24.11+r28+g73e57b57-1 libmanette-0.2.7-1 libwpe-1.14.2-1
webkit2gtk-4.1-2.42.5-2 woff2-1.0.2-4 wpebackend-fdo-1.14.2-1 yad-13.0-2
manjaro-iso-downloader-0.3.4-1
Gesamtgröße des Downloads: 29,84 MiB
Gesamtgröße der installierten Pakete: 114,82 MiB
:: Installation fortsetzen? [J/n]
omano ~ $ sudo pacman -Syu manjaro-iso-downloader
mesa-nonfree is up to date
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
Packages (1) manjaro-iso-downloader-0.3.4-1
Total Download Size: 0.01 MiB
Total Installed Size: 0.06 MiB
A lot of those depends you are grabbing are pretty basic packages that would often otherwise be already present.
woff is fonts. aria2 is download management gspell is gtk spelling checker webkit2gtk is gtk web content engine and often required by things like gamehub or telegram yad is a dialogue kit, a modernized zenity.
etc.
Nothing really.
As mentioned above it will use aria for the download so that may be more efficient than whatever other method you use.
It also provides all this functionality in a GUI so it is less scary to less experienced users.
But no, there arent many (or any) real technical benefits to using it over a regular download/check if you are comfortable doing that yourself.
