Hi, I lost a backup for Vivaldi session that was open 1 week ago, and on their forums, the last option they had was to check if there was a backup system set up and try to get the file back, is there something like that already set up for manjaro because I don’t believe that I manually did that myself.
No,
Manaro has some tools installed like Timeshift. But those are system snapshots (No user data/configuration) and would need to be set up anyway.
Any real backup would need to be set up on a separate storage and therefore would always need to be set up by the user/admin and either connect to a cloud storage or been managed manually.
No - there is no predefined backup system for user data.
btrfs or timeshift may assist in recovering files from a given point in time but they should never be regarded as a backup solution.
@linux-aarhus @Ganimede Thanks, tried timeshift no snapshots available.
