I have downgraded form the 6.1 to the 5.15 LTS kernel and i was wondering if that would cause any problems with my system?
Note: I first downgraded and then i installed my video-nvidia drivers
You mean you installed a second kernel and can now use this one as well as the one that was pre-installed.
Why not just boot it and try?
Worst case is it will not work.
Keep the other kernel so you have something that you know will work - you can have two or more.
i am using the 5.15 kernel right now and so far nothing visibly wrong has happened
I am more worried about things under the hood, not noticeable by day to day use
short answer:
don’t ![]()
start solving problems when they occur
ok will, thanks
5.15 is a long-term-support kernel, so it continues receiving security updates and bug fixes. Unless you have bleeding-edge hardware that requires support only available in the 6.x mainline kernel series, LTS kernels are the recommended choice.
