Docking Station will not display via DisplayPort
Newbie here! I recently installed Manjaro on my Dell XPS 15. I have a docking station (Dell WD19TB) to use two monitors, which connect via DisplayPort. Currently, the dock allows PCI devices (i.e., mouse, keyboard, webcam) to function but the monitors do not display.
The docking station will allow the laptop to display via HDMI. In addition, both monitors will display via DisplayPort when I boot from the installation disk. I believe that this may be an issue with my NVIDIA graphics card and corresponding drivers, but I can’t determine what is going on. Any assistance is appreciated!
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=c49f958f-fdf9-4c56-bfaa-1d8106924c8c rw quiet apparmor=1
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 05FFDN v: A00 serial: <filter> UEFI: Dell v: 1.19.2
  date: 05/22/2020
  ID-1: BAT0 charge: 92.9 Wh condition: 92.9/97.0 Wh (96%) volts: 12.6/11.4
  model: LGC-LGC8.33 DELL 5XJ287A type: Li-ion serial: <filter> status: Full
  Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: D6
  L2 cache: 6144 KiB
  bogomips: 44817
  Speed: 800 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Type: l1tf
  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:591b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: N/A
  alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:1c8d
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus ID: 1-12:5 chip ID: 0c45:6713
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 dpi: 141 size: 346x194mm (13.6x7.6")
  diag: 397mm (15.6")
  OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
  bus ID: 00:1f.3 chip ID: 8086:a171
  Device-2: Realtek type: USB driver: snd-usb-audio bus ID: 3-2.3.4:7
  chip ID: 0bda:402e serial: <filter>
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: e000
  bus ID: 02:00.0 chip ID: 168c:003e
  Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:2
  chip ID: 0cf3:e301
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
  bus ID: 4-2.4:4 chip ID: 0bda:8153 serial: <filter>
  IF: enp11s0u2u4 state: down mac: <filter>
  Local Storage: total: 953.87 GiB used: 16.84 GiB (1.8%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV1T02 NVMe 1024GB
  size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: AADA4106 scheme: GPT
  ID-1: / raw size: 596.76 GiB size: 586.39 GiB (98.26%)
  used: 16.80 GiB (2.9%) fs: ext4 dev: /dev/nvme0n1p7
  System Temperatures: cpu: 60.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 2517 fan-2: 2504
  Processes: 234 Uptime: 1m Memory: 31.22 GiB used: 1.27 GiB (4.1%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1201 lib: 321
  flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
:+1: Welcome to Manjaro! :+1:
  • Is this a fairly new install? (how long have you been running like this)
  • Did you install Manjaro while your docking station and monitors were connected?
(You see where I’m going with this, right?)
:grin:
Thank you! Glad to be a part of this community :slight_smile:
I installed Manjaro last week. I did not install with the devices attached.
I don’t think I follow – still a newbie, so I’d appreciate if you spelled it out.
This is where I was going:
  • back up your documents (not the settings)
  • reinstall with everything attached.
  • restore your documents
:man_shrugging:
I will do that, but can you help me understand how the installation is changed and why I couldn’t configure my installation now to produce the same result?
I don’t have a docking station, but am hopeful that the automatic install will detect all your monitors when they’re connected during the installation phase…
I see – thank you for your help! I’ll be sure to update with how the re-install goes.
As you might guess, this worked! I guess the lesson learned is to trust the automatic install :sweat_smile:
Thank you @Fabby for your help! I really appreciate it.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
