Docker won't start
running sudo systemctl start docker
produces
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xeu docker.service" for details.
output of systemctl status docker.service
× docker.service - Docker Application Container Engine
     Loaded: loaded (/usr/lib/systemd/system/docker.service; disabled; preset: disabled)
     Active: failed (Result: exit-code) since Wed 2023-04-19 11:55:51 CEST; 1min 2s ago
TriggeredBy: × docker.socket
       Docs: https://docs.docker.com
    Process: 102689 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
   Main PID: 102689 (code=exited, status=1/FAILURE)
        CPU: 91ms
apr 19 11:55:51 luke-30bgs2s000 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
apr 19 11:55:51 luke-30bgs2s000 systemd[1]: Stopped Docker Application Container Engine.
apr 19 11:55:51 luke-30bgs2s000 systemd[1]: docker.service: Start request repeated too quickly.
apr 19 11:55:51 luke-30bgs2s000 systemd[1]: docker.service: Failed with result 'exit-code'.
apr 19 11:55:51 luke-30bgs2s000 systemd[1]: Failed to start Docker Application Container Engine.
output of journalctl -xeu docker.service
░░ Subject: A start job for unit docker.service has failed
░░ Defined-By: systemd
░░ A start job for unit docker.service has finished with a failure.
░░ The job identifier is 9014 and the job result is failed.
apr 19 12:03:56 luke-30bgs2s000 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit docker.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
apr 19 12:03:56 luke-30bgs2s000 systemd[1]: Stopped Docker Application Container Engine.
░░ Subject: A stop job for unit docker.service has finished
░░ A stop job for unit docker.service has finished.
░░ The job identifier is 9101 and the job result is done.
apr 19 12:03:56 luke-30bgs2s000 systemd[1]: docker.service: Start request repeated too quickly.
apr 19 12:03:56 luke-30bgs2s000 systemd[1]: docker.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit docker.service has entered the 'failed' state with result 'exit-code'.
apr 19 12:03:56 luke-30bgs2s000 systemd[1]: Failed to start Docker Application Container Engine.
░░ The job identifier is 9101 and the job result is failed.
output of journalctl --no-hostname --no-pager -u docker.service
apr 19 12:03:50 dockerd[103167]: time="2023-04-19T12:03:50.216124831+02:00" level=info msg="[core] [Channel #1] Channel deleted" module=grpc
apr 19 12:03:50 dockerd[103167]: failed to start daemon: error initializing graphdriver: driver not supported
apr 19 12:03:50 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
apr 19 12:03:50 systemd[1]: docker.service: Failed with result 'exit-code'.
apr 19 12:03:50 systemd[1]: Failed to start Docker Application Container Engine.
apr 19 12:03:52 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
apr 19 12:03:52 systemd[1]: Stopped Docker Application Container Engine.
apr 19 12:03:52 systemd[1]: Starting Docker Application Container Engine...
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.562939796+02:00" level=info msg="Starting up"
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563783245+02:00" level=info msg="[core] [Channel #1] Channel created" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563798942+02:00" level=info msg="[core] [Channel #1] original dial target is: \"unix:///run/containerd/containerd.sock\"" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563818196+02:00" level=info msg="[core] [Channel #1] parsed dial target is: {Scheme:unix Authority: Endpoint:run/containerd/containerd.sock URL:{Scheme:unix Opaque: User: Host: Path:/run/containerd/containerd.sock RawPath: OmitHost:false ForceQuery:false RawQuery: Fragment: RawFragment:}}" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563827679+02:00" level=info msg="[core] [Channel #1] Channel authority set to \"localhost\"" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563891058+02:00" level=info msg="[core] [Channel #1] Resolver state updated: {\n  \"Addresses\": [\n    {\n      \"Addr\": \"/run/containerd/containerd.sock\",\n      \"ServerName\": \"\",\n      \"Attributes\": {},\n      \"BalancerAttributes\": null,\n      \"Type\": 0,\n      \"Metadata\": null\n    }\n  ],\n  \"ServiceConfig\": null,\n  \"Attributes\": null\n} (resolver returned new addresses)" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563931403+02:00" level=info msg="[core] [Channel #1] Channel switches to new LB policy \"pick_first\"" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.563975235+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel created" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564008297+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564038921+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel picks a new address \"/run/containerd/containerd.sock\" to connect" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564076098+02:00" level=info msg="[core] [Channel #1] Channel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564240896+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel Connectivity change to READY" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564263582+02:00" level=info msg="[core] [Channel #1] Channel Connectivity change to READY" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564703862+02:00" level=info msg="[core] [Channel #4] Channel created" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564716827+02:00" level=info msg="[core] [Channel #4] original dial target is: \"unix:///run/containerd/containerd.sock\"" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564738252+02:00" level=info msg="[core] [Channel #4] parsed dial target is: {Scheme:unix Authority: Endpoint:run/containerd/containerd.sock URL:{Scheme:unix Opaque: User: Host: Path:/run/containerd/containerd.sock RawPath: OmitHost:false ForceQuery:false RawQuery: Fragment: RawFragment:}}" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564753006+02:00" level=info msg="[core] [Channel #4] Channel authority set to \"localhost\"" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564780362+02:00" level=info msg="[core] [Channel #4] Resolver state updated: {\n  \"Addresses\": [\n    {\n      \"Addr\": \"/run/containerd/containerd.sock\",\n      \"ServerName\": \"\",\n      \"Attributes\": {},\n      \"BalancerAttributes\": null,\n      \"Type\": 0,\n      \"Metadata\": null\n    }\n  ],\n  \"ServiceConfig\": null,\n  \"Attributes\": null\n} (resolver returned new addresses)" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564805722+02:00" level=info msg="[core] [Channel #4] Channel switches to new LB policy \"pick_first\"" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564827360+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel created" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564852477+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564876326+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel picks a new address \"/run/containerd/containerd.sock\" to connect" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.564885650+02:00" level=info msg="[core] [Channel #4] Channel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.565039602+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel Connectivity change to READY" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.565066329+02:00" level=info msg="[core] [Channel #4] Channel Connectivity change to READY" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.565325137+02:00" level=info msg="[graphdriver] trying configured driver: overlay2"
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.567149388+02:00" level=error msg="failed to mount overlay: no such device" storage-driver=overlay2
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.567327923+02:00" level=info msg="[core] [Channel #1] Channel Connectivity change to SHUTDOWN" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.567348138+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel Connectivity change to SHUTDOWN" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.567359588+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel deleted" module=grpc
apr 19 12:03:52 dockerd[103186]: time="2023-04-19T12:03:52.567368048+02:00" level=info msg="[core] [Channel #1] Channel deleted" module=grpc
apr 19 12:03:52 dockerd[103186]: failed to start daemon: error initializing graphdriver: driver not supported
apr 19 12:03:52 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
apr 19 12:03:52 systemd[1]: docker.service: Failed with result 'exit-code'.
apr 19 12:03:52 systemd[1]: Failed to start Docker Application Container Engine.
apr 19 12:03:54 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
apr 19 12:03:54 systemd[1]: Stopped Docker Application Container Engine.
apr 19 12:03:54 systemd[1]: Starting Docker Application Container Engine...
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.787340828+02:00" level=info msg="Starting up"
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788518657+02:00" level=info msg="[core] [Channel #1] Channel created" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788533513+02:00" level=info msg="[core] [Channel #1] original dial target is: \"unix:///run/containerd/containerd.sock\"" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788553280+02:00" level=info msg="[core] [Channel #1] parsed dial target is: {Scheme:unix Authority: Endpoint:run/containerd/containerd.sock URL:{Scheme:unix Opaque: User: Host: Path:/run/containerd/containerd.sock RawPath: OmitHost:false ForceQuery:false RawQuery: Fragment: RawFragment:}}" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788563586+02:00" level=info msg="[core] [Channel #1] Channel authority set to \"localhost\"" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788628685+02:00" level=info msg="[core] [Channel #1] Resolver state updated: {\n  \"Addresses\": [\n    {\n      \"Addr\": \"/run/containerd/containerd.sock\",\n      \"ServerName\": \"\",\n      \"Attributes\": {},\n      \"BalancerAttributes\": null,\n      \"Type\": 0,\n      \"Metadata\": null\n    }\n  ],\n  \"ServiceConfig\": null,\n  \"Attributes\": null\n} (resolver returned new addresses)" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788664970+02:00" level=info msg="[core] [Channel #1] Channel switches to new LB policy \"pick_first\"" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788710068+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel created" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788732288+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788751475+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel picks a new address \"/run/containerd/containerd.sock\" to connect" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.788773693+02:00" level=info msg="[core] [Channel #1] Channel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789003753+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel Connectivity change to READY" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789036514+02:00" level=info msg="[core] [Channel #1] Channel Connectivity change to READY" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789559568+02:00" level=info msg="[core] [Channel #4] Channel created" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789574895+02:00" level=info msg="[core] [Channel #4] original dial target is: \"unix:///run/containerd/containerd.sock\"" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789604127+02:00" level=info msg="[core] [Channel #4] parsed dial target is: {Scheme:unix Authority: Endpoint:run/containerd/containerd.sock URL:{Scheme:unix Opaque: User: Host: Path:/run/containerd/containerd.sock RawPath: OmitHost:false ForceQuery:false RawQuery: Fragment: RawFragment:}}" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789624984+02:00" level=info msg="[core] [Channel #4] Channel authority set to \"localhost\"" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789662149+02:00" level=info msg="[core] [Channel #4] Resolver state updated: {\n  \"Addresses\": [\n    {\n      \"Addr\": \"/run/containerd/containerd.sock\",\n      \"ServerName\": \"\",\n      \"Attributes\": {},\n      \"BalancerAttributes\": null,\n      \"Type\": 0,\n      \"Metadata\": null\n    }\n  ],\n  \"ServiceConfig\": null,\n  \"Attributes\": null\n} (resolver returned new addresses)" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789691965+02:00" level=info msg="[core] [Channel #4] Channel switches to new LB policy \"pick_first\"" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789717680+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel created" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789740622+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789763361+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel picks a new address \"/run/containerd/containerd.sock\" to connect" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789773201+02:00" level=info msg="[core] [Channel #4] Channel Connectivity change to CONNECTING" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789971916+02:00" level=info msg="[core] [Channel #4 SubChannel #5] Subchannel Connectivity change to READY" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.789994370+02:00" level=info msg="[core] [Channel #4] Channel Connectivity change to READY" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.790266968+02:00" level=info msg="[graphdriver] trying configured driver: overlay2"
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.792211265+02:00" level=error msg="failed to mount overlay: no such device" storage-driver=overlay2
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.792371907+02:00" level=info msg="[core] [Channel #1] Channel Connectivity change to SHUTDOWN" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.792391577+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel Connectivity change to SHUTDOWN" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.792408028+02:00" level=info msg="[core] [Channel #1 SubChannel #2] Subchannel deleted" module=grpc
apr 19 12:03:54 dockerd[103200]: time="2023-04-19T12:03:54.792417041+02:00" level=info msg="[core] [Channel #1] Channel deleted" module=grpc
apr 19 12:03:54 dockerd[103200]: failed to start daemon: error initializing graphdriver: driver not supported
apr 19 12:03:54 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
apr 19 12:03:54 systemd[1]: docker.service: Failed with result 'exit-code'.
apr 19 12:03:54 systemd[1]: Failed to start Docker Application Container Engine.
apr 19 12:03:56 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
apr 19 12:03:56 systemd[1]: Stopped Docker Application Container Engine.
apr 19 12:03:56 systemd[1]: docker.service: Start request repeated too quickly.
apr 19 12:03:56 systemd[1]: docker.service: Failed with result 'exit-code'.
apr 19 12:03:56 systemd[1]: Failed to start Docker Application Container Engine.
I followed the instructions here to switch to overlay but it did not help.
Any ideas?
Did you reboot after the installation? (or rather after the last update of your kernel)
Most likely, you installed a new kernel (upgrade) in the meantime. No wonder the overlay2 cannot be loaded. A reboot is needed, therefore.
sigh… this worked. Thanks.
Should’ve remembered the first rule of diagnosis – turning it off and back on again.
