Hi, I cant remeber when it started to fail loading docker at init time
kernel 5.9.11-3-MANJARO
Docker version 19.03.13-ce, build 4484c46d9d (re installed)
this is the systemctl status:
⇝ systemctl status docker.service
● docker.service - Docker Application Container Engine
Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Wed 2020-12-23 17:48:52 -03; 9min ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Process: 6996 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock>
Main PID: 6996 (code=exited, status=1/FAILURE)
dic 23 17:48:52 icarusdb systemd[1]: docker.service: Scheduled restart job, restart counter is at >
dic 23 17:48:52 icarusdb systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:48:52 icarusdb systemd[1]: docker.service: Start request repeated too quickly.
dic 23 17:48:52 icarusdb systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:48:52 icarusdb systemd[1]: Failed to start Docker Application Container Engine.
and this is the journal log:
-- Logs begin at Thu 2020-08-27 22:52:30 -04, end at Wed 2020-12-23 17:49:35 -03. --
dic 23 17:43:13 systemd[1]: Starting Docker Application Container Engine...
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.884818919-03:00" level=info msg="Starting up"
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.886913214-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.886936725-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.886967675-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.886987569-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.897680206-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.897868693-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.897985827-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.898114258-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.910577329-03:00" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
dic 23 17:43:13 dockerd[544]: time="2020-12-23T17:43:13.910775363-03:00" level=error msg="[graphdriver] prior storage driver aufs failed: driver not supported"
dic 23 17:43:13 dockerd[544]: failed to start daemon: error initializing graphdriver: driver not supported
dic 23 17:43:13 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
dic 23 17:43:13 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:43:13 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:43:16 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
dic 23 17:43:16 systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:43:16 systemd[1]: Starting Docker Application Container Engine...
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.223505564-03:00" level=info msg="Starting up"
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.224877972-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.224906566-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.224954942-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.224976910-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.226134573-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.226160431-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.226200454-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.226222378-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.229155156-03:00" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
dic 23 17:43:16 dockerd[790]: time="2020-12-23T17:43:16.229191641-03:00" level=error msg="[graphdriver] prior storage driver aufs failed: driver not supported"
dic 23 17:43:16 dockerd[790]: failed to start daemon: error initializing graphdriver: driver not supported
dic 23 17:43:16 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
dic 23 17:43:16 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:43:16 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:43:18 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
dic 23 17:43:18 systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:43:18 systemd[1]: Starting Docker Application Container Engine...
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.408044065-03:00" level=info msg="Starting up"
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.409217533-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.409246255-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.409272071-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.409296099-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.410523594-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.410548438-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.410564363-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.410573876-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.413331556-03:00" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
dic 23 17:43:18 dockerd[977]: time="2020-12-23T17:43:18.413378469-03:00" level=error msg="[graphdriver] prior storage driver aufs failed: driver not supported"
dic 23 17:43:18 dockerd[977]: failed to start daemon: error initializing graphdriver: driver not supported
dic 23 17:43:18 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
dic 23 17:43:18 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:43:18 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:43:20 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
dic 23 17:43:20 systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:43:20 systemd[1]: docker.service: Start request repeated too quickly.
dic 23 17:43:20 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:43:20 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:48:45 systemd[1]: Starting Docker Application Container Engine...
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.445586744-03:00" level=info msg="Starting up"
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.446655989-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.446679798-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.446706231-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.446729526-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.447720708-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.447742801-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.447766442-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.447780306-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.449978604-03:00" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
dic 23 17:48:45 dockerd[6700]: time="2020-12-23T17:48:45.450012094-03:00" level=error msg="[graphdriver] prior storage driver aufs failed: driver not supported"
dic 23 17:48:45 dockerd[6700]: failed to start daemon: error initializing graphdriver: driver not supported
dic 23 17:48:45 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
dic 23 17:48:45 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:48:45 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:48:47 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
dic 23 17:48:47 systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:48:47 systemd[1]: Starting Docker Application Container Engine...
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.773336910-03:00" level=info msg="Starting up"
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.774527700-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.774556171-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.774594904-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.774613790-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.775487916-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.775514390-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.775538592-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.775563759-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.777668724-03:00" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
dic 23 17:48:47 dockerd[6984]: time="2020-12-23T17:48:47.777697914-03:00" level=error msg="[graphdriver] prior storage driver aufs failed: driver not supported"
dic 23 17:48:47 dockerd[6984]: failed to start daemon: error initializing graphdriver: driver not supported
dic 23 17:48:47 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
dic 23 17:48:47 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:48:47 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:48:49 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
dic 23 17:48:49 systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:48:49 systemd[1]: Starting Docker Application Container Engine...
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.023576078-03:00" level=info msg="Starting up"
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.024810321-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.024833744-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.024856220-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.024872733-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.025734729-03:00" level=info msg="parsed scheme: \"unix\"" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.025757279-03:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.025781924-03:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.025805590-03:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.027990908-03:00" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
dic 23 17:48:50 dockerd[6996]: time="2020-12-23T17:48:50.028032870-03:00" level=error msg="[graphdriver] prior storage driver aufs failed: driver not supported"
dic 23 17:48:50 dockerd[6996]: failed to start daemon: error initializing graphdriver: driver not supported
dic 23 17:48:50 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
dic 23 17:48:50 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:48:50 systemd[1]: Failed to start Docker Application Container Engine.
dic 23 17:48:52 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
dic 23 17:48:52 systemd[1]: Stopped Docker Application Container Engine.
dic 23 17:48:52 systemd[1]: docker.service: Start request repeated too quickly.
dic 23 17:48:52 systemd[1]: docker.service: Failed with result 'exit-code'.
dic 23 17:48:52 systemd[1]: Failed to start Docker Application Container Engine.
